MM Package and Memory Card - SDHC
Old Dec 12, 2007 | 07:46 PM
  #76
MBfan21's Avatar
2008 C300 Luxury 4matic
I went and bought a PNY 8 GB card. However I don't know if it's just my car but when I turn the vehicle off and then turn it back on, it takes about 5 seconds to load the memory card.. It will say reading memory card each time.
Old Dec 12, 2007 | 08:31 PM
  #77
Savage c-300's Avatar
C300 Sport, MM, P1
i havent gotten the video to work off the memory card either, i think its because its not a divx player, only standard dvd.
Old Jan 3, 2008 | 09:02 PM
  #78
kfm999's Avatar
2016 C400 4Matic
Originally Posted by crow944
Picked up the Sandisk 6-1 adapter this afternoon, plugged in my SDHC card and inserted in the PCMCIA slot in the car. Works like a charm! I prefer using the card better than my ipod. The SDHC card can be pulled out without ejecting the Sandisk adapter.
Thanks everyone on this thread for you advice.
I am starting to wonder if Sandisk only made 6000 of those 6-in-1 adapters?! and all the C Class owners bought them all because I cannot find anything on best buy or anywhere else?!
DUH!!!
Old Feb 6, 2008 | 07:42 AM
  #79
ecoamg's Avatar
07' S550 Flint Gray Sport
Help
Originally Posted by V8 AMG
I currently use a Compact Flash card with PCMCIA card adapter and it works like a charm. No need to worry about SDHC compatibility issues.
Bought an 8 GB (280 speed; for fast read/write) and songs are accessible instantly when i scroll through folders.
I bought a Compact Flash Extreme III 8.0 GB, thr pc card adapter, I copy my music from my pc and it does not work on the car.
Any suggestions???
Old Feb 6, 2008 | 10:00 AM
  #80
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
can you post your exact brand reader and and exact brand memory card? I want to be sure to get the fastest combo...
i hate when one bottlenecks the other, would be great to just know what already works FAST from somebody that already has it set up
Old Feb 6, 2008 | 11:39 AM
  #81
jstaneff's Avatar
C-300, XC70, Wrangler
Any suggestions???
Check the format of the card. Is it compatible (e.g., DOS format?). What format is your music?
I didn't even think about it, just copied files to a 1GB SD card, stuffed it into the adapter and it worked just fine. Had to select the AUX input. Normal SD is a DOS-like format. If you have a different format, it may not work.
Old Feb 6, 2008 | 11:00 PM
  #82
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
I noticed on mine that when I popped in one of my other SD cards that had a folder on there with songs in it, plus folders with other stuff, it wouldn't read them. I had to get rid of the non-MP3 files. It skipped over my ogg stuff fine but didn't like the ****.
I've had to re-seat my mini-sd cards a couple times in my SanDisk 6-1 in order to get it to read. Not sure if it's the card reader or the mini-sd adapter.
Old Feb 7, 2008 | 03:02 PM
  #83
C300Man's Avatar
C300
I was looking through flea-bay and found this. the description reads: But the picture itself shows no where its SDHC. Can someone that has bought one of this works or not? thanks
click here
ps. the shipper is from China...
* Comply with PCMCIA standard PCMCIA interface
* Support flash cards: xD/ SD /SDHC(SD2.0) / MMC / MMCplus / MS / MS PRO/ MS Duo(with adapter)/ Micro/Mini SD(with adapter)
* Very low power consumption
* Auto sensing PCMCIA/ATA host interface
* Compatible with Microsoft Windows 98SE/ME/2000/XP/Vista and Mac OS 9.X and above
* High access speed, "Plug-n-Play" operability
Old Feb 19, 2008 | 08:59 AM
  #84
rebel_mtc's Avatar
1991 560SEL, 1981 300SD, 1983 300SD, 2008 C350
Can someone post a photo of Scandisk 6 in 1 inserted in the MM thanks.
Old Feb 25, 2008 | 04:25 AM
  #85
@nv@'s Avatar
2008 S63 AMG, 2008 ML 550
anyplace to get the High Capacity adapter online?
