W204's and offsets of wheels
Old Jun 30, 2011 | 05:09 PM
  #176
SuperBeaverAMG's Avatar
S204 T-Modell C230 AMG Pack
Originally Posted by IPB
Fitment looks great in these pics!
Oh and I'm jealous of the wagon, I sooo wish we could get them here
Frankly speaking we don't have many C wagons in Russia as well, but the are available at dealers. I love them Wanna C63 wagon, that's my dream
Old Jun 30, 2011 | 05:13 PM
  #177
Originally Posted by Matt_Eurojerks
I am looking forward to seeing your front fitment. Can you please take a few different angles of the front wheels.
Sure I will try to make it soon. The thing is that officially Carlsson advise to fit 225/35 at front, but the only choice I had was 235. It is fine, no rub. Rather soon I will fix H&R springs, gonna be better.
Rims were restored, but I don't like final result, probably will repaint them this winter.
Old Jun 30, 2011 | 05:15 PM
  #178
Originally Posted by StormTrooperZo
And what brand tires? I saw that you rub until you rolled do you think if the et is higher it wont rub I am having rennen make me some wheels and they told me the same rim sizes but I was worried about the rears cause i see most people run 9.5 in the rear
10 is fine, see my pics, no rub. But 255/30 is maximum. I wrote to Carlsson for example asking of possibility to set 265, they said NO. Might rub, 255 better. Moreover I like the stretch
Old Jul 1, 2011 | 01:35 AM
  #179
StormTrooperZo's Avatar
2011 W204 C300 mm pano
Thanks so do you know how hard is it to roll these fenders cause I was going to try the conti 265 dws since I'm not lowered yet and I'm on the tire for life plan
Old Jul 1, 2011 | 05:25 AM
  #180
About rolling I will tell you approximately in 2-3 weeks (if it will be needed) after lowering. I don't know the roads at your location. Russia and Moscow seems definitely not the best place for roads. 19th and 30 rear seems fine for me, but I am always careful, I mean I always mind the surface, trying to avoid holes etc. As I realize now 19th is for style, for those who are ready to bear in mind - "man, I have goooood wheels, be careful".
In general it is fine, I am very satisfied. Besides it is funny to get stupid friends comments like - "how you drive that, it's impossible, I have 225/45/17 and smashed it recently"
Old Jul 1, 2011 | 06:17 PM
  #181
Here you go, had time today when was leaving car at Service Station
Rear as well
Old Jul 5, 2011 | 05:00 PM
  #182
Matt_Eurojerks's Avatar
w204 C300
Thanks!!!!
Old Jul 10, 2011 | 02:20 PM
  #183
xXHotelCrazyXx's Avatar
2008 W204 Sport
So the setup im looking at now is 19x8.5f +30 235/30/19 and 19x10r +37 265/30/19 dropped on H&R Super Sports...what do you think?
Old Jul 10, 2011 | 04:20 PM
  #184
2008 W204 Sport
BTW i just bought my own fender rolling tool so i should be able to make it work correct?
Old Jul 10, 2011 | 05:59 PM
  #185
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
I dont know about that hotelcrazy, im running +40 on 8.5 up front w 235/35/19 with no rubs and +45 on 10s out back w 275/30/19 and i JUST make it, mine stick out a bit but they clear. I test fit 285 and it rubbed the inner but cleared the fender. I have dynamic handling so Im a little lower than stock. on my 08 i ran +35mm offsets F and R and i did 225 up front and 255 out back, 265 rubbed and certain tires in 255 rubbed too, only falken and sumitomo were good. a +37 in 10 rear is gonn rub w 265 or just barely clear in stock height, dropped and your not gonna make it. Check out dudeitsmatt's posts where he couldnt make it with a +40 or+45 cant remember which he had to pull the liner out completely. Theres only a 1/4" to roll anyway, the fender isnt really the problem the inners are. and +30 up front isnt enuff, I think +32 minimum on 8.5, i ran +35 on 8.5 and never rubbed even w wheels turned and bottom outs
Old Jul 10, 2011 | 06:05 PM
  #186
2008 W204 Sport
^are your fenders rolled?
