Mb w203 blinker problem
Old Sep 26, 2017 | 12:19 PM
alexyz's Avatar
mercedes benz w203
hey guys , i own a 2000 w203 and from a week or 2 i got a blinker issue.. more precise when i turn the signal to left the turn signal is clicking fast but the headlight does 2,3 blinks then stops for a couple of seconds. then again blinks 2 ,3 times ..and so one...i got that blink error in the car comp.. any advice some1?
Old Sep 26, 2017 | 04:29 PM
Russell Ormerod's Avatar
not a merc
Fast flashing means a bulb is bad
Old Sep 27, 2017 | 12:52 PM
alexyz's Avatar
mercedes benz w203
i changed the bulb 2 times + check and cleaned from corosion but still nothing changed...
Old Sep 27, 2017 | 03:04 PM
not a merc
Do all bulbs flash when using indicators? Wattage correct?
Old Sep 27, 2017 | 04:05 PM
alexyz's Avatar
mercedes benz w203
i ddnt had time to go at a service yet.. yes all bulbs are flashing . the problem apeared from the sky ..one day the blinker started doing that thing .... one friend of mine checked the fuses the cables... and all seems good...
Old Sep 29, 2017 | 06:53 AM
alexyz's Avatar
mercedes benz w203
"Russell Ormerod o all bulbs flash when using indicators? Wattage correct? "
all the bulbs are flashing . the only problem remain the left side blinker . when i use turn singal to the left the bulb blinks 1 2 times then stops for a few seconds . then blinks again ..its like hes losing power or smth like that...i dk what to say and what to do ... no one can figure this out
Old Sep 29, 2017 | 04:33 PM
not a merc
Left front or rear?
Old Oct 1, 2017 | 05:03 AM
alexyz's Avatar
mercedes benz w203
front left .
Old Oct 1, 2017 | 05:06 AM
alexyz's Avatar
mercedes benz w203
i went to a service and a guy disambled the sam all the way to the circuit board.. remaked that circuit board .. and he said the front left blinker has issue due to a small black Square ..(i dont know whats the name ) inscriptioned like this : bts728l2
Old Oct 1, 2017 | 12:22 PM
not a merc
Ok. Probably the FET driver for that lamp
Old Oct 11, 2017 | 07:57 AM
alexyz's Avatar
mercedes benz w203
There is no way i could fix this issue? i dont fiind that IC bts728l2 to buy and change.