Old Feb 25, 2008 | 08:23 AM
  #86
rebel_mtc's Avatar
Finally got a 8gb Sandisk SDHC but unfortunately I can't find the Sandisk Adapter in Hong Kong Sandisk store they told me it's phase out it seems I have to find a way and buy in in USA.
Old Feb 25, 2008 | 08:56 AM
  #87
PoaMike's Avatar
C300 (W204) w/ MM, P1, & 18"amg's
It will always take a few seconds for it to load.
Old Feb 25, 2008 | 09:59 AM
  #88
theraj2's Avatar
'08C300 White w P2,MM,Pano
I use .mp3 and .wma (windows media audio) format on my micro sd w/ adaptor or my compact flash. doesnt really mater what card u use, once it fits the PCMCIA adaptor.
Also the card must be formated. you can do so, by inserting the whole PCMCIA card into your labtop. or taking the card out and connect it using an adaptor to your pc.
right click and hit format. or you can format it on the camera you may be using. then add the files back and it should work
Old Jul 8, 2008 | 12:03 PM
  #89
rebel_mtc's Avatar
what happens if the card is not formatted?
Old Jul 9, 2008 | 09:21 AM
  #90
rebel_mtc's Avatar
What is the brand and type of Compact Flash did you use and what brand is the adapter.
Old Jul 9, 2008 | 11:47 AM
  #91
rs1985's Avatar
BMW E90, W204 C350
also can we play WMA ?
cause on the s class
no chinese no video no wma
thanks
Old Jul 10, 2008 | 05:18 AM
  #92
Dimebag Darrell's Avatar
Mercedes Classe C
Hi all,
Please make a list of PCMCIA 6 in 1 card (with URL if possible) compatible
share your experience with the others users
Best regards,
Old Jul 24, 2008 | 10:28 AM
  #93
rs1985's Avatar
BMW E90, W204 C350
so only DVD would work ?
if i make the file Mp4 would it work ?
Old Aug 25, 2008 | 08:49 PM
  #94
SDGuy's Avatar
2000 CLK430 Cab - sold; 2009 C350 White with Mocha P2,MM,18" AMG,Pano roof
Can voice command be used to look inside folders and pick songs to play - or must I use the knob?
Old Aug 31, 2008 | 04:49 PM
  #95
larseu's Avatar
S204 2008 C 320T CDI 4MATIC AMG sp - R172 SLK 200 AMG
Look what I found
original for the Mercedes-Benz GLK offroader:
PCMCIA Multi-Card Reader
parts no.: B6 782 3971
Old Sep 2, 2008 | 02:12 PM
  #96
Saks_C350_Sport's Avatar
CLS63
Not sure if this is the right one but if it is, it is a HELLUVA deal. Enjoy:
http://www.woot.com/
Only lasts one day..............
Old Sep 3, 2008 | 03:32 AM
  #97
lx Raven xl's Avatar
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
Originally Posted by stealtheo
Correct, Cd Music (CDA) are those purchased. The MM package can also play mp3's or wma from cd or dvd but you can not copy those to the hard drive
You can copy mp3 files from the CD/DVD to the MM hard drive. I do that all the time.
Old Sep 3, 2008 | 10:10 AM
  #98
SDGuy's Avatar
You can? I heard that was not possible. Please elaborate.
Old Sep 4, 2008 | 10:04 AM
  #99
It is possible. It is easy.
Put the DVD which has MP3 files ( Does not matter if you have organized the folders on the DVD )
Now go to Audio
Select the Media as Music Register and then select I think Music register from the bottom Menu.
Then you will have an option copy files to Music register.
then select the folder or folders of Music you want to copy.
then select start.
Its kinda slow but it will copy over the mp3 files in the same folder structure as in the DVD and accessing the songs is fast. 1.5GB transfer takes upto 20 mins
alsi I would like to know , any PCMCIA card adaptor will work right. not only Sandisk. And then in that card adaptor you can use any supported memory card that adoptor can fit. and support ??
Old Sep 4, 2008 | 08:56 PM
  #100
CLS63
http://www.buy.com/retail/product.as...54&dcaid=17654
