*DIY Rear Camera install w/Pics - Centered Location
Old Oct 22, 2008 | 10:09 PM
  #51
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Camera not
Originally Posted by rob13572468
we've got to get you fixed up already... did you check the couple things from the other post ( when you press send+end+vol up does the radio read 'diagnosis' and then power off and then back on?)
I know about all that and in fact have turned it off and on several times and verified in the system menu that the camera is installed and gone into the other onscreen menu to verify that the camera option box is checked and it is.
And today, I stopped at my dealer and had a talk with the service manager about it. He got the keys for a 2009 model (MM but of course no camera) and I attempted to turn on the camera option using the steering wheel buttons, expecting a blank screen except for the check surroundings warning at the top. After repeated attempts we gave up since it would not respond. BUT, that does not mean that on the next try it would not have because we then climbed into my car, I turned it off and attempted to reactivate it to demonstrate the diagnosis screen and it would not respond. When he went back inside I tried once more and sure enough it worked.
I have found that it sometimes takes multiple attempts to turn it on after it has been turned off, using the buttons.
He suggested bringing the car in so they could run a scan to see if anything is abnormal. Probably at no cost to me.
I asked about software versions, thinking mine may be something out of date but he had nothing to offer about that.
Old Oct 22, 2008 | 11:47 PM
  #52
white46's Avatar
08 C300
when you change the settings on engineering menu, it takes few minutes to adopt changes which was being addressed on,
https://mbworld.org/forums/showpost....4&postcount=15
and
https://mbworld.org/forums/showpost....5&postcount=17
Old Oct 23, 2008 | 09:55 PM
  #53
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
ok lets try something different... instead try activating the aux video option: (press send, end, and mute) all at once and watch for the words 'diagnosis' to be displayed and for the screen to go up and down. Then go to the 'video' menu on the main screen and select 'aux' under video. lets see if the camera image shows up under aux (you will have to put the car in reverse to turn the camera on if you have it wired to the reverse lead).
Also keep in mind that the steering wheel button activation only works because the vim/programming module is plugged in behind the radio. normal cars will not program that way.
Old Oct 23, 2008 | 10:48 PM
  #54
RLE's Avatar
RLE
NOW IT WORKS..ONCE
OK, I did that and the camera screen comes up so now I know the camera and cabling and components all work.
But, shifting out of reverse, the screen reverts to blank and the only way to get back to normal is to push for example the radio button which then restores all functions. But, the camera view is not available unless I go back in and activate Aux video again.
BTW, the camera view only works when stationary. When I move the car it is replaced by (paraphrasing) "For safety cannot be viewed when moving" which sounds like the old video warning when no VIM is installed.
it's clear that all the hardware is OK (maybe) and installed correctly so it's software. But isn't the purpose of the VIM to allow video in motion all the time?
Old Oct 24, 2008 | 01:22 AM
  #55
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
If you want to use the VIM function, you must enable it every time you start the car. It's not ON all the time, because if it was then you'd have GPS disabled all the time.
When you turn off the car, the next time you start the car you'll have to enable VIM again to watch video in motion.
Old Oct 24, 2008 | 01:28 AM
  #56
RLE's Avatar
RLE
VIM? No.
I have no desire to ever watch video in motion but what that little test revealed is that the camera and associated wiring etc. does work and can be displayed. The only question remaining is why the camera does not display when in reverse under normal conditions.
Old Oct 24, 2008 | 01:44 AM
  #57
Hmmm... I'm just as baffled as you are now.
When was your car built? I wonder if there were any COMAND software changes around the time of your car's build.
BTW, mine had a build date of 10/2007.
Old Nov 11, 2008 | 09:06 PM
  #58
wanchu83's Avatar
C300 Sport LOADED
I have a question.
Camera looks great, but how does it look on night time? can ou see back well? I don't see an ir or lights so i am curious. Let me know. Thank you.
Old Nov 11, 2008 | 09:12 PM
  #59
PolePosition's Avatar
C350
Originally Posted by wanchu83
I have a question.
Funny that you just posted this because I was just about to mention that I used my backup camera in the dark last night for the first time and it works GREAT in the dark
Old Feb 5, 2009 | 01:29 AM
  #60
matt92's Avatar
2008 C300 Sport 4Matic
Great job on "centering" the camera.
But about wiring. If I remember correctly, Kenwood CCD-2000 has 3 wiring.
Ground, reverse light and ACC.
(I helped a friend install it in another car)
So where did you wire the ACC cable?
Is it ignorable?
Old Feb 5, 2009 | 03:06 AM
  #61
micropower99's Avatar
2008 Mercedes C300 4Matic
Is it ignorable?
Yupp. I was confused there too. So I put the Reverse light and ACC wire together and the ground I put on its own.
Old Feb 5, 2009 | 03:10 AM
  #62
Will38's Avatar
2008 C300
For the Rear Camera, do you have to have the Multimedia Package as the screen?
Old Feb 5, 2009 | 03:16 AM
  #63
I have the command package. So its the navi but no logic7.
