View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Old May 29, 2003 | 02:01 AM
  #951
dvyan's Avatar
c230 sport coupe
the width is 9.5 in the rear, so will it fit
Old Jun 4, 2003 | 03:02 PM
  #952
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
How many miles on stock Michelin 16" tires?
We've got about 25K on our's and the dealer said they need replacing
I realize driving style has alot to do with it, but I expected more. Anyone have more than 25K miles on their stock 16" Michelin's?
Old Jun 4, 2003 | 04:39 PM
  #953
hobie's Avatar
'02 C230K
I lasted about 15K before I could no longer stand the squealing of the MXVs. The tires look as though they will last indefinitely. They're in my garage, cheap.
Old Jun 4, 2003 | 07:50 PM
  #954
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Do the *penny test* yourself. Then make up your own mind. You know about them stealers, don't you?
Old Jun 4, 2003 | 09:39 PM
  #955
.elijah.'s Avatar
W203
My first set...
I had the Michelin Pilot Sport HX on the 16" via the 2002 sport package. They lasted me with tire rotations and stuff, about 35K. I could have gone longer but I went to Mammoth and burned out my tire on some pieces of wood and cardboard trying to get out of the snow. So i have two shot tires, and two alright condition ones. I then just went ahead and got 18's with Yokohama AVS db.
Old Jun 4, 2003 | 09:45 PM
  #956
steffen's Avatar
MB C230K
Wow - only 25k on the stock 16" tires? These are the regular, non-performance kind, right? I'd expect about 50k out of regular run-of-the-mill tires.
Or I guess they're "luxury tires" with shorter treadlife?
--Steffen
Old Jun 4, 2003 | 09:54 PM
  #957
jay's Avatar
jay
2002 C230K Sports Coupe
Hmmmmm?
I just passed 44K miles. Yeah, I drive a lot, and it's all highway. Does highway travel cause less tire waer? There's still a lot of tread left too......
Old Jun 8, 2003 | 08:27 PM
  #958
aerodragon's Avatar
Flat Tire Help....
guys,
my tire hit a nail and it was leaking, what do you suggest to do?
I took it to the nearest tire shop and the guy plugged the hole with some kind of rubber and he claimed it will last for the life of tire. (no need to replace).
I have Service B scheduled for tomorrow actually. Is it safe to drive it? (at least 0.5 hr away from my home)
Also, should I have it replaced at the dealership? If so, how much does it cost usually (16" standard) and do I have to replace the other side too? (for balancing purpose)
please let me know...thanks
Old Jun 8, 2003 | 08:31 PM
  #959
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
it should be fine as long as it's not on the sidewall
Old Jun 8, 2003 | 08:33 PM
  #960
aerodragon's Avatar
thanks.for the info..
you meant sidewall is where the 'brand and size" shown?
Old Jun 8, 2003 | 10:03 PM
  #961
Matt230K's Avatar
2010 C300 4matic
Yes, that is the sidewall. As long as the hole was on the tread and not on the sidewall, you have nothing to worry about. Plugging the hole works very good.
Old Jun 8, 2003 | 10:58 PM
  #962
aerodragon's Avatar
thanks...for the info.
Old Jul 25, 2003 | 11:32 PM
  #963
b4chow's Avatar
how wide of tire size with 18X8
i'm running the same set-up on my rims right now, 235/20/18. just wonderin how wide i can run in the rear to run a staggered on carlsson 18X8s.
Old Jul 26, 2003 | 01:01 AM
  #964
BrabusCClass's Avatar
GL450, Sienna SE
Re: how wide of tire size with 18X8
I hope you mean you run 235/40/18 not 20. I dont even think they make 235/20/18.
Anyways, i dont think it would look too staggered. I dont recommend it. It might actually just look funny because your rim is the same size all around. If you had custom rims with custom offsets then you can get away with it. Also, I dont recommend anything bigger than 245 on a 8" width rim and thats pushing it.
Old Jul 26, 2003 | 01:51 AM
  #965
b4chow's Avatar
not 20, i meant 40... sorrie
Old Jul 26, 2003 | 01:55 AM
  #966
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I say maybe 255 from some brand. One of my friends that has the 99 SLK230 sport managed to put 245/40 on his stock 17x7.5 front rims.
Old Jul 26, 2003 | 06:15 PM
  #967
BruNo's Avatar
07' ML350
yeah..i want to run staggered too in my 18x8 rims with 225/40r18 all around but i dont think its a logical idea since d rims r d same width. b4chow, wat about if we just put on rear 10mm or 15mm spacers? would it look good???
Old Jul 26, 2003 | 09:36 PM
  #968
b4chow's Avatar
if i put spacers, i'm scared my rears will rub with my fenders... i have the cupkit and there is a little tire tuck right now, besides i don't like the spacer look....
Old Jul 26, 2003 | 11:34 PM
  #969
KWiK's Avatar
2002 C230 : 2007 C230
Originally posted by BruNo
...but i dont think its a logical idea since d rims r d same width. b4chow, wat about if we just put on rear 10mm or 15mm spacers? would it look good???
This would be a much better choice than different size rubber on the same size wheels. It would also allow you to still rotate your tires while still having the staggered look
Old Aug 2, 2003 | 11:02 PM
  #970
kimchiFLAVA's Avatar
2005 Porsche Boxster 987
can these tires fit on a c class?
BRIDGESTONE POTENZA S03 18 IN TIRES Four max performance 18" tires 245/45/ZR18
can this fit on my c240?
i am working in a deal for those tires and 4 carlsson 2 peice 5 spoke rims.
but i guess theres no point if they cant fit on my benz since it was fitted on a s class before
Old Aug 3, 2003 | 12:15 AM
  #971
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
kimchi,
I'm sure the TIRES will fit; but I think the bolt depth is deeper on a S Class. Search around in Wheels, Tires, Suspension & Brakes
Old Aug 3, 2003 | 04:24 AM
  #972
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
S-class rims won't fit on the C-class...you can pass on the deal.
Old Aug 3, 2003 | 06:40 AM
  #973
S_kLaSse's Avatar
300E
I dont recommend 245 for front. go with 235.
Old Aug 4, 2003 | 06:37 PM
  #974
the rims will fit the c class i was told but the guy wasnt sure if the tires would fit my car.
Old Aug 4, 2003 | 08:43 PM
  #975
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the tires will fit, but no recommanded for the front. The S-class rims has different offset than the C-class. You might want to ask BEN/Mach430 from Evosport.
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
