Coolant leak.. $3000+ job??
We have recently gotten low coolant warnings, bought zerex and topped it up and the warning would eventually come back (within the month).
Pop the hood and there was less coolant and had to be topped up. The weird part is that there is no coolant on the ground on the driveway ever. So we just keep a bottle of Zerex in the trunk and top up whenever we need to.
Took it to a few different shops and they all said the same thing, something about a gasket that wuold cost $4000+ to replace.
Took it to our local/family mechanic and he raised the car and removed some sort of plastic housing from the engine and there was a bunch of coolant in it that just poured out. I guess there was no leaks on the ground because the plastic was holding it in. He also said it was a gasket issue and said he would help us out but it would be about $3000 (always helps us with prices) and looked the labour time up and it read about 10-12 hours.
Has anyone heard of this issue? I just called to confirm was he said, and he said it was clear to see the head gasket is leaking, and he will take another look to see if there is anything else.
Would a head gasket leak cause the coolant to be leaking gradually? There is no other issue with the car as far as its actual ride.
Also is a head gasket this time of price to fix?
(Canada)
Thank you
You have an '02 so I wouldn't think a head gasket on the I-4 would be a major job. Unless the car has overheated, then they may need to machine the surfaces flat if the head warped.
I'd be looking for a hose leak somewhere. I think there is even a way to use a blacklight with dye or something to spot a leak.
The first mechanic to mention the gasket issue said the same thing.. its weird that it happened to the car with just 120km on it
Might give you a better idea about where to look for possible external leaks.
One is to check for milky residue under the oil filler cap. That indicates that there is coolant in the oil.
I had this happen on an old Toyota, and smoke screened people on the road getting to the shop.
Something like Steel Seal?
This 3 grand will hurt
edit:
I wonder if I should give this a shot in the mean time? ..
http://www.canadiantire.ca/AST/browse/4/Auto/AutoRepairAccessories/SpecialtyRepair/PRDOVR~0380847P/Rislone+Head+Gasket+Fix.jsp?locale=en
The reviews are good on it, and it says its compatible with aluminum heads.
the actual product website - http://www.rislone.ca/31111.htm
Do you think its worth the $40?
Use it, top off the coolant, and then monitor the level of the coolant over the next month or two?
If the coolant isnt decreasing like it has been, then its worked, even temporarily . If its still decreasing then we will do the repair?
It wont hurt to try it out, right
There is also one that is cheaper and more specific here that says its aluminum-
http://www.canadiantire.ca/AST/browse/4/Auto/3/AutoFluidsChemicals/EngineTreatments/PRD~0380845P/Rislone+Liquid+Aluminum+Cooling+System%2BRadiator+ Stop+Leak.jsp?locale=en
manufacturer page for it - http://www.rislone.ca/31186.htm
Its $10
I think the $40 might be more worth while between those two
The fix for a blown head gasket, is to replace the head gasket, don't use band aid fixes as water does not compress and can lead to a major catastrophic failure, that ultimately can be well beyond the $3k that you are looking at currently.
The other alternative is to trade it in for a new car. Top up the coolant and hope the dealership doesn't notice. I don't recommend this approach, yet if you're tight on cash this could be an option worth pursuing.
I agree with others that the repair shouldn't be $3K, find a cheaper independent mechanic. It should be < 10 hrs to remove the head and the same to replace it, so even at $100/hr you're < $2K. The only way it'll cost more if is the block is warped. Even if the head is warped and needs machining it shouldn't cost $3K.
How much is the part alone?
The lower quote of $3000 was my family mechanic and he lowers the labour to about $65 for us.
edit :
Is one of these the part?
http://www.ebay.ca/itm/OEM-Mercedes-...item23125f0623
http://www.ebay.ca/itm/Victor-Reinz-...item43a9be891a
http://www.autopartswarehouse.com/sk...3-1618459.html
Does the gasket itself HAVE to be bought from MB? Would one of those ebay OEM ones be just as good?
If so, I could just order the part myself, give it to him, and only pay the labour?
$3000 is high for head gasket replacement. It's is presumably due to high US/Canada labour rates.
