DIY: Centrifuge Cover [Oil Separator]
Old Feb 28, 2017 | 07:59 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Hello everyone,
Here is a simple diy since there was not one present on the forums (not that it is very difficult, but for some direction). Also sorry for the large images.
Difficulty: 3/10
Time: Ranges from 20 to 50 minutes depending on experience...and if you accidentally drop stuff in engine bay
Dealer Cost: $300 DIY Cost: $15
INSTRUCTIONS:
Step 0: Purchase the Product
You can purchase Mercedes original or from some sponsors here on the forums. Usually they will be about ~$50. I decided to take one for the team and try the one for $15 and I'm 90% sure it is the original company but without the Mercedes badge. It is very good quality.
Here is the link:
Amazon Amazon
DIY: Centrifuge Cover [Oil Separator]-8bvqwkm.jpg
DIY: Centrifuge Cover [Oil Separator]-27qouty.jpg
Step 1: Remove Engine Covers
Reference this DIY: http://www.pelicanparts.com/techarti...er_Removal.htm
Step 2: Determine location of Centrifuge
It is in the back of the engine, near the dipstick. Far right circle.
DIY: Centrifuge Cover [Oil Separator]-gizccqe.jpg
Step 3: Remove Hose
Just pull the hose from it.
DIY: Centrifuge Cover [Oil Separator]-idzs0qw.jpg
Step 4: Remove Screws
Screws are E10 and 8mm or 5/16" socket can be used (thank you ItalianJoe1) count of 4.
Step 5: Remove Centrifuge
Step 6: Oil up new centrifuge at seals, remove cover plug, and replace.
Step 7: Put everything else back in its place.
That's pretty much it, no need for photos for those as they are self explanatory.
Congratulations!
*Disclaimer: I am not responsible for any damage you do to your car.*
Any questions let me know!
Old Feb 28, 2017 | 08:07 PM
ItalianJoe1's Avatar
2003 CL 600
Be sure to check the cam plugs at the back of the heads while you're in there, they often leak and are simply pop out-pop in, worth changing if there's any doubt.
Screws are E10, IIRC. Can use a 8mm or 5/16" socket, they aren't tight.
Old Feb 28, 2017 | 09:21 PM
Adi-Benz's Avatar
Correct thank you! I used 8mm.
Old Feb 28, 2017 | 09:54 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
Adi did you find a good transmission for your car?
Old Mar 1, 2017 | 08:14 AM
Adi-Benz's Avatar
Nope week 7 without using the car. I found a source to the bearings overseas but the only mechanic willing to open the trans is 'busy' so if anything the earliest is next monday. Being that even I know how to fix it theres no point in buying a new trans. In the end of this hopefully I'll have saved $ and have a sort of diy thing up since no one has done it (online). Transmission is fine though just the transfer case, but they are merged so dealer wants to sell entire package.
Old Mar 1, 2017 | 05:27 PM
Colin G's Avatar
2008 C-230 4Matic Sport
I find it very odd that transfer case bearings can't be serviced or at least that MB does not offer it and will just say buy a new transmission.
F that. Seems dumb to me and Canada is full of 4 Matics.
Was your transfer case fluid really low or very dirty? I'd like to know what causes the bearing to fail. I plan on getting my front transfer case fluid changed asap in the spring. Hopefully that will prevent mine from doing what yours did.
Old Mar 1, 2017 | 05:50 PM
Adi-Benz's Avatar
Theres no dipstick to check the fluid amount. From what I can tell it seems fine but its a bad design on MB's part; apparently oil doesn't get through the way its supposed to or something but no one has confirmed.
I believe I found this to be best priced service kit.
https://www.ecstuning.com/b-assemble...FVq4wAodv4wLAA
Old Mar 1, 2017 | 06:07 PM
MB Marko's Avatar
I hope you get it resolved!
Old Mar 1, 2017 | 07:47 PM
OrientBlau's Avatar
2011 C300 4MATIC
what were your symptoms that you determined you need new bearings in the TC?
Old Mar 1, 2017 | 07:48 PM
OrientBlau's Avatar
2011 C300 4MATIC
Hello everyone,
Difficulty: 3/10
Dealer Cost: $500 DIY Cost: $15
INSTRUCTIONS:
Here is the link: https://www.amazon.com/Mercedes-Benz...+oil+separator
Step 3: Remove Hose
Congratulations!
what symptoms led you to replace your oil separator?
DIY looks super easy. It is a bear in the BMW e46. Lots of parts to remove just to get to it... and then its a tight fit in and out. I managed it yrs ago but what a pain!
Old Mar 1, 2017 | 07:52 PM
2003 CL 600
Some people have tackled it themselves, but it's uncommon.
