Rears Collect more Dust/Dirt?
2007 c230
I have the 2007 C230 stagger wheel setup... I've always noticed that the rear wheels collect an excersive amount of brake dust then the front. I know you use 70 percent of your brakes in the front more then in the back but is that common to have more dust in the back? At first I thought it was because the wheels are a lot bigger. But maybe they used two different style pads in the front and in the rear?
06 C230 SS 6spd
fronts use to have more than the rears on mine as well. Just buy some brake cleaner and spray it down. Have you done a brake pad change on them? or have they been done before? If not I'd recommend getting some Akebono pads from tirerack. Minimal to no brake dust at all and has the stopping power as the OEM pads, hands down my favorite pads for these cars.
Nowhere ...Fast
rear pads are probably cheap metalic and are getting down to nothing...i noticed that with aged cheap metallic that towards the end of their life they seem to dust like a ****...but otherwise there should be barely any dust coming from rears...get some ceramics in there...good stuff!
05.C230K.SS
Recent one has been the Armor All Wheel Protectant. Other people over here have used the more popular Sonax wheel cleaners. I have never tried any of them, but i think either one will do the trick.
06 C230 SS 6spd
those are wheels cleaners... i'm talking about brake cleaners, i just use the cheap Oreilys brake cleaner, works great. Your auto store should sell brake cleaner.
I spray down my rotors and calipers with it before and after I do brake pads or whenever I touch the rotors so I dont leave an residue of grease or oil on it.
![](http://dutchtouchcarpetservice.com/wp-content/uploads/2010/05/brake_cleaner.gif)
Audi A4 Quattro 2013
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
06 C230 SS 6spd
no they have a straw that attaches to the spray nozzle so you just point the straw at the rotors and calipers. It wont do any damage to the wheels. I've sprayed the lip of my wheels to get some brake dust off before. Its a quick and fast way to clean the wheels from the dust, then just spray it down with water to wash all the loosen debris the spray knocked off.
2007 c230
when I bought the car I knew the front pads were done but the rears didnt need them at the time... So probably they used some good quality ones in the front and some cheap ones in the rear.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
If OE - Benz did have a batch of OE rear pads that were faulty. Mainly effected W204 but also some 203. They made a real mess in the rear.
Super Moderator
Here is one of many W204 threads on the issue.
https://mbworld.org/forums/c-class-w...ear+brake+dust
2004 C240 4Matic
My front wheels were starting to look bad, was down in Manassas with my daughter for indoor bounce fun and before we went, stopped at the self serv car wash with high power water, and power blasted the dust from my rims, they are not perfect, but look much better than they did before.
Have you checked brake fluid?
If the sagent Glyn tip does not work I have seen cars that were had bad brake seals and leaking brake fluids that had nasty dirt in one or more wheels.
