How do I turn on my fog lights
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
2003 C230 sedan.
I can't seem to figure out how to turn on my fog lights. Am I missing a switch or something?
2004 C240 4Matic
If you pull out once, it will turn on your front fog lights, if you pull it out two clicks, it will turn on your rear fog light as well. FYI, only one light comes on in the rear for the rear foglight.
02 c230k coupe
Geez I figured it was something simple like that.
Thanks.
Thanks.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
2004 C240 4Matic
Took me a while to figure it out. After I turned on the front, and pulled it out again, I saw it turned something else on, and had no idea it had rear fog lights.
Also, I do not think you can turn the fog lights on from auto, you need to turn the *** all the way to the right then pull out. I am not at my car so I can not verify for sure.
Please don't use the rear foglight unless it's actually foggy out. It is far too bright for a clear night and will blind drivers behind you.
Super Moderator
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
If all else fails, read the manual! I think that is why they include one with the car. You would be amazed what you will find
Super Moderator
1 Post
2005 c230 S.S.
https://mbworld.org/forums/c-class-w...og-lights.html
https://mbworld.org/forums/c-class-w...eadlights.html