MB says you have to replace the unit, and the coupling between it and the trans is shimmed from factory, so if you change one piece you have to change both. If you just remove the same trans/transfer case and put it back on it's matching mate, it's fine.
https://mbworld.org/forums/e-class-w...long-read.html
I was trying to find another old thread with more info of actual rebuilding but I was unsuccessful. I'm sure it's on the forum somewhere, I've read it.
Old Mar 2, 2017 | 08:56 AM
Adi-Benz's Avatar
If you find anything it would be much appreciated. But I'm pretty sure I've read nearly everything related to it on the web so doubt I'll find any new info.
Old Mar 2, 2017 | 11:20 AM
amoffitt's Avatar
C350
Thanks Adi. I figured it would not be much work.
I had the dealer check where oil was leaking from and creating a burning oil smell, they instructed me that this was leaking and causing everything. Does that make sense? Has anyone else had to replace this because of this same symptom?
Old Mar 2, 2017 | 01:07 PM
Adi-Benz's Avatar
Yes, correct. I took my car in for a different reason but a few days earlier it started to leak. By that point I wasn't driving my car much but dealer analysis said this:
"...Completed inspection of vehicle found oil to be leaking from centrifuge cover on to cat causing burning smell."
Should update, dealer cost is actually $300.
Old Mar 2, 2017 | 01:10 PM
amoffitt's Avatar
C350
Gotcha, good to know. This is what I ordered:
http://www.ebay.com/itm/201450289119...%3AMEBIDX%3AIT
I suppose this will take care of both the centrifuge and the cam covers.
Old Mar 2, 2017 | 01:18 PM
Adi-Benz's Avatar
Sorry I missed some of your comments, they should be answered now.
As for the transfer case, at speeds of 60mph+ I could hear a faint high pitched whirr, speed dependent not rpm. Did some research and matched up transfer case issue. Also got it analyzed by 3 indy's and the dealer (only dealer charged). Got offers to swap trans with salvage cars, but it is still pricey and not a definite solution. Found that most likely issue in transfer case is bearings; should be easy for any trans mechanic.
I could go on but I don't wanna derail too much. I'll likely end up making a thread if I get it resolved.
Old Mar 6, 2017 | 03:52 PM
amoffitt's Avatar
C350
One question that came up. I understand where the two small camshaft covers go but where does the larger one go or have you guys not been replacing the larger one?
This is what the parts department at my dealership said:
"IT DOES NOT. ARE TECHS ALWAYS REPLACE THEM WHEN THERE IN THE FOR THE CENTIRFUGE COVER THE HAVE 2 SMALL ONES 0009985609 9.99 AND ONE LARGE ONE 000986590 7.99
WE KEEP THOSE IN STOCK"
That's the large one that I am referring to.
Old Mar 6, 2017 | 09:15 PM
Adi-Benz's Avatar
The people at the dealership need to learn some grammar.
I'll let italianjoe answer this as I didn't do them
Old Mar 6, 2017 | 10:32 PM
amoffitt's Avatar
C350
I just got in there and started to work on this tonight. Seems to be that my 2009 C350 has screws that hold that piece on T27 or so (Does this seem correct)? Anyway I used a T27 bit to remove 3 out of the 4. I got to the 4th and dropped the bit down in the engine bay. I wish I was able to use a socket, it would make things way easier but I can only use T27 bit. Is there any recommendation of tools to use to be able to do what my bit is doing since I cant get a full screw driver down in that area and my bit and wrench combo is a terrible method?
Old Mar 13, 2017 | 05:08 PM
amoffitt's Avatar
C350
**Update**
After looking more in depth the size is T30 on my car (2009 C350 Sport). Once I removed 4 T30 Screws with the bottom one behind the hardest, and installed the new piece my oil leak was resolved. Everything seems to be working well. I purchased Torx Keys from Home Depot (roughly $15) and used those to assist in removing the torx screws.
Thanks Adi-Benz for the write-up.
Old Mar 14, 2017 | 01:43 PM
Adi-Benz's Avatar
No problem, also sorry I totally missed your last comment, glad you got it figured out!
Old Jun 8, 2017 | 02:39 AM
brettysetgo's Avatar
2008 Mercedes-Benz C300 Sport 3.0L FLEX
Just replaced this part on my 2008 C300 Sport - wish I would have seen this tutorial first. My mechanic called it "Crankcase Cover", so my searches were all over the place. I went ahead and bought the OEM part on Amazon for $58 - I wasn't sure if the cheaper one for around $20 was legit. I take it that yours is still working?
Old Jun 8, 2017 | 08:53 AM
Adi-Benz's Avatar
Yes like a charm. I will have to leave a review on amazon to help others.