Old Feb 23, 2009 | 05:50 AM
  #64
sim2011's Avatar
C250CDI Sport W204 + Command
UK Camera Install
Backup Camera UK
I have fitted the Back up camera to my 2008 C220 CDI Sport , so I thought I’d let anyone else in the UK know the parts I sourced
Camera Kenwood CCD-200 www.dynamicsounds.co.uk £96.94
5m Composite Video/Digital Audio Coax Phono Cable Lead
GOLD RCA Phono Coupler Join AV Composite Sound Cable
Both from http://shop.ebay.co.uk/merchant/kenable_ltd
Cost for both items £6.06
Fakra Female to DIN Female Aerial Adaptor £6.94
http://stores.ebay.co.uk/In-Car-Mart-Ltd
Female RCA connector from Maplin £1.20
Total cost £111.14
I chose to fit the camera in the centre location and ran the cable through the drivers side headlining, the Camera control unit is tie wrapped in the fuse comaprment in the boot .
Old Mar 26, 2009 | 12:56 PM
  #65
Bokx_350's Avatar
C350
Can anyone provide more details (pics would also be a great aid) on passing the cable from the trunk to the head unit??
I have seen several DIY for the camera, all great, but they fall short on this part.
Old Apr 22, 2009 | 07:54 AM
  #66
woontai's Avatar
Mercedes Benz ML350
Backup Camera for W164 ML350
Beautiful job on the center location. It turned out really nice...
Hi, I have this European version APS Command Unit with a video input at the back.
I have just purchased a Kenwood CCD-2000 Backup Camera which I believe can be installed directly to the APS. But Unfortunately, the screen showed "No Video" like in the attached picture.
Wonder if you can help me? I would like to have this reverse camera installed (I would like to make full use of the existing Fakra video input). And Video in Motion from an external video source.
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
Attached Thumbnails *DIY Rear Camera install w/Pics - Centered Location-rear-comand-aps.jpg   *DIY Rear Camera install w/Pics - Centered Location-aps-back.jpg   *DIY Rear Camera install w/Pics - Centered Location-aps-front.jpg
Old Apr 22, 2009 | 09:33 AM
  #67
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Yes.
Old Apr 22, 2009 | 01:37 PM
  #68
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
Exclamation
EXACTLY... Need more details on routing the wire for us amatures that do not want to take to many risks with messing up our car!
Thanks in advance
rb
Old Apr 22, 2009 | 02:22 PM
  #69
Ron Jr's Avatar
I went through the passanger sideof the car. There is a cable run on that side hidden behind the carpet in the trunk. Push a wire snake (or coat hanger) through it and you should be able to fell it between the rear seat back and the door jamb area. Pull the wire through. I tucked mine under the door sills then under the carpet up the firewall, under the dash and there is a hole behind the command that leads to an area around the glove box (If I remember right). Not to hard just take it slow and use common sense if it won't go through easy don't force it.
Old Jul 20, 2009 | 02:49 PM
  #70
xxnonamexx's Avatar
2008 C Class Sport
Vader- Great Job! I have one question you stated you have additional RCA cable to wire camera stuff in back instead of the front. Can you be more specific about how/where you ran the wires/connection? You mentioned over the driver side headliner did you have to run it from the trunk to the front?
Old Jul 22, 2009 | 11:07 PM
  #71
horizon's Avatar
2016 C200
Cool. Just need to clarify a few things.
Did you feed the cable from the handle strip to the inside of the boot through the same hole you fixed the bolt on? There seem to be no other holes to get to the inside of the boot. The nearest alternative looks like drilling a hole through the middle of the plastic catch hook on the right mounting position.
wrt cables - I assume the purple and red are spliced together to the vehicle reserve light harness and black alone to ground
I prefer the centred location, but I notice the chrome on the handle strip is not exactly aligned when the snap pin on that mounting point is replaced
Finally, what is the issue about needing an rca extension? Is the one that comes with the camera not long enough to get to the head unit?
Thanks in advance to anyone who answers
Old Jul 23, 2009 | 10:34 AM
  #72
PREMIUM SPONSOR
ML350, Lotus Elise
The location and position of mounting/access holes varies with the trim level of the vehicle and production date and location.. For example in the US some of the W204's have a grommit or plastic pop-out where the wires can be routed. Otherwise you can always drill a hole underneath the plastic trim plate. Just be sure to use a rubber or plastic grommit to protect the wiring.
There are a couple of wiring options: if you decide to connect the power in the back at the reverse light then you will need an RCA extension to reach the front. Alternately you can connect power up front at the cigarette lighter plug (pop up the shifter trim and unscrew two T-20 to remove) which will allow you to use the length of cable provided with the camera instead.
Old Jul 23, 2009 | 10:45 AM
  #73
kaku's Avatar
2009 C300S 6mt
but if you connect power at the cigarette lighter plug, won't the camera be constantly on?
Old Jul 23, 2009 | 12:32 PM
  #74
Ron Jr's Avatar
Well yes and no. It will have power but it doesn't actually turn on till you put the car in reverse.
Old Jul 23, 2009 | 01:30 PM
  #75
horizon's Avatar
2016 C200
Thanks very much Rob. Cleared those issues up.