Old Jul 10, 2011 | 06:20 PM
  #187
no they're not. It didnt matter either way. Its not hitting the fender lip, it hits inside. I have my own shop so I can play around, but if someone wants to test offsets just put your car on a lift and bottom it out on one corner w a block of 6x6 wood or an old bare rim under tire and let the car down til it comes off the lift a hair on that side. If you witness this on a w204 u will be amazed at how much the tire goes in when it goes up. It clears the fender pretty easy, but the inner fabric gets rubbed. When I ran +35 offset out back and tried 265 in a month i had huge wear marks on the inner fabric, and this was just from bottom outs, and on baby springs, only lowered about half an inch. you need minimum +40 out back to clear, +45 is whats ideal with a 10" rear, I have 10s on +45 w 275 and if i dropped to supersports or whatev id be rubbin. You should test bottom ur car to see the suspension travel, and you could also test w spacers w stock wheels to see what u can get away with before u order wheels, thats the safe way. drop the car whatev height u want, then add spacers and see if you clear. theres a formula online for overall tire dimension, when I computed 275/30/19 it came to .04 difference than the stock 18" amgs that came on the car. they were 245/35/18 in back for reference +52 offset
Old Jul 10, 2011 | 07:48 PM
  #188
2008 W204 Sport
So its only rubbing in the rear? Is there any kind of modification you can do to the inner well? Ill have to check it out
Old Jul 10, 2011 | 08:58 PM
  #189
Blazeitup123's Avatar
W205 c400 sport
i read somewhere that you can remove the carpet baffling from the plastic tire well. how? i don't know.
Old Jul 10, 2011 | 09:01 PM
  #190
2008 W204 Sport
If you remove it, i still assume there is metal or something right under it to rub on?
Old Jul 11, 2011 | 11:09 AM
  #191
yeah it only rubs in the rear inner fabric, not the fender. I test fit +32 255/40/18 once and it cleared teh fender too, just barely though, but rubbed bad on the fabric. The inner well has the metal quarter panel above it and on the passenger side u can see the filler if you remove the fabric liner. They are in w plastic clips w push pin insides and just plastic set screw plugs. Crap will get in behind ur bumper cover/quarter and backside of door jambs, but u cant really tell if your slammed down low enuff. If I was u hotelcrazy, I would do +40 up front and +45 out back, thats a flush to fender fit w 8.5 and 10 and will clear w sports and supers to if you do 265 out back 225 up front to match the stretch. If you go lower than that your gonna have to play around w fender well problems.
Old Jul 12, 2011 | 08:43 AM
  #192
I wrote here already that 265 rear can rub, I wrote official request to Carlsson on that, they advised 255 if the rims 10J rear and ET should be 45, so will be very nice.
Front if 8,5 ideally should be 225 will be slight stretch which is lovely to my mind.
Just FYI
Old Jul 12, 2011 | 11:06 AM
  #193
Just FYI
255 rear on 10J is too much stretch, doesnt look good. 265 is better, ad 225 on 8.5J matches well. It will clear well with +45 offset
Old Jul 12, 2011 | 01:09 PM
  #194
davezaristo's Avatar
16 GLE400, 16 eGolf, 15 M3, 13 328i, 06 S430, 98 E320
yes, i can confirm that with 265 and +32 setup, you will definitely be rubbing in the rear and doesn't look all that great imho since it sticks out about half an inch too much..i am seeing pieces of tires (like hair) coming off the side wall on the outer part and it seems like rubbing occur alot more on the right rear side..not sure why but i think those wheels will be taken off very soon if i can't find a solution and jimmy is right, i think the rubbing occur mostly in the inside but in my case, i think it is both inside and outside when i do hard turn or going over uneven pavement on the freeway.....
Old Jul 12, 2011 | 07:39 PM
  #195
2008 W204 Sport
What do you guys think about a 19x9.5 rear wheel with a +35 ET? Think it would look good or not?
Old Jul 12, 2011 | 07:45 PM
  #196
itsLoonie's Avatar
2012 E350 RWD
9.5 +35 ET 235/35/19 in the rear. I think it looks good
Old Jul 12, 2011 | 08:02 PM
  #197
2008 W204 Sport
Thats a 9.5 +35ET??? really? can i seez moar plz! sideviews?
  #198
2008 W204 Sport
Also are you running any spacers?
Old Jul 12, 2011 | 08:08 PM
  #199
itsLoonie's Avatar
2012 E350 RWD
Not my car. Posted this 2 pages back. Here's the link. Don't think he's on spacers.
https://mbworld.org/forums/c-class-w...cs-stance.html
Old Jul 12, 2011 | 08:09 PM
  #200
2008 W204 Sport
thanks ill check it out
You have already rated this thread Rating: Thread Rating: 14 votes, 4.64 average.
