W204's and offsets of wheels
Old Dec 5, 2013 | 01:27 AM
  #951
vic viper's Avatar
S213
Originally Posted by edgalang
I've read EVERY page here and this thread is killing me with suspense!!
I plan on mounting Micheline Pilot Super Sports after my ECU tune and I'm still confused if these tires are considered "skinny" or not.
Tire/wheel sizes will be:
Fronts: 235/40-18x8.5+45
Rears: 265/35-18x9.5+45
I'll be running this setup on stock suspension, however I have the dynamic handling package (which I'm assuming is the same with the exception of the magnetic dampers).
Some seem to run 235/265 fine on 19's using similar offsets while others rub. I'm assuming I'll be right at the borderline and it'll purely be dependent on the tire selection at this point, but I plan on using the Micheline Pilot Super Sports regardless.
I'm positive the fronts will be fine...but is 265/35-18x9.5+45 too optimistic for the rear with the tire selection above?
Tires will look good on rims, and as long as running on stock suspension you will most likely not rub, but if you want to lower youll want to go +55 int the rear.
Old Dec 5, 2013 | 06:23 PM
  #952
First Benz 2013's Avatar
2011 Mercedes Benz C300 Luxury
Sweet
Old Dec 5, 2013 | 06:27 PM
  #953
c300 badge
Originally Posted by dudeitsmattx
Ok so I am going to keep the 20's I have now and just powder coat them matte black. I have H&R Super Sports on the way. Now does anyone on here have this setup? 20x10 in the rear with super sports? What size tire are you running? I have a 255/30/20 now but i need to goto a 265 or 275. Im sure it will rub but I would like to know for sure, cuz if so I will just roll my fenders. Because the 255 are just a little to skinny and if I hit a pot hole my lip would be done!
Did the c300 badge have holes behind it or was it just stuck on?
Old Dec 7, 2013 | 04:10 PM
  #954
MBH427's Avatar
03 Cobra
I've been putting together a list of some nice fitting wheels for our cars, and comparing how they fit versus the stock wheels. I figure that this will help at least somebody else out in the future
This is my car, and is my reference point for this post.
Stock offsets and widths for me are: F 17x7.5 et47. Rear 17x8.5 et58
I tried to put this in order so it goes from a less aggressive to more aggressive offset. Tried to use only non-C63 cars, as they have wider front fenders (not sure about the rear) than my C300 does.
The bolded numbers represent the change in measurement compared to my stock 17" wheels, on the outer surface of the wheel only.
AMG with 5mm F and 12mm R spacers: F +13mm / R +22mm
http://i9.photobucket.com/albums/a65...yd3/null-1.jpg
http://i9.photobucket.com/albums/a65/pharcyd3/null.jpg
HRE: F +12mm / R +24mm
https://mbworld.org/forums/attachmen...10211-1025.jpg
Unsure of brand: F +15mm / R +13mm
http://img855.imageshack.us/img855/3318/imageatm.jpg
http://img826.imageshack.us/img826/8653/imagesjz.jpg
OZ wheels: F +16mm / R +14mm
http://img.photobucket.com/albums/v4...ous/c3rims.jpg
BBS LM: F +21mm / R +24mm (stock suspension)
http://i534.photobucket.com/albums/e...x/IMG_0919.jpg
http://i534.photobucket.com/albums/e...x/IMG_0918.jpg
BBS (poke/rub reported): F +20mm / R +26mm
https://mbworld.org/forums/attachmen...s-photo-7-.jpg
https://mbworld.org/forums/attachmen...s-photo-3-.jpg
3DSM: F +18mm / R +31mm
http://oi41.tinypic.com/658qjd.jpg
Carlsson: F +20mm / R +32mm
https://lh5.googleusercontent.com/-1...2/IMG_8968.JPG
https://lh3.googleusercontent.com/-D...2/IMG_8972.JPG
https://lh5.googleusercontent.com/-3...2/IMG_8914.JPG
GroundForce: F +15mm / R +26mm
http://i1103.photobucket.com/albums/...pscf44e904.jpg
http://i1103.photobucket.com/albums/...ps8e4bb82c.jpg
http://i1103.photobucket.com/albums/...ps5f9230b4.jpg
Thanks to all of you who shared your set ups and your pictures
I'm keeping stock suspension and the OEM 17" wheels, I think that the best set up for me might be running F +12mm / R+17mm hubcentric and wheelcentric spacers, as any poke on stock wheels/tires/suspension would look terrible lol. Let me know what you guys think
Old Dec 7, 2013 | 06:19 PM
  #955
matt9's Avatar
Registered User
2013 c-class
Will these fit a 2013 C-Class:
19x8.5/9.5 +42mm all around
http://www.powerwheelspro.com/shop/p...roducts_id=714
Thanks in advance.
Old Dec 7, 2013 | 06:29 PM
  #956
Richard2011's Avatar
2015 BMW M235i 6MT
Thanks in advance.
On stock suspension, it should work fine. Lowered, depending on tire choice, will probably rub.
Old Dec 7, 2013 | 10:15 PM
  #957
Teddy Ouyang's Avatar
'10 R350 4matic BlueTEC/ '12 C250 4matic/ '12 GLK350 4matic/ '15 GLA250 4matic (delivery on Oct 22)
Originally Posted by Teddy Ouyang
Hello guys, I'm driving a Canadian 2012 C250 4matic with sport package. I want to buy a set of rims and tires: 225/45/17 et 35 17x8 for my winter setup. It's a good deal if it will work with my car so I don't want to miss it. Any inputs will be appreciated. Thanks!
I bought the tires and rims (17x8 +35) one season old for altogether $550 CAD and they fit quite well. They do stick out a bit more than the OEM 17inch but still acceptable. I used original nuts as the new rims are also ball sitting.
