DIY - setting up the AUX input for iPod, mp3 player, etc.
Rating: Thread Rating: 23 votes, 4.65 average.
Old 06-21-2008, 10:05 AM
  #501
kickR's Avatar
'14 CLA 45
Originally Posted by lilbabybenz
I really wanna do this, but, is it just my computer or are the pictures for the install gone? if they are, does anyone have them so that i can do this?
Any help would be GREATLY appreciated..
I got the same problem. But I was told by a moderator that the pictures are still there so I guess it had something to do with our computers? Even after clearing cache and cookies no result. I tried it on several different computers always with the same outcome. Maybe someone who can see them might be so kind to upload them again for us.
Old 06-21-2008, 01:46 PM
  #502
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Here you guys go, I've saved the first page in .pdf format so that you can get the pics...
File Type: pdf
Old 06-21-2008, 05:41 PM
  #503
kickR's Avatar
'14 CLA 45
thanks
Old 06-22-2008, 08:17 PM
  #504
lilbabybenz's Avatar
2005 C230 Kompressor
Thank You!!
I am going to ask the dealership tomorrow about the part.
Oh, does anyone know if there is anyway to have an AUX input that plays thru the bottom of the ipod, instead of the headphone jack? I broke the headphone jack and this could present a slight problem..
Old 06-23-2008, 12:44 PM
  #505
nuphan's Avatar
'06 C350 SS
Originally Posted by lapi
Finaly got it working!.
For those who still trying to figureout with the yellow thing on the A-piller.
Remove the screew using the torx driver head. Then pull the front part of the plastic thing. Now, the only parts holding the plastic should be the two yellow clamps. It is actually two 'E' shaped clamps. And the top line of the 'E' has a reversed 'c' attached at the end. The E is attached to the body(do not try to use screwdriver to pry the yellow thing apart). Now, try pulling the plastic towards the side (near one clamp). (towards your left side when you are sitting on the passenger seat, NOT to the rear of the car). You need to use some force, since the clamp is tightly holding the plastic thing.
If you need any assistance, please let me know!
Thanks.
That's cool! I was wondering how to work those yellow clamps and was afraid to pull them out. I need to order the cable and then try to do mine too.
Old 06-30-2008, 03:04 AM
  #506
so, apparently there is, or was in 2006, an ipod integration that plugged into the bottom of your ipod and you controlled it thru your lcd screen in your gauges? i was wondering if production had stopped or if there is still a product number? i kinda have to use this route of integration due to loss of the headphone jack on my ipod..
any help would be much appreciated. thanks
Old 06-30-2008, 03:44 AM
  #507
Super Moderator
nlpamg's Avatar
lol, there is still an ipod integration kit you can buy. you can ask at the dealership (and they'll charge you an arm and a leg for it and to install it) or you can try www.mbenznl.com
Old 06-30-2008, 03:55 AM
  #508
RDSBENZ's Avatar
C300. FJ Cruiser, 370Z
I went the safe route and had Steve (MBenzNL) install one for me today. I'm now able to hear music from my iPhone using the iPod Integration kit. It connects into the bottom of the iPhone (the same for the iPod). It will then ask you if you want to turn on the 'airplane mode'. Click 'NO' so you can still receive and make phone calls. Just press & hold the CDC button on your HU and you will be able to scroll thru your music library & listen to it via your steering wheel controls. Info from your iPhone/iPod will be displayed on your IC (cluster). Now I don't need my iPhone charger anymore because it acts as a charger too. It wasn't cheap but I think it's worth it. IMO
Old 06-30-2008, 01:27 PM
  #509
MBAT's Avatar
2007 C230, 2008 Nissan Altima 3.5SE
Has anyone tried this on a 2007 C230? I heard something about the 2007 models having a different connector or not having the white connector at all. Any info you guys have would be great.
Old 07-20-2008, 08:38 PM
  #510
djtech2k's Avatar
C230
I also have a 2007 C230. Is this the same and how can I check?
Old 07-21-2008, 01:08 AM
  #511
MBworld Guru
FrankW's Avatar
white and whiter
pop open the kicker panel and find out.
Old 07-21-2008, 06:21 AM
  #512
djtech2k's Avatar
C230
I tried that, but could not get the thing off. I got the dorr strip on the bottom off, but around where it overlaps with the kick panel, it seems to be latched on something. I yanked on it very hard and it did not budge. How does it come off?
Old 07-21-2008, 12:20 PM
  #513
detroityianni's Avatar
2005 c230k sedan
there is a screw in the middle of your kick panel.. i think it has a cover on it.
Old 07-21-2008, 07:17 PM
  #514
djtech2k's Avatar
C230
Got it and here is what I saw. Is this ready for aux cable, if so whats the part number?
Here are the pics:
https://mbworld.org/forums/c-class-w203/253264-2007-c230-auxilary-audio-input.html
Old 07-21-2008, 07:57 PM
  #515
MBworld Guru
FrankW's Avatar
white and whiter
Here are the pics:
https://mbworld.org/forums/showthread.php?t=253264
no white plug = no pre-wire. seems like a lot of the base car does not have them pre-wired.
