Something exploded under my hood
Last night I was leaving Safeway, I turned on my car and my engine made a little different of a start up sound but it didn't sound too weird so I didn't think anything of it. As I turned out of the parking spot my stearing wheel felt really hard and weird to turn, it kind of felt like a flat. So I went a few more feet and then pulled into a spot. Once I got out I saw a huge trail of oil from the spot I was parked at originally to the spot on the other side of the lot were I was parked, the rest pored out into a huge puddle of oil under the new spot that I was at. I popped my hood and there was oil splattered everywhere and even dripping out from the sides and out my bumper.
I had the car towed to my MB dealership but this all happend late at night so I still haven't talked to MB about diognosticing it or doing anything to it so I can still change were I take it.
The car was recently involved in a accsident were a sign was hit and the sign ended up breaking parts under my car that I had replaced including the radiator and the car did over heat in that acsident. I was wondering if issue could be related to the previous accsident
Any recommendations for a good Indy in the sf Bay Area would be appreciated
Anyone ever hear of a similar issue ?
Any help or tips are appreciated
Also sorry for any typos or mistakes in this, I am typing it all from my Iphone at work
Thanks in advanced
How's the coolant level? Any mixing of the coolant and oil? I'm guessing a seal was ripped in the prior accident.
Your iphone doesn't have autocorrect?
I didn't get a chance to check the coolant level and now the cars at the dealership
I just called mb of Fremont and told them to go ahead with the diagnostic so I can at-least find out what the issue is and work from there.
I'm not sure what your referring to by the seal, but in the acsident something did break that caused all the coolant to leak out
1. photo - power steering reservoir (between coolant reservoir and gold coloured cap) right in the middle of oil leak
2. your hard to turn like driving with flat tire is describing problem of lost of power steering,... when that's gone, you need lots of upper body strength just to turn the steering wheel so the car can do a normal turn.
BTW, why is there tin foil wrapped around rubber hose between coolant reservoir and power steering reservoir?
As for the tin foil I have no clue, I haven't really touched anything under the hood other then the air filters since I bought the car
Maybe Peydidy can check if his (formerly Jordan's) coupe has it,...
But why would Mercedes add a aluminum tin foil around that hose? Maybe it's because they had problems with that hose being close to the engine exhaust header,... notice all the heat shield in the area,.... maybe excess heat would cause that hose to become brittle and crack sooner than expected (never heard about any problem with that particular hose),... so they added the aluminum tin foil around that hose to deflect the heat from the engine exhaust header,....
So I just got a call from my SA and he said it was transmission related and all the fluid everywhere wasn't engine oil it was transmission fluid. He said all the fluid is gone so its basically like I am getting a transmission flush out of it too haha. It is soposed to come out to $800 for them to clean it all up, add transmission fluid, and fix what ever the issue was. I still don't get what caused the fluid to go everywhere or how it happened, I will report back tomorrow when I get the car back and have more information on the whole thing, I got the call while I was at work so I wasn't able to talk to my SA more about what the issue was.
I was expecting a lot worst so I am glad it wasn't anything too crazy
So I just got another call from my SA
He said that they repaired it, cleaned it all up and topped off the fluids. He said that once they had it all ready to go they took it out for a test drive to make sure everything good and it exploded everywhere again. He said they tried repairing it again and the same thing happened.
Then they had one of there guys take a closer look at it and realized that it was because the radiator was causing it to over heat and explode.
My radiator was damaged in my recent accident but the insurance would only pay for an aftermarket one which cost around $200-$300. So I had an aftermarket put on at the time of repair.
The dealership is also saying that any aftermarket radiator will cause the same issue to happen and that I need to get an OEM one which they charge $1000 for.
I called the shop that I had my work done at and they said they would not be held responsible because the issue has to do with the replaced part not the install that they did.
EDIT: Behr has a factory here for supply to Benz, VAG & BMW. We have a weak currency so prices are good!
First don't ever go to the dealership they are a joke in the bay area. And they mark up the parts HUGE. Always go to peninsula mercedes "http://www.peninsulamercedes.com/". Nick is the owner and the mechanic. He's smart and doesn't mess around. One drawback is he has a waiting list and he only works on 2-3 cars a day. He does buy his parts from a dealership so that is a bummer. BUT if you get on his good side, like I did. Then you can bring in your own parts. However they can only be OE mercedes parts. Which is fine.. which brings me to my second point.
Secondly order your radiator from getmercedesparts. Its $210! This is one main reason why I don't miss the bay area. They mark everything up to make more money on people who don't know. get Mercedes parts is a DEALERSHIP based out of NY.. so yeah it takes some time to get the parts. And yeah the guy who runs it ls like 70 and if he reply's to your email. A) you're lucky.. he's not very good with computer. B) its all in caps. But their prices are fair and you only pay shipping.
Hope everything works out for you man. Don't sell the car because of this... its a very minor speed bump. Just take it to Nick and get it sorted out proper.
