Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
- Mercedes-Benz C-Class: How to Remove Engine Cover
Step by step instructions for do-it-yourself repairs
C230 Engine cover removal and oil filter
2008 VW GTI
It drives me crazy that I can't figure out how to take this car apart on my own.
Does the entire car "snap" together without fasteners or what? I afraid to just yank on a part and end up breaking something.
Anyway...
How do I take off that grey and black plastic cover over the intake manifold?
Where is the oil filter?
Do I have to remove part of the plastic "belly-pan" in order to access the oil drain plug? I'm not changing the oil myself (untill 60k miles) but I'd figure I'd ask now.
There are no fasteners visable on the interior of the car. How do I remove trim pieces (generally)?
![Mad](https://mbworld.org/forums/images/smilies/mad.gif)
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
The oil filter is on the top left front of the engine. It is not a cannister; it is a cartridge type. Mercedes dealers do not use the drain plug. The oil is sucked out the dip stick tube.
2002 c230 sport coupe six spd. C7
The oil filter cartridge is under the gray plastic cover then. How does one get that off. I note that the power steer pump/resevior is under there too. I've got the same question, how does the cover over the intake manifold come off?
2002 C230 C2 C7 six spd. Bose Paprika
2008 VW GTI
Lynn, I realize MB uses a suction pump system to remove the old oil, but I've read here that there is also a drain plug. I believe that MB uses the suction system only to eliminate having to utilize a vehicle lift and to make the oil change faster and more efficient for them.
2008 VW GTI
In case anyone is still wondering about this:
Yes- the belly pan has to be removed to access the drain plug. In fact, about 10 screws and two belly pans have to be removed to access the plug. If I decide to change the oil myself, I'll definitely be getting a siphon (or fashioning a "hatch" on the belly pan to access the plug).
FYI- I had to remove both pans to clean empty the 1/2 quart of oil that I "spilled". There's some cool stuff to look at under there but I wouldn't want to take those panels off every time I changed the oil.
Former Vendor of MBWorld
engine cover
i would like to see pics if you take off your engine cover.
i thought about doing it 2.
by the way where is the supercharger and how can i see it. if possible?
2002 C230k
Re: engine cover
Here's a diagram for ya...
2008 VW GTI
BlackC230Coupe,
Picture here: https://mbworld.org/forums/showthrea...&threadid=4501
-or-
Just pop the covers off yourself. Pull up while wiggling them and they pop off. It'd be pretty hard to break them so don't worry about that. You'll be able to see all the fine German engineering under there first hand.
-or-
Originally posted by Lynn
We have also been told that they suck out the oil to avoid damage to the oil pan drain plug threads.
Don't know if this is true or just BS, but the mechanic there told me that Daimler/Chrysler is using very thin metal on their oil pans and they are subject to stripping, because the threads a cut very shallow (ie, not "full cut" threads). It costs about $100 to replace the oil pan and plug on the minivan... I shudder to think what it would cost on an MB.
So, if there is any truth to what Lynn has heard about siphoning the oil to avoid drain plug thread damage, then I think that "clue" is another reason to buy a siphon if you must change the oil yourself.
Yeah, I had the same thing on my crx. Jiffy Lube finally stripped my plug. Serves me right for not taking ten minutes to do it myself. Cost a couple of hundred for a new pan. Damn!
avlis,
Didn't you take a lot of photos of your engine with the covers off? Is there a thread that shows them all? I meant to copy the photos for future use but forgot.
Thanks,
Andy
Thanks,
Andy
2008 VW GTI
There are pictures in my album. You'll have to sift through to find what you're looking for.
http://www.imagestation.com/album/pi...?id=4292046119
BTW: the site is down as of right now...but, your results may vary....
2002 C230k
Originally posted by MB-BOB
snip
snip
1 Post
1997 Toyota Tacoma 4x4
If you use the suction device on any 4-cylinder Kompressor motor, be sure to pinch off the rubber hose that connects to the dipstick tube, or nothing will get sucked out.
2002 C230K
Hello all, Have any of you tried this oil extractor device sold by Griot's Garage? https://www.griotsgarage.com/search....=29&search.y=8
The cost is $69.95 + shipping.