Old 07-21-2008, 08:55 PM
  #516
djtech2k's Avatar
C230
I mean is it possible its not in that place? I looked at it and pulled wires up, but of course theres all sorts of wires in there. Could I have missed it? I looked as far forward as I could under the carpet, but did not see any other plugs.
So what are my options then? I want a bluetooth phone setup and a way to stream audio from an mp3 player, but will not consider any fm mod stuff. I also cannot see myself spending some ridiculous price for the things like incartronics has.
Any ideas?
Old 07-22-2008, 12:57 PM
  #517
2005 c230k sedan
Any ideas?
looking at your pics my plug was a little further towards the front of the car in that groove where you have all the wires pulled out. i have a 2005 though.. it was deep in there
Old 07-22-2008, 09:47 PM
  #518
djtech2k's Avatar
C230
I ripped it apart again today and dug all the way up to the floor boards by the passenger feet, which is a metal plate. I saw no white connector anywhere unless its run underneath that big metal plate under the passenger feet.
Old 08-03-2008, 08:30 PM
  #519
sraj49's Avatar
E-320
I Have an E-320 year 2002 model. Can you please help me with:
1 What are the items to be bought
2 Step by step how I can achieve to have and AUX input created.
Thank you for your help and I wait your kind response.
Raj
Originally Posted by mbny
yes, no screws. tug alittle and you'll find the spots were it's locked in place. then slowly apply more pressure until it comes off.
I just picked up my cable this morning and did the install this afternoon. took about a half an hour and works great. the only thing i don't like is my ipod keeps playing after i shut the car off. get back in the car and i realized the ipod was a few songs later. sound quality is great, wasn't sure what to expect but it sounds as good as a CD, sometimes i actually think better. great mod!!! cable cost me $47 at my local dealer.
Old 08-22-2008, 05:03 PM
  #520
geli7's Avatar
2005 Mercedes C240
AUX Harness and Charger?
Great thread. I've read it all and just ordered the Aux harness for my 2005 C240.
My question is charging. Id like to run a wire to the center console and keep the ipod there. I saw somebody had what looked like a separate charger in the section under the gear shifter so they could charge their ipod without using the cigarette lighter. Can someone give me a bit more info on this, specifically what needs to be purchased and how to install? Would appreciate any help, thanks!
Old 08-25-2008, 08:16 AM
  #521
codegeek's Avatar
A car
I used tap-in connectors and a cigarette lighter extension (both available from RadioShack) to get the power connection to my XM receiver. Make sure you use a voltage meter to tap into the correct power cables on the cigarette lighter. One wire is for the light ring around the existing cigarette lighter (you don't want to use that one).
The bulky part of the cigarette lighter extension fits under the carpet on the passenger-side foot well. I routed the power connection to the XM receiver through the back of the ashtray compartment. I drilled a small hole in the back of the ashtray compartment that will get covered with the ashtray insert if I decided to change things later.
If I did it over again, I'd add a bit more slack when tapping into the existing cigarette lighter, because it was a tight squeeze getting everything tucked back in behind the ashtray compartment.
See post #496 on this thread for more info and pics.
Old 10-02-2008, 09:40 AM
  #522
simppa80's Avatar
S204 220 CDI "AMG" Mopf
Audio 10 w203 -03
is there any posibility to make AUX-in this D2B system? Not system MOST.
Old 10-02-2008, 11:54 AM
  #523
ChrisBrown's Avatar
2005 C240 4MATIC, 2010 ML350
Wasn't there someone on here who modded their deck via the tape deck? It was the most integrated stock mod I saw.
Old 10-03-2008, 05:36 AM
  #524
ram_rtg's Avatar
C200K Jul 2004
Hey guys I thought I'd share my setup with you all.
This is only one possible alternative I guess but I found it to be the best for my needs as it requires no modifications to the car dash.
It cost me EUR 100 all up . I will shortly investigate running the power cable from the cigarette lighter to the unit undercover.
It transmits music and GPS voice simultanously via FM reasonable sound (clean non distorted treble) with volume level adjustment through the unit.
It takes a 4GB SD card so not too bad for storage.
This is good for a temporary measure I suppose but I would really like to get a hold of the Alpine KCA-430A if I can find anyone who sells them here in Australia
Check out the pix
Old 10-04-2008, 03:10 AM
  #525
simppa80's Avatar
Check out the pix
I not sure that do i understrand this right. Do you have a Fm-transmitter there (whit good sound quality)?
I check this alpine KCA and I think I could then have Aux-Input for mp3 player? Correct if I'm wrong. I find cheapest KCA-430 like 120€..
You have already rated this thread Rating: Thread Rating: 23 votes, 4.65 average.
Quick Reply: DIY - setting up the AUX input for iPod, mp3 player, etc.
