Phone system part numbers
Old Aug 10, 2003 | 07:28 AM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
I found a local yard parting out a wrecked 2002 C Class...selling the phone components. The dealer tells me the 02 model year was available with either the TimePort or v60, depending on the manufacturing date. He's not sure what phone it was for and doesnt have the handset, but I'm looking for the v60.
Can anyone please verify the part numbers for the v60 cradle, fiber optic control unit, f/o cables, bumper antenna, PSE box and Voice Rec boxes for the v60 coupe option?
(I think that covers it all...if not, please advise)
Old Aug 10, 2003 | 10:19 AM
Lynn's Avatar
Rick, the V60 and Timeport are significantly different in size and shape. If your V60 fits the cradle, it should be for a V60. I don't think you could stuff a Timeport into a V60 cradle.
Old Aug 10, 2003 | 10:30 AM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Re: Phone system part numbers
Can you tell me which yard? I need some spare parts and I am in central NJ.
Erik
Old Aug 10, 2003 | 01:03 PM
Rick's Avatar
Lynn....thanks. I'm looking to set up a v60 and want to make sure the wrecked car's parts will work. The local dealer said there are 2 types of phone, the junk guy has no idea which phone this was, since he doesn't have the handset.
Erik....check your e-mail.
Thanks guys.
Old Aug 11, 2003 | 10:58 AM
breastroker's Avatar
2003 C230 K , 2001 ML320
Ask the shop if they will part out the wood from the center console?
Old Aug 11, 2003 | 01:19 PM
c class 279's Avatar
M
Rick
Can you PLEASE do me a huge favor? Would you get the metal spring clip out of the H7 (low beam) bulb/housing on that junked C-class! I cannot get one anywhere and you can't order it as a seperate part! PLEASE! THanks!
Old Aug 11, 2003 | 02:13 PM
awiner's Avatar
2003 CL55 AMG
Vehicle Type CL203 (With Tele Aid)
MBUSA Part Number
Kit Description Q6820714
VEHICLE COMPLETER KIT Q6820577
OPTIONAL VR KIT
Components MBUSA P/N MBUSA P/N
VR MODULE -- Q6820650
CABLE PSE/COMPSTR Q6820468 --
BRKT, VR MODULE -- Q6820654
BRKT PSE/COMPEN/ANTSW Q6820655 --
PTT LEVER -- Q6820651
ANTENNA SWITCH (DUAL BAND) Q6820652 --
TEMPLATE, V60 HOLDER INSTALL Q6820762 --
TEMPLATE, TIMEPORT HOLDER INSTALL Q6820763 --
MANUAL, VR -- S-2765-000
Vehicle Type CL203 (Without Tele Aid)
MBUSA Part Number
OPTIONAL VR KIT
Vehicle Type S203
MBUSA Part Number
Kit Description Q6820713
OPTIONAL VR KIT
CABLE, COAX (S203 ONLY) Q6820702 --
BRKT PSE/COMPEN/ANTSW Q6820656 --
Vehicle Type W203
MBUSA Part Number
Kit Description Q6820712
OPTIONAL VR KIT
BRKT PSE/COMPEN/ANTSW Q6820653 --
Old Aug 11, 2003 | 10:16 PM
lars's Avatar
05 CLK 500 cab
Umm.. I think I read somewhere that one of the reasons the MB phones were so expensive was that the handset had a non-standard circuit board, meaning that a normal V60 would not be fully integrated with the steering wheel buttons and the audio. Does someone know if that's right?
Old Aug 11, 2003 | 11:20 PM
Lynn's Avatar
That is essentially correct. I don't know if the circuit board is different, but the firmware is.
