Oil Dip Stick Question
Given that our cars come without a oil dip stick and just a cover I was wondering if anyone had decided to use a dip stick rather than a cover?
I pulled the one from my W210 and noticed that it fit perfectly and also gave me a correct oil level reading.
Is there any reason NOT to leave the dip stick in???
I bought a dipstick. It's not something you can keep in your car while driving as it's about a foot or so longer than it needs to be for this. I was confused about how to use it (or even if I got the correct part) because it was so long, however found out you stick it all the way in until it bottoms out to make the measurement (I'm used to just putting the dipstick in all the way and then pulling it out, as I'm sure most are).
I'll double check with my Mercedes contact at the dealer and see what they say and report back.
I'm hoping that this may be a solution for everyone that's irritated with having to use a dip stick that doesn't fit or use the stupid electronic method.
It's just that, to me, using a dipstick is far easier and simpler.
Why do so many folks ask about using the dipstick measuring method???
Same with the trans fluid. I'll be you if there was a measuring tool for the trans that you could leave in a ton of folks would do that.
Why do the older cars have a dip stick? Why not just guess about the oil level?
If the electronic method of checking was fool proof why is there a tube for a dip stick?
I never understand why there are always folks like you that have to say negative things about questions. If you ain't got nothing nice to say keep it to youself!
And here I thought I was onto something positive that I could share with folks here.
Edit: I agree with you about the transmission dipstick. That whole situation is ridiculous.
Just to me, the oil level is so important I'd prefer not to trust electronics. I know there are those that do.
Look at the fuel level sending unit on some Benz's. They're never accurate! LOL!
Thanks for the interesting posting & forget about grumpy.
Then we can give out the correct info if something does really happen you know?
Booo this is sad just got my car waxxeddd and i don't wanna drive it in the rain BOO but i wanna go out
Sorry if im an ******* lol i quit smoking pot =D
I think you've got pretty good odds trusting the electronics. Indeed you should do whatever makes you comfortable, but don't try to pass extreme paranoia for common sense under the implication that those of us who use the electronic systems are being foolish. If I can't trust its simple oil level monitoring system to give me an accurate reading, I feel I could hardly trust its complex SRS system to protect me in a crash... oh bother, I guess I shouldn't drive it at all.
I'd rather a dipstick & have the car a little cheaper & with one less thing to go wrong.
Wow, ... what an imposition to have to open your bonnet & check the oil. You never know you might check to see if everything is as it should be under there. eg any leaks, unusual noises ,brake fluid level & coolant level & top up the windscreen reservoir ect.
I prefer to drive a manual over a cutting edge DSG transmission. That's my preference, but I know the manual isn't any "better". Same principle applies here.
Sheesh, this was supposed to be such a simple harmless question and it turned out to be such a sensitive issue to some folks.
The oil tube is there and rather than just plug it with a cap I thought it'd be cool to use a dip stick if possible and I'm sure there are a bunch of folks that would like to do that also.
As I said, I'll check tomorrow and post back.
Besides, double-checking the oil level after topping off the car would be a serious PITA if I had to rely on the MFD.
It sounds like the dipstick is sealing ok at the top - I would leave it in, drive around a couple of days, and see if the oil level has dropped. If it hasn't, pat yourself on the back for finding a dipstick that works for your car. I see nothing wrong with having a reliable oil level indicator in our cars, if only as a back up to the electronic nannies.
