transmission problem c230
Old Nov 13, 2013 | 09:11 PM
gulf039's Avatar
c230
Hello.. i have a 2005 c230 with only 66, 000 miles.. but i have problems in transmission.. (automatic).. runs good but gear #3 has a vibration.. only gear #3.. please help.. thanks
Old Nov 13, 2013 | 11:19 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
Is your whole car shaking while in 3rd gear? Does it only happen under accelleration? Under load?
Old Nov 14, 2013 | 07:11 AM
gulf039's Avatar
c230
Thanks.. yes.. whole car... and happen under accelleretion and under load.. both..
Old Nov 14, 2013 | 02:29 PM
samaritrey's Avatar
Super Moderator
THE C350
What speed are you at in 3rd gear? Try to go same speed you notice it at in a higher/lower gear and see if you can recreate it. You may just notice it in 3rd gear because of the speed you are traveling.
Old Nov 14, 2013 | 02:34 PM
gulf039's Avatar
c230
High speed or lower speed i can feel the vibrarion.. when change de gear, the vibratuon its over.. its only in that gear.. thanks
Old Dec 24, 2013 | 12:40 AM
scottonfire's Avatar
2013 c250
Bump. I have same issue, possibly 2nd gear too in my automatic. When I hit the acceleration hard enough it smooths it out. From reading about vibrations, it seems like 2 engine mounts and transmission mount could need replacing, but these people seem to be vibrating in reverse or at a stop light. Neither of which causes vibrations in my car, only in 2nd/3rd gear when going soft on the accelaration. Anyone confirm or deny 3 motor mount theory?
Old Dec 24, 2013 | 07:32 AM
Glyn M Ruck's Avatar
Super Moderator
Check:
Engine mountings & rear transmission mount
Center propshaft bearing
Propshaft flex discs for cracks
Propshaft UJ's
Grease propshaft spline
If the vibration is truly caused by 3rd speed in the transmission only, you are in for a failure & soon. I doubt it is the transmission. When last did it have a fluid & filter change.
Old Dec 24, 2013 | 07:59 AM
gulf039's Avatar
c230
Thanks all.. i will do..
Old Dec 24, 2013 | 09:45 AM
jkowtko's Avatar
2005 c230SS
(Glyn asked) ... when did you last change the transmission fluid and filter?