Attached Thumbnails W204's and offsets of wheels-dsc00903.jpg   W204's and offsets of wheels-dsc00898.jpg   W204's and offsets of wheels-dsc00896.jpg   W204's and offsets of wheels-dsc00894.jpg
Old Dec 7, 2013 | 10:37 PM
  #958
MBH427's Avatar
03 Cobra
Good timing on the post for me, your wheels look great. The fronts sit 18mm and the rears sit 17mm farther out than stock. Any rubbing or regrets on the set up?
Old Dec 7, 2013 | 10:51 PM
  #959
There's no rubbing at all as you can see from the photos (front and rear) and I'm running these rims with sport suspension (not sure how much it differs from the original one).
Attached Thumbnails W204's and offsets of wheels-dsc00906.jpg   W204's and offsets of wheels-dsc00904.jpg
Old Dec 9, 2013 | 12:12 PM
  #960
vendsit's Avatar
2009 C300
New Wheels and Tires
I was finally able to get my new wheels and tires installed Friday. I went with Niche M108 in 18X8 all the way around with a 40 offset. I wrapped them in Hankook S1 Noble2 tires. So far the ride is much smoother than the previous 17 inch set up.
Attached Thumbnails W204's and offsets of wheels-2013-12-07-13.40.08.jpg   W204's and offsets of wheels-2013-12-07-13.40.56.jpg
Old Dec 9, 2013 | 12:25 PM
  #961
2015 BMW M235i 6MT
I like it!
Where'd you get your lip? And what size tires are you using?
Old Dec 9, 2013 | 12:39 PM
  #962
Wawatusi's Avatar
2011 c300
I'm looking at a set of wheels for my snow tires, which all are 245/40-17 and work well on the stock rims....
The wheels I am looking at are Front & Rear: 17x8.0" Offset: Front & Rear: +38
Think they would work?
Guy says they fit, but I think it better to check with those who know.
http://www.ebay.com/itm/370948355184...S:1123&vxp=mtr
Old Dec 9, 2013 | 12:48 PM
  #963
Jpslikk's Avatar
C300
Vendsit nice set of wheels black on black. U thinking bout blackin out the headlight too?
Old Dec 9, 2013 | 02:36 PM
  #964
vendsit's Avatar
2009 C300
Wheels
Thanks, I'm thinking about it but not sure how it will look all blacked out. I've actually been thing about getting the illuminated star for the grill so it stands out at night.
Old Dec 9, 2013 | 02:44 PM
  #965
vendsit's Avatar
2009 C300
Wheels
Originally Posted by Richard2011
I like it!
I got it from JB Speed here on the forum and the tires are 234/40/18s.
Old Dec 9, 2013 | 05:17 PM
  #966
MBH427's Avatar
03 Cobra
http://www.1010tires.com/Tools/Wheel...ulator#Results
The 17x8.0 et38 would be:
15mm farther towards the fender in the front
14mm farther towards the fender in the rear
These should work fine as far as I know
Old Dec 9, 2013 | 10:31 PM
  #967
Wawatusi's Avatar
2011 c300
Would that go for me as well? Think the tires would rub being 245/45's in the front? Car sits on hr sport springs, 4 matic
Thanks for your help
Old Dec 10, 2013 | 08:57 PM
  #968
Joey8686's Avatar
2010 C300
[QUOTE=c3nthusiast;5669558]20 x 8.5 ET42 w/ Pirelli P Zero 245/30-20
20 x 10 ET53 w/ Pirelli P Zero 285/25-20
Lowered on Eibach Pros
What brand rims do you have? They look sick! I'm looking 2 do same type of rims but in 19x8.5 in the front and 19x9.5 in the rear what do you think is a good drop kit?
Old Dec 16, 2013 | 07:43 AM
  #969
nanofast's Avatar
cl203 220 CDI '02
Originally Posted by Leo977
my details:
wheels 3sdm 0.01 concave
Front: 19x8.5 ET42 with Falken 452 225/35
Rear: 19x9.5 ET40 with Falken 452 235/35
who make your rims in CB 66.6?
Old Dec 17, 2013 | 02:55 PM
  #970
Makross's Avatar
2013 C250, 2T Ruckus
would the Lorinser RS8 20x9 front and 20x10 rear fit a C-Class?? Not sure what the offset are though they came off a CLS.
Old Dec 17, 2013 | 03:18 PM
  #971
Frnakito71's Avatar
C300, 93tt RX7, 88RX7 Vet, 83RX7
Key word (offset) you need to find out
Old Dec 17, 2013 | 06:39 PM
  #972
Makross's Avatar
Offset is +38 all around.
Old Dec 21, 2013 | 07:43 PM
  #973
Daun_Tran's Avatar
mb W204
w204 offset
''BBs lm'' 19x8,5 et48 215/35... 19x9,5 et45 225/35
Old Dec 24, 2013 | 04:07 AM
  #974
Sinikovicm's Avatar
C250 coupe 2014
Will these SL550 wheels fit C250 coupe on stock height?
These are the specs:
5x112. 19x8.5 ET35 Front and 19x9.5 ET48 Rear.* tires 255/35/19 front and 285/30/19 rear.
http://www.ebay.com/itm/Genuine-OEM-Factory-Mercedes-Benz-AMG-SL550-19-in-WHEELS-TIRES-SL63-SL65-CLS550-/171169285884?pt=Motors_Car_Truck_Wheel_Packages&hash=item27da7c06fc&vxp=mtr
Thanks.
Old Dec 24, 2013 | 08:54 AM
  #975
vic viper's Avatar
S213
Genuine Factory Mercedes Benz AMG SL550 19 in Wheels Tires SL63 SL65 CLS550 | eBay
Thanks.
Front, no
Rear, maybe if youre not lowered.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
