My faclifting inc new Comand NTG 2.5
Old Jan 24, 2012 | 01:40 PM
  #201
WaveyKat's Avatar
Something Slow
i also heard it still doesnt fit nicely.. but inorder to install the bracket the Entire Dash has to be removed from what i know
Old Jan 25, 2012 | 05:49 AM
  #202
Chris The Swede's Avatar
W222 S63L, ML/GLE350
There will be some gaps since it is for W209 and it is not the same hole in W203.
Old Jan 25, 2012 | 11:29 AM
  #203
190Benz's Avatar
190 evoII replica
I am not talking about gaps. It just doens't feel right jamming it in that hard.
Feels like i will never get the tacho out again.
Does anyone know what this means? Does it mean that there is a problem with the convertible roof?
Old Jan 26, 2012 | 03:20 AM
  #204
That is the back mounting frame that is to small. You have to replace it or cut off alot of details on it. Yes..That is a cluster from a W209 Conv...Dont know if you can use it on a W203. Try to pogram it or take away the LED.
Old Jan 26, 2012 | 06:18 AM
  #205
190Benz's Avatar
190 evoII replica
Yeah i was thinking about asking steve to program it for a clk coupe.
I will first try to cut away some of the back frame.
The cluster also has the black series "carbon fiber" frame :-)
Old Jan 26, 2012 | 05:46 PM
  #206
WaveyKat's Avatar
Something Slow
yep you need the W209 Cluster Bracket..was that a brand new cluster?
Old Jan 27, 2012 | 07:32 AM
  #207
190Benz's Avatar
190 evoII replica
No a second hand one.
Old Jan 27, 2012 | 08:18 AM
  #208
WaveyKat's Avatar
Something Slow
so wait you got a used cluster to work? i need a new cluster i would like to get the W209 style but am scared to puchase one then it doesnt work for me i will be pissed since you have a 2005+ you already have the Newer Fuel Pumps etc.. so its easy to sync with the cluster. i have a 2001 C320k my cluster Speedo Needles doesnt Work so am looking for a new Cluster. im not sure which direction to go with it. :-(
Old Jan 27, 2012 | 10:48 AM
  #209
190Benz's Avatar
190 evoII replica
Yes i have a +05 so i have the right fuel pump and stuff from stock.
It works except for the mileage. I have to get that reset and then make the cluster fit properly.
Old Jan 27, 2012 | 11:23 AM
  #210
You will NEVER gat a used cluster to work with milage. You MUST have a new one.
Old Jan 27, 2012 | 12:16 PM
  #211
ND2020's Avatar
2004 C320 Sport
Chris I have a random question for you...
Do you know if It's possible to program a face-lifted analog climate control unit to work in a pre facelift digital? I know alot of people upgrade to the digital, but I would much prefer a knob to adjusts temps rather than tapping a button repeatedly. I've heard the analog units are not plug and play...as in the dual climate control aspect does not work. Not to mention analog units are much easier to come by.
Old Jan 28, 2012 | 03:20 AM
  #212
Dont think so. My digital worked perfect even tough I had analog before.
Old Feb 23, 2012 | 10:21 AM
  #213
MB-CLS500's Avatar
CL600 W216
TACHO,SPEEDO. INStument cluster
Do anybody wants to buy speedo here? I have 2006 cls500 speedo in W211 housing very mint works great $150+ shipping
Old Feb 23, 2012 | 11:15 AM
  #214
GIANNISANAG's Avatar
w203 c200K 2.0 mod 02
I d take it
Any pics?
Old Feb 23, 2012 | 11:49 AM
  #215
Dont fit W203 tthough.
Old Feb 23, 2012 | 12:38 PM
  #216
MB-CLS500's Avatar
CL600 W216
pic
Originally Posted by GIANNISANAG
I d take it
Any pics?
http://www.benzworld.org/forums/w211...ml#post5125597 here is photo
Old Mar 2, 2012 | 04:04 PM
  #217
Adrenal Rush's Avatar
Hello guys, I retrofit the central console of my W203@2001 to Audio 20, but have a small issue. Cluster display info and steering controls don't work.
Audio is working normaly. When I turn the ignition switch, it power's on. On the cluster display the only info is: Audio ----
My wiring is as follows:
Quadlock pins:
9 CAN Bus Low Brown
10 Mute Yellow/Black
11 CAN Bus High Brown/Red
12 Terminal 31 (-) Brown
13 Antenna Supply Black
15 Terminal 30 (+) Red/Blue
Please help me to find out what's going on.
Old Mar 2, 2012 | 06:15 PM
  #218
Will never work until you change tonew MOST cluster. I have discribed this several times.
Old Mar 3, 2012 | 09:44 AM
  #219
Thank you Chris for your reply.
So i have two options here. To replace the cluster with w209 or w203 facelift right ?
I know that there are several issues with w209 cluster. ODO meter and fuel meter.
If i choose the w203 instrument what will be the issues and what shoud i do to fix them ?
P.S. Sorry fot the questions, I've tryind to find similar thread but no success.
Old Mar 3, 2012 | 09:58 AM
  #220
Same issues with both.
Old Mar 4, 2012 | 12:38 PM
  #221
wodturner's Avatar
2004 c230 4cyl supercharge
My PM's are not working. Are you selling the old head unit?
Bob
Old Mar 21, 2012 | 08:36 PM
  #222
sarcazm's Avatar
2004.5 230k
to fit the 209 cluster...you need the W209 Cluster Bracket...a part number on it? i didnt see it on the website you provided, and any pics on where u had to modify/cut? mines is sticking out like the pic above...cant be riding silver star an having that!!! lol
Old Mar 27, 2012 | 08:50 PM
  #223
sarcazm's Avatar
2004.5 230k
Old Apr 4, 2012 | 05:25 AM
  #224
190Benz's Avatar
190 evoII replica
I will post some pics of what to cut when i have the time to work on my car.
Old May 14, 2012 | 06:59 AM
  #225
jlelvira's Avatar
CLK320 w209
Hi, I'm trying to change the comand comand 2.0 for NTG2
scheme have the iso connectors at quadlock
thanks
this is my email (jlelvira@aol.es)
in my 2001 c-class the comand 2.0 has other plugs and cables than the comand aps in the 2004 model (should be the same plugs and cables to the harddrive comand aps you used)...i've always read that everything just goes plug & play.
i have nearly all the parts i need from the facelift model but i don't want to buy the comand aps if it won't work...
here are two pics with (not mine - i have it from the net) comand 2.0 and comand aps backs:
they have some cables that don't fit, e.g. gps...
please help me!
cheers mario[/QUOTE]
