C350 Clear side marker installation (additional step)
Old Jul 21, 2008 | 08:20 PM
yxc145's Avatar
2004 E320, 2006 Audi A6, 2008 C350 W204, 2010 BMW F10, 2012 Porsche Carrera S 991, 2014 E350 W212
Hi C350 sport owner
unlike C300, we have additional steps to go through when installing the clear side markers. There is a screw holding the OEM lense to the black housing you need to unscrew to remove the lense. It's tricky. The space is very small. So, you need a pretty small L shape screw driving to do that job. Also, it's not a phillip or flat head screw. it's 6 lobe/star recess. Good luck to you all. I think the saler for the the clear side markers should give discount to C350 owners, cause we have to buy additional tools and spend much much more time to do the job.
Old Jul 21, 2008 | 08:42 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
Good to know. You're probably the first C350 owner to do this since I haven't seen this posted anywhere else.
Old Jul 21, 2008 | 09:10 PM
aprince2die4's Avatar
08-C350 black/black
one more quesion....did the screw fit into the clear lenses i dont recall seeing ne thread in the clear lense hole....also if u didnt rescrew it...does it still sit tight against the fender?
Old Jul 21, 2008 | 09:30 PM
yxc145's Avatar
the clear markers i got has no threads in the hole. They do fit, but of course, not gonna be "tight" like the OEM ones with screws. I am not exactly sure if the clear lense HOLE size is bigger than the screws. If not, you can definitely try screwing them in.
Old Jul 21, 2008 | 09:40 PM
08-C350 black/black
ok great info...thanx everyone
Old Jul 21, 2008 | 11:24 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
The clear ones with the chrome bulbs that I got do not fit perfectly tight against the fender. It was buggin at first but now I don't notice it as much. Probably cause I got a scratch on it in a parking lot so that's all I see now...
But I don't recall there being anything like you're describing when I installed them on my C350. Different lens manufacturer maybe?
Old Jul 21, 2008 | 11:32 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
same with me, no screws needed?
it just clips in 3 places
Old Jul 21, 2008 | 11:33 PM
yxc145's Avatar
that's a possibility. anyway, i actually ones with screws are better. So they can fit the bumper tighter and not fall out easily.
Old Jul 21, 2008 | 11:42 PM
mb_horseshoe's Avatar
2008 C300 Sport
I have a c300 and had the screw as well.
My car is only 2 weeks old, maybe the newer builds have it... not sure
Old Jul 22, 2008 | 12:25 AM
Derspeed's Avatar
X3 and 2012 C coming soon
Mine had no screw, but does have a place for it. This is odd.
Old Jul 22, 2008 | 02:17 AM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
this has nothing to do with whether it is a c350 or c300...
I have the c350 and i didnt have to use a screwdriver for my clears...
they also fit snugly jusyt like OEM... without screws...make sure you get the more expensive ones on ebay... the cheaper ones didnt fit right for me and i had to return them...
i picked my c350 up in october 2007, maybe the newer builds have screws....
Old Jul 22, 2008 | 02:56 AM
Azn_C300's Avatar
mine was late May 08 delivery and had no screws. If they did update it by production date, they only did it for the c350s then.
Old Jul 22, 2008 | 08:52 AM
nolabenz's Avatar
c300 sport
There was a screw for my C300
Old Jul 22, 2008 | 11:36 AM
jo17jC230's Avatar
2008 C300 Sport
Me too.
Old Jul 22, 2008 | 01:01 PM
yxc145's Avatar
Hi guys
i just did. ones with screws holding the lenses. You can screw them back into the clear lenses you got (even the holes don't have threads). Not really hard to do, just take some patience with the right L shape tool. It will hold the Clear marker in much tighter and guranteed never to fall out. No more wiggling
Old Jul 22, 2008 | 01:08 PM
kfm999's Avatar
2016 C400 4Matic
Originally Posted by yxc145
Hi guys
MB owes all of us pre- 05/08 C owners a screw.
Old Jul 22, 2008 | 01:11 PM
yxc145's Avatar
If you guys without screws see a hole in the housing unit and also see threads in the hole of the of the OEM amber lense, I wonder if Mercedes benz forgot to put screws in... ha ha, just a joke.
Old Jul 22, 2008 | 01:16 PM
Azn_C300's Avatar
wonder what else in the car they forgot to put screws in....
Old Jul 22, 2008 | 01:31 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
You think thats scary. A while ago a friend of mine owned a Jeep, purchased new no mods. I went to change his oil and was lying under the car when I looked at the passanger side leaf spring. The rear bolt was well over 3/4's of the way out. No thoughts I slid out real quick got out the floor jack and jack stands a quick run to the parts store for a new bolt with nut some locktite and it was fine for the rest of the time he owned the car. Also found a screwdriver behind the battery when I changed that for him don't know if it came from the factory or at the shop he had some work done. Looked old though.
Old Jul 22, 2008 | 06:42 PM
narky's Avatar
2008 Arctic White C300 Sport 6M
This is all very reassuring to know.
Old Jul 23, 2008 | 03:24 AM
08-C350 black/black
dont wanna start drama but mine has a screw and was made in SA...just for thought...maybe cause of different plants
Old Jul 25, 2008 | 03:01 PM
who8888's Avatar
15 E350 4Matic
It looks like maybe the door pins
Old Jul 25, 2008 | 03:03 PM
who8888's Avatar
15 E350 4Matic
Hi guys
I just got a set of the clear lenses. How hard to install them? Is it just removing the wheel well covers and removing the OEM lenses? Or there is more to it..
Thanks!
Old Jul 25, 2008 | 03:12 PM
yxc145's Avatar
ok, you gotta see if you have the screws holding the OEM lense to the rear black housing or not. If not, it's pretty easy to pop them out. If you do have the screws. you will need a small L shape Torx screw driver to take the screws out. very time consuming and hurts your fingers.
Putting them back in is tricky, too. You just gotta play with it a bit.
without screws.. about 20 minutes.
With screws... about 35 minutes.
Attached Thumbnails C350 Clear side marker installation (additional step)-07212008452.jpg
Old Jul 25, 2008 | 03:43 PM
who8888's Avatar
15 E350 4Matic
We are talking about the Orange side marker in the front right? Just want to make sure. If so, how can you tell if there is a screw holding the lense without popping it out?
