7 speed tranmission Jerk
If this does not fix it then it could be the speed sensor/electrohydraulic valve body problem that some have experienced. It's hit & miss on that and the only cure is a complete new valve body assembly. Good luck!
They say it's fine and that's how the transmission is...bs
They say it's because of adaptations and it's normal....bs
Don't fall for their excuses or I should says BS.
Also, why did you have to pay $125 when your car is under warranty?
You have a 2007, so you should have the updated valve body, but likely have outdated software. Just tell them flat out, you want the latest software for the ECM and TCM.
