My faclifting inc new Comand NTG 2.5
Old Sep 25, 2010 | 09:39 AM
  #176
tijn's Avatar
White w203 C200K Elegance
Originally Posted by Chris The Swede
1. Works only with a new cluster. Already discussed!
You said the cluster could be reprogramming from D2B to MOST?
Also, if i buy a W211 cluster nothing will work on it? but a w209 will work? Does the w209 cluster need to be petrol if my car is petrol or will a diesel one work?
what about a w203 MY2005+ update cluster will that work with comand 2.5 in the preface-lift w203?
and these clusters fit directly into the preface-lift w203 with no rewiring just a direct swap?
Old Sep 25, 2010 | 11:30 AM
  #177
OverDrive's Avatar
Volvo
Keep in mind, That the cluster has to be new, or less than 1000 miles on them, You cant buy a used one off ebay or anywhere else. Why? Because your not able to program them after 1000 miles, hints won't work, The 03-04 W209 will work with just programing the miles, the later ones you will need to program it for an older fuel sensor and a couple other things. Same with the 05+ facelift W203.
Old Sep 25, 2010 | 06:55 PM
  #178
Chris The Swede's Avatar
W222 S63L, ML/GLE350
And W211 do NOT work or fit.
Old Sep 25, 2010 | 07:05 PM
  #179
GIANNISANAG's Avatar
w203 c200K 2.0 mod 02
the problem i am facing is the following:
car: w203 mod 2002 m111 engine manual
retrofit: facelift center console
ice:audio 20
cluster : clk 63 amg most
problem: star cannot se the cluster or the audio 20 either. However, audio 20 works perfectly and i have steering controls and cluster info.
problem no2: tried to fit an ntg2 command. Star does not see it. I am thinking of trying to code the comand with the old cluster fitted as the cluster seems to make the canbus a mess
ps: the cluster works perfectly (ever single feature except odo of course). the star cannot see the cluster either.
any advice??? (cluster is new)
Old Sep 25, 2010 | 10:11 PM
  #180
OverDrive's Avatar
Volvo
Its possible (Im just spitballing here) that you need to hook it up to obdII, On the pre facelift there was a wire on audio 10, and the comand 2.0 thats part of the connector that connects it to Obd2. It may need that hooked up before it would read... Thats my guess as i have the same issue even though i don't need the star system.
Old Sep 26, 2010 | 01:33 AM
  #181
why wouldnt you need the star???
the cable you are talking about is the canbus and it is already plugged in the appropriate canbus distributor. this is why i have steering controls and cluster info.
As I see it i have 2 options.
1. I will have to code the comand on another MOST car. Then I could easily live without the ability to use star dignose to do thing to the comand. That would be the case if i had a non-oem unit so i can live with it. howevere I should better add any star enabled devices (such as phone kit) before doing the coding
2. I could use an ntg 2.5 unit (audio 20 or comand) I need bluetooth and mp3 more than navi and movies and the audio 20 ntg 2.5 is ridicusly cheap to buy as new. I suspect that i will not need any coding at all!!!
Old Sep 27, 2010 | 03:05 AM
  #182
And you have my answers on mail...And you are corect.
Old Oct 7, 2010 | 10:42 AM
  #183
nguyennhatquang's Avatar
W219 CLS500 M113, W203 C240 M112.
i think u select the 209 car in Star..
then intial start up from it..
u'll see the ICM..
Old Oct 29, 2010 | 06:24 PM
  #184
ozique's Avatar
Mercedes ML270CDI
It was a W211 silver panel and dails I put in a W209 D2B cluster. Then I tried the W211 cluster that is MOST in the car and damn it all worked.
It is possible that the W209 cluster cant be programed to be MOST..I heard one say it could..But if not I just get a W211 or newrer W209 cluster and do the fitting with..I have bought a Star Diagnostic now so I can play with it my self.
Hi Chris, you are real genius.
What about W163? Appalling cluster, need to be updated with W208/210 cluster with computer display, steering wheel to connect to Comand? Any possibility and what about NTG 2.5 from W164?
Sorry I am asking too much,, as I have asked around everywhere, and everyone went blank!
I mean retrofitting for this model.
Cheers.
Old Mar 22, 2011 | 12:15 PM
  #185
Silver C's Avatar
C240
Wow this is insane! I so want it...
But one question arises for me, a few mentioned the upgrade isnt worth it.. Taking from your example of 5 hours work, i guess time isnt the issue. Then it comes down to the cost factor.. How much in total did it cost you to fit the whole thing and make it work?
Old Mar 22, 2011 | 09:14 PM
  #186
OverDrive's Avatar
Volvo
Mine was $1200.00, Have a look at the DIY for it in my sig, I broke down the price list
Old Nov 24, 2011 | 07:19 AM
  #187
Anej's Avatar
Mercedes-Benz CLK 270 CDI avantgarde
Congratulations! You did great job! I am thinking about this since I bought my pre facelift CLK (2004 :S).
Old Nov 24, 2011 | 11:59 AM
  #188
Thanx...Nice to se that this old thread still inspires.
Old Dec 16, 2011 | 10:20 AM
  #189
navycooder's Avatar
Mercedes C280
Does anyone know if this approuch would be possible on a 1999 C43? I already have comand 2.0 installed, but would like to upgrade again due to the technology being near obsolete as it was created back in 1998. Would a newer comand talk to the instrument cluster? What all would need to be done? Could climate and instrument cluster be updated as well? Thanks!
Old Dec 16, 2011 | 10:58 AM
  #190
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Thanx...Nice to see that this old thread still inspires.
apologies for going O/T, but Chris, since you are such a good answerer (!?), do you know if these small parts are available by themselves?
the "chrome" trim piece inside the a/c vent louvers
the blank switches in the upper switch row
Old Dec 20, 2011 | 06:31 AM
  #191
No they are not.
Old Dec 20, 2011 | 10:42 AM
  #192
Glyn M Ruck's Avatar
Super Moderator
I posted it to the CLK forum due to questions being asked
Old Dec 29, 2011 | 08:59 AM
  #193
190Benz's Avatar
190 evoII replica
I don't know if it has been discussed allready but i have a w209 cluster that i want to put in my 2005 w203.
I already found someone who can program the mileage. Will the rest of it be plug & play and will al the features in the cluster work?
Old Jan 11, 2012 | 07:53 AM
  #194
190Benz's Avatar
190 evoII replica
Nobody?
Old Jan 11, 2012 | 08:09 AM
  #195
I will pm you the details. Till then search my profile to find posts and photos
Old Jan 24, 2012 | 09:07 AM
  #196
190Benz's Avatar
190 evoII replica
I got my w209 cluster to work in my 2005 w203 200cdi. The mileage still has to be programmed.
But! It doesn't seem to fit :-s i cut of a piece of the plastic in the back but i still have to jam in it and it still sticks out like 2cm.
I thought that it would fit nicely...
Old Jan 24, 2012 | 10:24 AM
  #197
You need a new holder in the back.
Old Jan 24, 2012 | 12:12 PM
  #198
190Benz's Avatar
190 evoII replica
Do you have a partnumber and some pictures on how to remove it?
I was thinking about cutting away pieces because it looks like there is allot attached to it from beneath.
Old Jan 24, 2012 | 12:36 PM
  #199
WaveyKat's Avatar
Something Slow
can you take a Pciture of the Space its sticking out? also yes will need the W209 REAR Bracket For it To Sit Nicely
Old Jan 24, 2012 | 01:03 PM
  #200
190Benz's Avatar
190 evoII replica
Will take a picture tomorow and a picture of the piece i cut off.
It's dark here now :-)
