Miss fire on cyclinder #4
Old Jul 20, 2010 | 08:50 PM
04mbc230's Avatar
2006 C230 Sedan
I was told by my stealership that my Enginee #4 cyclinder has a miss fire. So how did this occur? What am I looking at in terms of repair? How can I make this problem go away?
Is this something I should be concern of?
Please advise.
Old Jul 20, 2010 | 08:54 PM
laneshift's Avatar
C240
https://mbworld.org/forums/c-class-w...ll-20-sec.html
Basically, something in your ignition system isn't working or similar. Dirty/old spark plugs or plug wires, or failing coil packs, can cause this. Furthermore, dirty or defective injectors can do it, too.
How many miles are on the car?
You want to do the cheaper things first. If your car is below 100k miles, don't worry too much about your coil packs. Swap your plugs for cylinder four out, along with the wires. Run some techron through that sucker.
I'm going through this same exact issue.
Also, your stealership may lie to you at times. Does your car shake at idle in drive? Have you ever felt a sudden drop in power out of nowhere, or a stutter? Perhaps a symptom in my thread I linked?
Old Jul 20, 2010 | 08:55 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Please advise.
#4 is at the rear of the engine. Most likely a bad coil pack. Or a bad spark plug. If you have more than 75k miles, I'd change the plugs, and change the coil pack on #4 as well. Coil packs are some $60.
Old Jul 20, 2010 | 08:57 PM
laneshift's Avatar
C240
NO WAY. REALLY?! I thought cylinder four is at the front of the engine, driver's side, as far from the driver as possible...
Old Jul 20, 2010 | 09:01 PM
fookoo303's Avatar
2003 c240
his is an I4 engine
Old Jul 20, 2010 | 09:02 PM
04mbc230's Avatar
2006 C230 Sedan
I have about 89500 miles on it. When you said techron, you mean that addative fuel injection bottle you pour in while pumping gas at the station right?
So a new set of spark plugs, Plug wires should be good?
Nope, I have got any expereinces of what you mention. Still pretty solid. Although on the first start up, it does makes some enginee noise. Perhaps this is normal for Mercedes?
Is there a distrubuter in this car? If so does this have to be replace? How about cap and rotor? Please excuse me, I am a noob here . I used to drive an integra and these are the items I look at when ever I play with miss fires and such.
Old Jul 20, 2010 | 09:06 PM
04mbc230's Avatar
2006 C230 Sedan
What is a coil pack? Where is this located? Any picture may help. I am so helpless with this car right now, since I am learning everything as a noob.
Thanks in advance for any advice.
Old Jul 20, 2010 | 09:08 PM
fookoo303's Avatar
2003 c240
the coil pack sits on you valve cover. Its pretty much what replaced the distributor. Your spark plug wire plugs into your coil pack, so just follow the wire to it.
Old Jul 20, 2010 | 09:09 PM
laneshift's Avatar
C240
For now, I would say cylinder four's plugs and wires. I'm sure you know the flow of things when talking of replacing plugs, but just a reminder! Remember that dielectric grease and anti-seize!!
The wires are a pain to get off sometimes. Rotate the wire connecting to the plug to loosen things up.
https://mbworld.org/forums/c-class-w...-plug-r-r.html
^Great write-up for the v6.
OOPS! My apologies, 2004 C230's still have the kompressor/4banger. Just use that v6 thread for reference then.
Old Jul 20, 2010 | 09:21 PM
SeaCoupe's Avatar
Yep, you were due. New plugs, Get a coil pack, take the advice offered above and have fun. Just insure you do not overtorque the plugs. The plug threads are steel, your cylinder head is aluminum. You can damge the head if you don't know how to proprly torque the plugs in.
E
Old Jul 20, 2010 | 09:22 PM
04mbc230's Avatar
2006 C230 Sedan
Thanks Lane!
Yea, I guess the V6 don't kick in until 2006 models. But even so, they have transmission problems. So the question is minor enginee problems or tranny problems that affects the enginee. After reading so much horror stories, I am wondering if there is any solid MB models at all.
Oh.. One more thing, supercharge vs just V6, I guess it depends who you ask about which is fun.
Old Jul 20, 2010 | 09:32 PM
fookoo303's Avatar
2003 c240
lane did your issue get resolved with the techron?
Old Jul 20, 2010 | 09:34 PM
laneshift's Avatar
C240
I was supposed to be able to give results tonight, but my window issue stopped me from driving my car. I don't want to break that window, especially it being still at the bottom of my door.
Old Jul 20, 2010 | 09:36 PM
fookoo303's Avatar
2003 c240
ouch.. problem after problem. that really sucks. hope it all gets resolved
Old Jul 20, 2010 | 09:49 PM
laneshift's Avatar
C240
Hah yeah. Problems arise whether I drive the thing or not. Anyway, OP, let us know your results!
Old Jul 20, 2010 | 10:34 PM
04mbc230's Avatar
2006 C230 Sedan
Yea, I will follow the recommendation and pick up the parts at the stealership tomorrow.
Old Jul 20, 2010 | 11:22 PM
laneshift's Avatar
C240
Plugs and wires for cylinder four will run you about 100 or so bucks. I think it was under 150. (This was at the stealership.)
Get techron form autozone or something. Much cheaper there.
Old Jul 21, 2010 | 12:27 AM
04mbc230's Avatar
2006 C230 Sedan
Is this techron thing the fuel injector cleaner? The black bottle? Or is this something else?
Old Jul 21, 2010 | 03:45 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
It's the black bottle. Also if you have oil leaking in your cam magnets this can cause a whole host of false alarms and is a general nightmare.
The C230K does not have engine problems, and the C230 V6 does not have transmission problems. The early cars were problematic electrically but the engines and transmissions were always solid.
Old Jul 21, 2010 | 11:39 AM
04mbc230's Avatar
2006 C230 Sedan
really? I used google and did this search. 2006 c230 issues and you have a nice time reading all the problems. Among the frequent titles, it shows that transmission problems.
As for c230k, well, I am sure this forum pretty much speaks for it. With the hose, senloid and such. I think that is pretty much "minor" enginee problems.
Or I am just being a little extreme on this. Oh, also some miss fires on some cyclinder as well.
Old Jul 21, 2010 | 01:17 PM
laneshift's Avatar
C240
Well, you are just about near the time where you should really swap all plugs and wires, if not coil packs, too. I would do that soon. If you're going to do such a big swap, buy the parts online. It'll save you an eyeball.
Old Jul 21, 2010 | 04:15 PM
LILBENZ230's Avatar
Those are recalls that all manufacturers have. Search Google for info on 1999-2003 Accord V6, Odyssey, Acura TL/CL and that will expose what a REAL transmission problem epidemic really is. The 722.6 5AT and 722.9 7G transmissions in the W203 are solid. We very rarely hear any any transmission woes on this forum.
Old Jul 21, 2010 | 06:03 PM
04mbc230's Avatar
2006 C230 Sedan
HAHAH.. Okay. I give you that.
