Flush free door pins...FINALLY!!!
Old Oct 2, 2010 | 09:05 PM
mrod81's Avatar
01' w203 C320 and 08' w204 C350
Exclamation Flush free door pins...FINALLY!!!
ok so after looking online and buying door pins that dont sit flush because MB decided they would design the top part of the door at an angle and since no one seems to be making door pins specifically for this door including the dealer (AMG pins or the Brabus dont sit flush either...close but not flush) i decided to take matters into my own hands...im sure someone here has done this prior to me but i did a search and didnt find anything...
it took all of ten min including paint drying time and best of all it was free...let me know what you guys think!
Attached Thumbnails Flush free door pins...FINALLY!!!-imag0001.jpg   Flush free door pins...FINALLY!!!-imag0004.jpg   Flush free door pins...FINALLY!!!-imag0006.jpg   Flush free door pins...FINALLY!!!-imag0007.jpg   Flush free door pins...FINALLY!!!-imag0011.jpg
Old Oct 2, 2010 | 09:24 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Pretty cool idea. Did you just cut it and paint over it?
Old Oct 2, 2010 | 09:42 PM
Samieee's Avatar
C
The pins are solid?
Old Oct 2, 2010 | 09:49 PM
Savage c-300's Avatar
C300 Sport, MM, P1
Cool. That's one way of dealing with the door pins!
Old Oct 2, 2010 | 09:54 PM
mrod81's Avatar
Yeah just cut and used a dremel to smooth it out and set the angle, painted it and called it a day.
Originally Posted by Samieee
The pins are solid?
yeah, they are the original ones that were on the door.
Thanks! I got tired of stabbing my arm every time i tried to rest my arm there.
Old Oct 2, 2010 | 10:45 PM
Samieee's Avatar
C
The pins are twisted off correct?
Old Oct 2, 2010 | 10:51 PM
mrod81's Avatar
yup...they are screwed in pretty tight.
Old Oct 3, 2010 | 11:01 AM
jctevere's Avatar
2012 C250 Coupe
Great mod, I just might do this! Note, the front ones twist off, the rear ones don't In order to replace the rear ones you need to take the door panel off. But this mod doesn't have to be done to the rear ones, they are far up front and out of the way. It just might look a bit weird having two different door pins.
Old Oct 3, 2010 | 11:58 AM
mrod81's Avatar
Thanks...the rears just popped off(literally popped off) so i did those too...didnt need to take the door apart at all one thing though...when i put them back on they wouldnt stay on they would come out really easy so i used a drop of glue to keep them on and that was that...i was actually considering capping them like one of the members did ( https://mbworld.org/forums/c-class-w...installed.html ) but i like how they all look exactly the same now.
Old Oct 4, 2010 | 09:41 AM
Bluewater41's Avatar
2009 Arctic White/Black C350 with NAV pkg, ipod integration, 40% HO tint, and 18" 5-spoke AMG wheels
I have the AMG door pins but haven't installed them yet. I went to try to unscrew the front door pins and they just kept twisting, not feeling like they were unscrewing at all, more of a little pop at the end of each rotation...do I just have to keep working these things???
Old Oct 4, 2010 | 11:55 AM
zankok's Avatar
W204, W220, S15 Silvia
strange, my stock door pins sits flush when locked :O
Old Oct 4, 2010 | 12:08 PM
Glyn M Ruck's Avatar
Super Moderator
Standard SA pins sit flush when locked.
Old Oct 4, 2010 | 01:58 PM
mrod81's Avatar
just keep unscrewing until they come out...
Old Oct 4, 2010 | 01:59 PM
mrod81's Avatar
Standard "SA" ? what is SA?
Old Oct 4, 2010 | 02:17 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
South Africa
Old Nov 6, 2010 | 10:06 PM
Rogwp's Avatar
2010 C300 4matic Special Edition
Another door modification
If I remove the front door pins can I cut at the base to make them shorter, so that they fit flush when the door is locked, or do I need to cut the top off, as in the OP of this thread?
Old Nov 7, 2010 | 08:30 PM
masterstudent's Avatar
C350
Great job
Old Nov 8, 2010 | 01:46 PM
mrod81's Avatar
cut from the top.
Old Nov 8, 2010 | 03:49 PM
NJBNZ's Avatar
'09 C300 4Matic Sport
Will definitely be doing this ASAP. I hate stabbing my arm with the door pins
Old Nov 8, 2010 | 05:09 PM
Kvn22's Avatar
24' G63,21' AMG GTR, 24' McLaren Artura, 17'' GLS63S, 24' GLE63S, 08' CL550
Thanks for the post man. Cool mod.
Old Nov 8, 2010 | 05:27 PM
lickem66's Avatar
09 C350
has anyone measure how much to cut off?
Old Nov 8, 2010 | 05:58 PM
NJBNZ's Avatar
Just lock the doors and make a mark on the pin that is flush with the door panel
Old Nov 8, 2010 | 06:25 PM
M-bENZ's Avatar
Corrolla
just want to show off my pin too and it doesnt looks flushed like your but i can live with that .
Andy
Attached Thumbnails Flush free door pins...FINALLY!!!-img_0090.jpg   Flush free door pins...FINALLY!!!-img_0091.jpg   Flush free door pins...FINALLY!!!-img_0083.jpg
Old Nov 8, 2010 | 06:31 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Andy
They look great Andy!
Old Nov 8, 2010 | 06:48 PM
mrod81's Avatar
Talking
thats how i did it...use a razor for the initial cut and then use a dremel or a fine file to smooth out the edges
Andy
Looks cool
No problem...my arm/elbow couldnt take getting stabbed any longer
