CEL w/ o2 Sensor, Replaced O2 and still throwing codes
Old May 6, 2014 | 01:37 AM
Monk's Avatar
C320
Had a CEL for a bit of time, so I decided to change both the front o2 sensors out with ones from on my '02 c320.
Went to
http://www.boschautoparts.com/Vehicl...artFinder.aspx
I bought this, Upstream Right:
Amazon Amazon
And then this, Upstream Left:
Amazon Amazon
Both part numbers are what Bosch recommends for my car. Took it to my local shop to have them change it out, as I needed them to look to see if I needed new control arms (which I do).
Once I replaced them, CEL was still on. Did a reset with a hand tool, then it came back on with P0134 and P0135 codes. Sometimes the car idles rough now. If I remember correctly, Bank I Sensor 1 is the passenger side (right) of the vehicle (cylinder 1 is on the 'left' side of the engine if you are looking at the car from the front)
Did I purchase the wrong o2 sensor? Or? It seems one of the sensors seems to work OK, but the other one is not working.
Old May 6, 2014 | 04:43 PM
Monk's Avatar
C320
bump.. anyone?
Old May 7, 2014 | 03:36 AM
cm60k's Avatar
While the sensor connect properly to the connector socket, it should be OK,
do you check if there is any leaks in the sensors area or cats joints..!??!
ZAYED,,
Old May 7, 2014 | 04:17 AM
Monk's Avatar
C320
ZAYED,,
I didn't think that affected my engine since it's the M112 based one?
When I take it back to the shop I'll have them look for it.
Old May 7, 2014 | 04:23 AM
cm60k's Avatar
I like M112, it's a great Engine, exactly the same of M113 platform,
Emission system is these Engines are little sensitive to the ECU, during to the EGR recycle,,
BTW; do you recently removed or change any of cats....??
ZAYED,,
Old May 7, 2014 | 05:41 AM
Monk's Avatar
C320
The cats have not been changed. The same code has existing for the right side of the engine before and after I've changed the o2 sensor
Old May 17, 2014 | 07:34 AM
Glyn M Ruck's Avatar
Super Moderator
P0134 = O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 = O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Your engine orientation is correct. Cyl one is bank one RHS bank from drivers seat.
You either have a dud sensor or a wiring/plug issue.
Old May 17, 2014 | 01:08 PM
Monk's Avatar
C320
Replaced o2 sensor again with
Mercedes-Benz Oxygen Sensor - BOSCH - 0258006167 / 16167 - NEW OEM MB O2
Bosch 0258006167 / 16167 - MB # 0015405017 - Direct Fit
Still throwing the same codes. Probably wiring harness from ECU to o2 plug?
Old May 17, 2014 | 01:18 PM
Super Moderator
Sounds that way I'm afraid. Clean up all plugs with switch cleaner.
Old May 17, 2014 | 01:37 PM
Monk's Avatar
C320
I've attempted to look on EPC for the wiring part numbers (from o2 plug to engine ECU), just in case, but I cannot locate them.
