Best Repair Manual & Starter Replacement
Now while I do almost all of my own repairs on everything I own thats mechanical, this car is a ball of fun to work on to say the least. I have not even located the starter motor on this thing! LOL
Anyone here replace their own starter in a V6 C240 4Matic?
Any help will be greatly appreciated.
Also, does anyone know which side of the engine the starter is on in a 2003 C240 4Matic?
On a M271 engine it is on the left side and you will have to remove the steering gear coupler
I will let you know how it goes.
That's how I'm running it now. Did you install XP Mode and then Virtual PC?
XP mode, which opens a virtual PC>
Unfortunately I don't believe it's compatible with the
lesser versions of Windows 7. According to this chart on
Wikipedia, you have to have at least 7 pro.
http://en.wikipedia.org/wiki/Windows_7_editions
The cost of the DVD manuals are 70 from 18004mercedes ?
I forget the ph # , but it's MBUSA.
I use it to run legacy apps.
It works!
If you use it, you need to install your 32 bit apps into the virtual machine.
So, in this case, disable autorun, so it doesn't try to open in win 7,
then open it from the XP virtual machine.
