My car pop up cel
Old Mar 6, 2010 | 12:17 AM
dutnguye's Avatar
My car pop up cel
it said p00022- i scan it and it meant intake camshaft position timing over retarded?
is it serious? and how much would it take to fix it?
Old Mar 6, 2010 | 02:58 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Try searching that code P0022. This is a common issue on cars with the M272 engines, not that we know what kind of car you have since you haven't updated that part of your profile.
Old Mar 6, 2010 | 08:45 AM
Glyn M Ruck's Avatar
Super Moderator
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2) so you must have a V6 & likely a quadcam V6 which is the 272. A camshaft position sensor has likely failed. See Johnand's thread in this regard. He found cheaper CPS's that are OE from suppliers other than stealers. Replacement is easy.
Old Mar 6, 2010 | 09:26 AM
ontmiss's Avatar
2007 C280 4matic Avantgarde
Happened to me a month ago P0015 what is same thing but on Bank 1. They first change camshaft sensor but didn't help. Second time they did some kind of camshaft timing udjustment as they told me and that helped. I have no idea how much would that cost because it was under warnty.
Old Mar 6, 2010 | 01:51 PM
dutnguye's Avatar
I have a 2006 c230
Old Mar 6, 2010 | 02:34 PM
Super Moderator
First replace the camshaft sensor. It is DIY and costs about $135. If this does not work then it's a dealer job with once only use impulse wheels etc.
https://mbworld.org/forums/attachmen...80504-1-21.pdf
https://mbworld.org/forums/attachmen...80504-1-23.pdf
Old Mar 6, 2010 | 03:01 PM
Super Moderator
impulse wheels
Old Mar 6, 2010 | 03:14 PM
dutnguye's Avatar
thanks i will have it fix this weekend maybe
