Back up camera
Dear . I check my car today its 2009 C 63 and when i enter the hiden menu in the HU parameter there is no thing say backup camera. there is only VIDEO (ON OR OFF) But i check my freind car which the same car but its 2008 one and its has back of camera option.
I swap the head unit i mean the command and it work in my car but it did not work in has car.it means the software in my head unit is not the same of his one. can any body help me to find the same softwear which the 2008 model has?
Kind regards
Any help please?my car 2009 model.orange color.
Anyone figure out how to get the Video Aux to work constantly instead of working only in Reverse? I wonder if you turn Video Aux "ON" and Backup Camera option to "SRVC", and if the backup camera is given constant power (instead of how you guys had connected the power wire to the backup light which means the camera only powers up when in reverse), that way even when the car is not in reverse there is a way to display the camera on video (obviously we'd add some other video source in the future).
Anyone try this? On the screen I do not see any option to display Video Aux. If I go into Video there is only the DVD. And I believe the Aux under Audio is just for the audio Aux port in the glove compartment.
Anyone?
Anyone?
Apparently you cannot use both Rear Camera and Video Aux source at the same time. Another cool option I found is that you can set Navigation as "Uninstalled" and then set Navigation Retrofit to "Installed", and that way the Mercedes Navi menu dissappears but if you press the Navi button on the Comand it will go to the Video source, which it I think assumes it to be an external retrofit Navigation system. This is perfect for us in Korea where the Mercedes Navigation does not work.
Also under Navigation Retrofit there is "Installed RGB" option, which I assume is a different connector than the FAKRA in the back - anyonw how this might connect to the Comand?
Finally, anyone know how to access the Prohivitive Parameters section in the menu? I read on a German forum that one guy had this option come up in the Engineering menu, and you could actually set the speed at which the Video stops displaying (alah, Video in motion!!!). Maybe this is available to the updated SW, if anyone here has their software updated and can check for this menu that would be great. Below is the full list of parameters in the Engineering menu of a C-class in Germany...
[Map]
Map Version: ES0700-04
[H/W information]
ECU Id: : 20
ZB num: 2049062800 001
H/W Ver.: 08 11
Device Ver.: D3 0.1
Device: HU/TGW.DVDS+N E
ECU CRIN: ME 4450 8 7291115
H/W P/N: 2048706789
H/W ZGS: 002
[Main-CPU]
FL Ver.: BLD-NR-204 1.43
Navi Ver.: 01.15.08_ECE
CPU Ver.: 10200:00
SWDL Ver.: 91.15.01
BT FW Ver.: a119
DSP FW Ver.: 20080331D31C
[Audio-CPU]
Apl. S/W Ver.: 02.15.05
Boot S/W Ver.: 02.01.02
[TGW-CPU]
Apl. S/W Ver.: 05.15.05
Boot S/W Ver.: 00.01.14
B-CAN.: 2007_41a(PreRelease)
H-CAN.: 2007_19a(Super Set)
[DVD setting]
ECE/US/Japan: ECE(0)
PAL/NTSC: PAL(2)
Region code: 2
Single/Changer: Single(1)
Range type AM/FM: ECE(0)
Range type LW: On(1)
Range type SW: On(1)
[TGW Parameter]
MOST: On(1)
Audio Source: force audio via external amp(1)
DAB: Not installed(0)
SDARS: Not installed(0)
UCI: Not installed(0)
[Debug Serial setting]
Main: Stop(0)
Audio: Audio Debug Port Off(0)
[Prohibition setting]
Navi speller: Enable(0)
Navi map: Enable(0)
Address book: Dis > 5km/h(3)
TV/Video: Dis > 5km/h(3)
Navi (car position): Enable(0)
Navi (destination): Enable(0)
Navi (city): Enable(0)
Navi (name): Enable(0)
Navi (phone number): Enable(0)
Navi Scroll Map: Enable(0)
Other Distraction: Disable(255)
[HU Paramter]
Language: german(0x01[4])
BT contact plate: Not installed(0)
Audio AUX: On(1)
Video AUX: Off(0)
Navi: Installed(1)
Bluetooth: On(1)
Navi Data Base: Activated(1)
RIZ signal source: reverse gear(0)
Retrofit Navi: Not installed(0)
Navi Offroad: Not installed(0)
Musicserver: Activated(1)
Basic telephone: Activated(1)
Addressbook: Activated(1)
SDS/TTS: Activated(1)
Musicserver func: Copy(1)
DVD Video: On(1)
Tail gate party: Off(0)
Rearview Camera: Not installed(0)
Display Haptics: Moveable(0)
Rear Seat Entertainment: off(RSE0)(0)
[Data Version - HDD1]
VII Data : 204111
Navi(Screen) : 1.01.25 0839
TTS_SSFT_CUDAT : 035
[Data Version - HDD2]
CDDB : 08/09
[Data Version - HDD3]
[Data Version - HDD4]
VRDB : 0.84ENN
[Map]
[H/W information]
ECU Id: : 20
H/W Ver.: 08 11
Device Ver.: D3 0.1
H/W P/N: 2048706789
H/W ZGS: 002
[Main-CPU]
CPU Ver.: 10200:00
SWDL Ver.: 91.15.01
BT FW Ver.: a119
[Audio-CPU]
[TGW-CPU]
[DVD setting]
PAL/NTSC: PAL(2)
Region code: 2
[TGW Parameter]
MOST: On(1)
Main: Stop(0)
Navi map: Enable(0)
[HU Paramter]
Audio AUX: On(1)
Video AUX: Off(0)
Navi: Installed(1)
Bluetooth: On(1)
DVD Video: On(1)
VII Data : 204111
CDDB : 08/09
VRDB : 0.84ENN
We should keep this topic bumped, cus this would quickly turn into the number one mod if it was true...
[Map]
[H/W information]
ECU Id: : 20
H/W Ver.: 08 11
Device Ver.: D3 0.1
H/W P/N: 2048706789
H/W ZGS: 002
[Main-CPU]
CPU Ver.: 10200:00
SWDL Ver.: 91.15.01
BT FW Ver.: a119
[Audio-CPU]
[TGW-CPU]
[DVD setting]
PAL/NTSC: PAL(2)
Region code: 2
[TGW Parameter]
MOST: On(1)
Main: Stop(0)
Navi map: Enable(0)
[HU Paramter]
Audio AUX: On(1)
Video AUX: Off(0)
Navi: Installed(1)
Bluetooth: On(1)
DVD Video: On(1)
VII Data : 204111
CDDB : 08/09
VRDB : 0.84ENN
I have able to dismantle the BZ9880/NTG2.5 HDD and read the data inside
attached is a copy of list of files in the hard disk. There are several drive partition, some are for music server (<4.0G), map data, voice etc..
oops.... im stuck, how do i insert image? when i try, it instead show http://
the files is in my pc, so how to attach?? haha
https://mbworld.org/forums/c-class-w...ring-menu.html
I keep reading this thread but i cant find where anyone clearly says "rear view camera will work on Non-MM."
Can anyone confirm? cause im looking in my Eng menu options and theres nothing for a camera :\
Navi map: Enable(0)
and how - I figured it was available via DAS,, but via the engineering menu????
