Help!! rear wheel clicking noise
Old Jun 9, 2011 | 10:53 PM
aw9550w203's Avatar
c320
Unhappy Help!! rear wheel clicking noise
hey guys i hv a c320 01...recently i installed some lenso ls21...18 inch wheels... now first when i tried to install it i put the wheels on and after installing the car wouldnt move so realized the lug bolt was too long so went to belle tire and had them install it after orderin shorter lug bolts finally after 3 days it worked..but problems continued...first day after i got back from work the rear wheel started making this grinding noise so i took it back to belle tire they fixed it said they had to re essmable my parkin break...its driving fine now...but every time i go over a pothole or un even road pavements...it makes this clicking noise coming from my rear driver side wheel....took it back to belle tire told me to come back saturday..so wondering if anyone had the same issue or would kno what it is....thank you any help would b much appreciated!!!...
Old Jun 10, 2011 | 10:10 AM
Glyn M Ruck's Avatar
Super Moderator
This is common on the rear with wrong bolts. Something is damaged in the parking brake mechanism. Might be something as simple as a loose spring. Inspect & correct.
Old Jun 10, 2011 | 11:22 AM
JJSBENZ's Avatar
C230 Sport
It sounds like your bolts maybe are still too long or your wheel is hitting the fasteners that hold your fender lining.
Old Jun 10, 2011 | 01:55 PM
Silver C's Avatar
C240
I am having almost the same problem right now, though it sounds more like a i have a bolt loose and its making a clicking sound thingy..
Old Jun 10, 2011 | 02:33 PM
aw9550w203's Avatar
c320
well i m preety sure the bolts not too long...cuz it doesnt make the noise on the right wheel only the driver side wheel...so may b something went wrong on the parking break from previously installing wrong bolt...i m goin to belletire 2moro if not den benz dealer after will keep u guys updated thank u!!!
Old Jun 10, 2011 | 02:36 PM
aw9550w203's Avatar
c320
silver c if you find out anything regarding this metter please keep me posted i will do the same
Old Jun 16, 2011 | 12:25 AM
aw9550w203's Avatar
c320
alright so parking break hardware was missing belle tire installed it and problem solved....thanks guys for helping!
Old Jun 16, 2011 | 10:22 AM
Super Moderator
Pleased it's fixed!
