Running 235/40R 17's all around on '05 Sport
Old Oct 18, 2009 | 09:09 PM
Twenty4Play's Avatar
2K5 C230K SS 6MT -BLK/BLK
I found some ridiculously priced (cheap) Advan Neova AD07's, the only problem is they are only 235/40R 17's. ;-( Anyone see a problem running these all around on the staggered rims? I'm trying to get some good tires for running auto-x, and Advan's are some of the best.
Old Oct 18, 2009 | 11:05 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
there shouldn't be any problems. I just don't think you can rotate them since the rears are wider then the fronts.
Old Oct 18, 2009 | 11:31 PM
Yea that's what I figured. I'm running 225's all the way around for winter tires right now and no problems, but I was worried the 235's wouldn't work well with the fronts.
Old Oct 19, 2009 | 12:13 AM
TemjinX2's Avatar
you might rub a little on U turns depending on the brand. I'm running 235's all around and i rub a little on U turns.
Old Oct 19, 2009 | 12:36 AM
Yea, when I first put my snow tires on (225's) they rubbed when doing U-turns or backing with the wheel cranked to the right or left.
Old Oct 19, 2009 | 03:08 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it won't rub because 235/40/17 is half inch smaller in diameter.
Old Oct 19, 2009 | 07:50 AM
Glyn M Ruck's Avatar
Super Moderator
Mike - you are running 18" - yes? I'm about to go 245/40/17 all round like splinter. He says he has zero rubs or touches.
What is your clearance on the front strut?
Old Oct 19, 2009 | 08:27 AM
TemjinX2's Avatar
i'm running 19's. keep in mind different brands have slightly different widths even if the number is the same.
I rub less with my hankook evos then i do with my BFG TA's. Both are 235/35/19, but the bfg seem slightly wider.
Old Oct 19, 2009 | 12:21 PM
Super Moderator
What rim width & offset? Do you actually have some rubbing on the strut up front? Do you have stock struts?
I will be going Michelin PS2s or Exalto PE2s if I can get the size.
Old Oct 19, 2009 | 01:29 PM
krisv420's Avatar
02 C320 Sedan
Im running 235/45/17 ALL AROUND.. pirelli p6
It is so close in the front its not even funny.. i can't even put 1 finger from the tire to the spring / shock or w/e
I hear a funny noise sometimes when i back up but i don't know if its from my tires or if its something else.
But i never rubb or anything its so close it feels like it..
Old Oct 19, 2009 | 05:14 PM
Super Moderator
Kris - do you know the offset of those E Class rims?
Old Oct 19, 2009 | 06:35 PM
krisv420's Avatar
02 C320 Sedan
Yeah it says 37 on the inside i could be wrong but i will look again when i take my wheels off
Old Oct 19, 2009 | 07:10 PM
TemjinX2's Avatar
i'm running a front et of 27, on a 19x 8.5 rim. Basically the outside half of the tire rubs against the inside part of the inner fender on U turns. I'm probably lower around 1.5-1.75 inches. Basically its a one finger gape from the tire and fender. Its not a big deal since i dont make U turns often.
I have to keep the bfg's in the rear since its rubs on just regular turns. Thats why i think bfg cheated a little since there 235 is a lot wider then the general and hankook 235.
Old Oct 19, 2009 | 08:01 PM
Super Moderator
OK - I'm about to run 17X8 ET32 with 245/40/17 all round. I'm not worried about outside problems. My only worry was the strut. 1010 tyres & all other calculators tell me I will be fine. Hope so!
Old Oct 19, 2009 | 08:43 PM
TemjinX2's Avatar
i think you should be fine..since frank pointed out your running smaller diameter tires.
