Foot Brake Ratchet replacement
Rating: Thread Rating: 3 votes, 5.00 average.
Old Sep 2, 2011 | 04:45 AM
selwyng's Avatar
2001 w203 C180
Hi Guys
Does anyone know how to replace the ratchet on the foot brake (hand brake). How difficult is it?
Mine does not make the clicking sound anymore.
I have a 2001 W203 C180
Old Sep 2, 2011 | 11:25 AM
Glyn M Ruck's Avatar
Super Moderator
I doubt that the rachet needs replacement. At worst a spring. It's not difficult to access. I suggest you lubricate everything before taking it apart. This should include the cable transfer bar under the rear seat center hatch.
Old Sep 2, 2011 | 06:02 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Mine broke too, a piece of plastic fell out,
it doesn't ratchet but it holds just fine, so fuggetaboutit!
Old Sep 2, 2011 | 10:12 PM
mleskovar's Avatar
'17 Jaguar XF
Same here.
Old Sep 3, 2011 | 11:04 AM
Super Moderator
Is it part no 60 in the diagram that breaks on early cars? If so that is a very easy replacement. You certainly dont have to replace the assembly.
Old Sep 7, 2011 | 03:19 AM
selwyng's Avatar
2001 w203 C180
Thanks Glyn M Ruck for the reply!
It was part 60 and 70 of your diagram that i needed to replace. I now have my ratchet sound back!! thank you!
Old Sep 7, 2011 | 11:35 AM
Super Moderator
Pleased it's fixed - thank you for letting us know!
Old Sep 7, 2011 | 07:21 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Hmmm, this happenned to me a while ago (lost the rachet sound but the foot brake still works). Easy replacement? I'll have to stick my head under the dash when I get home tonight... +1 on thanks for letting us know the resolution and how you fixed it!
Old Feb 24, 2014 | 05:04 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
:Bump:
Question: Does not having the ratchet sound affect the engagement and release of the parking brake?
Thanks!
Old Feb 24, 2014 | 05:15 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by TruTaing
...Question: Does not having the ratchet sound affect the engagement and release of the parking brake?...
It didn't on mine.
Old Feb 25, 2014 | 12:59 PM
selwyng's Avatar
2001 w203 C180
:Bump:
Thanks!
It does not affect the engagement or release of the parking brake..
The reason why i replaced the ratchet was to give me an indication of how deep i should press the parking brake. The clicks give me an indication of that
Old Sep 29, 2015 | 05:34 AM
lisas800's Avatar
c180K se coupe
Sorry for jumping this thread but does anyone have the part number for the spring number 160? Cheers
Old Sep 29, 2015 | 06:36 AM
cm60k's Avatar
It should be "201 423 05 92"..
ZAYED,,
Old Sep 29, 2015 | 06:37 PM
wvadam's Avatar
C230 COUPE 2003 M271
Attachment 316844
ZAYED,,
damnit I wish I had that part # 3 months ago. stupid hook on the end snapped off and I ordered the whole rear hardware kit.
Old Feb 16, 2017 | 12:00 PM
Azeem's Avatar
W211 E270 cdi 2004
Do you know the part number for item 60 and 70 in the above diagram.
My w211 lost the clicking sound when i apply the parking brake.
Old Aug 5, 2018 | 07:15 PM
wanderlust360's Avatar
2003 C230 Sedan Manual
I lost the clicking sound on my parking brake as well, but not sure if any parts are actually broken. I had a mechanic adjust the release tension of the brake, and wonder if he just did not put everything back together properly The black pin #70 is still in place, and the white round plastic piece #60 does not appear broken to me. I tried but could not figure out exactly how to push it back into place... Can anyone tell if #60 is broken or not by the pictures?
Old Aug 8, 2018 | 06:16 AM
Azeem's Avatar
W211 E270 cdi 2004
parking brake illustration
I can't seem to upload illustration.
Old Aug 8, 2018 | 06:18 AM
Azeem's Avatar
W211 E270 cdi 2004
Old Sep 5, 2021 | 06:38 AM
nikobland's Avatar
w203
Hi,
Would really appreciate any idea of the part number of item 60 in @Glyn M Ruck 's post way back on 9.2.2011 please! I'm having some issues with the handbrake not locking - gradually eliminating issues and part 60 is definitely worn.
Thanks,
Nikolas
Old Sep 6, 2021 | 03:13 PM
Russell Ormerod's Avatar
not a merc
Item 60 is ONLY there to give a sound effect of a ratchet and has nothing at all to to do with the brake holding.
Old Sep 7, 2021 | 04:31 AM
nikobland's Avatar
w203
Thanks very much Russell! I think this leads to two questions from me, again any help appreciated!
  1. Would still be good to get the clicking, in which case it would still be really good to understand if that part is orderable separately.
  2. If item 60 is not the cause of the handbrake not engaging, what could be causing this? The mechanism under the rear seat works fine, the pedal simply does not 'stick'. Would it be likely that the complete pedal assembly needs replacing?
Thanks again.
Old Sep 7, 2021 | 11:04 AM
not a merc
Yes you can order it separately. Can't recall that I have had a mechanism fail. But what you must check is that the release cable has enough freeway at the mechanism otherwise it will not hold
Old Apr 18, 2022 | 10:29 AM
efzauner's Avatar
2005 C240 2011 R350
Thanks for this
Seems my old links on MB parts catalog is no longer working
I need part 210 the spring is broken. Do you know the part number?
Do you have a working parts catalog lookup? I could find all the cables and pedal but not the part under the rear seats that splits the cable into left and right rear.
thanks
Old Apr 18, 2022 | 11:05 AM
efzauner's Avatar
2005 C240 2011 R350
Found it Parking Brake Tensioner A2034200438
easy to find online
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
