Spark plug photos. Are these as fouled as I think they are?
Old Sep 4, 2009 | 05:59 PM
acr2001's Avatar
2012 C300 4Matic
The photos below are of one of my original NGK plugs with only 27,000 miles on it (2005 C240).
So far I only removed 2 plugs and they look identical. I have to get my hands on the right tool before I can remove the other plug wires without damaging them.
I decided to change them because my car was not starting as quickly or smoothly as it should.
I really don't have a clue about how spark plugs should look, but I'm guessing these are pretty well fouled with carbon / oil? Anyone?
Attached Thumbnails Spark plug photos. Are these as fouled as I think they are?-pict0001.jpg   Spark plug photos. Are these as fouled as I think they are?-pict0002.jpg
Old Sep 4, 2009 | 06:13 PM
dnlow's Avatar
2005 c230k
They look pretty good. I would wait to change them, but if you want it will not hurt. I recently changed my plugs at about 85k and they looked a bit worse than yours, but still acceptable for the miles. I did notice a slightly smoother engine though.
Old Sep 4, 2009 | 06:32 PM
Glyn M Ruck's Avatar
Super Moderator
Mine looked similar at 45,000Km - Bosch though - Changing them stopped the spluttery starts I talked about on the other thread. I would change them as Benz advise. Bosch run a finer centre electrode.
Plugs from fuel injected cars running on lead free fuel always look so damn good compared with the lead errosion & deposits of the past. This can be misleading.
Old Sep 4, 2009 | 06:53 PM
acr2001's Avatar
2012 C300 4Matic
Glad to hear that. I actually swapped those 2 for new plugs today (replaced with the same part #). I was going to do all 12 but I can't find a way to remove the other plug wires without damaging them. Going to get the removal tool tomorrow.
Old Sep 4, 2009 | 07:28 PM
Super Moderator
That tool is a good idea - Hanging on the wires is not - as I know you know.
Old Sep 5, 2009 | 07:37 PM
acr2001's Avatar
2012 C300 4Matic
Finished swapping all the plugs today. The engine feels smoother and a lot stronger on the low end. Revs up more smoothly too.
Now I have to get the dealer to fix the passenger side recirculating cover which is leaking oil again. They already fixed it once but not surprisingly did a **** job.
Old Sep 5, 2009 | 08:12 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Is this recirculating cover exclusive to the M112? Or does the M272 family have it, too?
Old Sep 5, 2009 | 10:20 PM
acr2001's Avatar
2012 C300 4Matic
The problem with it leaking is specific to the M112. It's probably the most common problem I've heard of on the M112. I'm seriously thinking about fixing it myself even though the car is under warranty. My dealer *really* sucks.
It's pretty easy to fix - https://mbworld.org/forums/c-class-w...ing-cover.html
