722.9 likely conductor plate issue, but no engine code?
I have an '07 with 70,000 kms and have been having some trans issues that seem indicative of the well known conductor plate issue I've read about on here. The thing is, I have had no check engine lights come on whatsoever, and in every other post I've seen on this there seems to be codes. Could this be something else? I finally brought it into the dealership for diagnosis today as it was jerking as well as feeling stuck in a gear or limp mode (turning it off and on again has fixed it every time), but I've been getting some hard shifts too, but never an engine light. Could this still be the conductor plate issue all things point to it being?
Also, if it is the conductor plate I'm questioning repairing it myself, as money is tight enough to warrant it (despite my usual desire to leave it in the hands of those that will take care of it the best). I found Circuit Board Medics and it looks promising, I read they do some soldering to fix it, but couldn't find details on the whole process. My father works in electrical and solders with radios all day anyways, is this something someone like him could take on? Literally the most in depth thing I've done in a car is spark plugs, but I have more knowledge than what I've actually used, and been wanting to wrench around a little more, and there seems to be great tutorials online for this issue that make it look straight forward enough to manage, should I go for it myself? I read also that I should use Mercedes' own transmission fluid rather than buying it from some shop, is this true?
Sorry if these have been answered before, I'm looking for some guidance and am stressing a little that it's gonna be alot of money whatever's going on.
According to my youtube video watching and google expertise, what i would do in your situation is take a clean pump + hose (for oil changes) to suck a cup of oil out to inspect it.. color and odor (black and burned = bad) to further investigate - drain as much oil as you can with the pump, and then remove the pan carefully (still some oil left in) and inspect the dirt in the pan - black clutch dust and some shimmering silver dust = normal but brass / copper coloured = bad, r.i.p transmission. The dealership will have to do this... but then they have the car on the lift.. 1 step away from replacing your plate... so will give you a call and guilt you into paying xyz to get it fixed there and then. 70k km is not much miles at all so thats really unfortunate.
Please correct my method of diagnosing the problem if its wrong !
$4,441.70 - Transmission Valve Body: Require to replace electro hydraulic valve body, defective speed sensors. (This would be the suspected conductor plate and the valve body in there right?)
$369.35 - Centrifuge cover: require to replace centrifuge cover due to leak.
$463.75 - Stabilizer links: require to replace RF stabilizer link, found link top rubber boot was cracked.
What should I do here, advice anyone, that's alot of money. Do you think if I took the conductor plate out brought it to them for repair, then put it back in myself to save on man hours, or just asked them for the parts to do it myself it would save much? I don't know really know what those other two are about, is that something doable by myself? Calling independent shops for quotes now...
722.9 Transmission valve body and tcu Control Unit Conductor Plate A 0034460310
I know nothing about the other 2 things.. are they related to the transmission? or just other parts on the vehicle
RF stabilizer link = anti roll bar drop link? (you can diy that)
centrifuge cover due to leak - sounds like an airplane phrase lol i'd need a better name to find it on google
well i found this thread , but for another model (cetrifuge cover)
https://mbworld.org/forums/c-class-w...separator.html
Yeah the RF stabilizer is just a anti roll bar link, super confident I could do that. That would be a cheap part too.
The Centrifuge cover says this on their detailed invoice: Item Description The Centrifuge Cover or Cap is used to contain the oil in the Centrifuge (Oil Separator) and provide access to clean and check the system.
The thread i linked above and this one cover it https://www.benzworld.org/threads/ce...1505037/page-2
You just need tools that will 'fit' : (again, have a look yourself first)
The valve body thing, with my limited experience i would also attempt that myself. As long as there are instructions/videos its just 'a few bolts' - the good thing is when you remove it, you can put the pan back on (catch any drips) and bring the valve body/conductor inside to swap over stuff... and then 'reverse order' with correct torque, not much at all , 8-9nm i believe
