Differential Fluid Change (4MATIC Owners)
1.) Does anyone know the official MB recommended service interval for the differential oil/fluid change? I've heard various answers from different dealerships.
2.) I'm currently sitting at the dealer getting the differential oil change. The MB tech was puzzled at first when looking at the front differential. There is a drain plug but no fill plug for the W204. He said they will need to remove the driveshaft in order to refill the front differential (an added 3 hours of labor). Anyone else run into this problem?
3.) What did u pay for the 4MATIC differential oil change?
FYI - I just told them to do the rear differential change for now.
It has been recommended previously on this forum that 100,000 miles would be a good point to do a change.
I think I will be doing mine a little earlier ie 100,000 km.
The manuals I have seen only recommend a level check. Other older manuals pre W204 say 10 years or 300,000Km.
You have to suck the oil out of the front diff. They do not have to remove the drive shaft.
We always recommend every 100K miles on the 203 forum just for good measure. The diff oil has a sacrificial additive system in it & while it will go a long, long way it does deplete in the end. It's also a good idea to get any wear debris out of the diff within reason & clean magnetic plugs where fitted.
JC - you are wise!
US Service 20 once at 39,000 miles
Underside of vehicle
Automatic transmission - oil and filter change 2702
I know now it has been decided that it should be done more than once, but it says nothing in the whole manual about a differential change, unless that's included in the trans fluid change.
Service the 722.9 transmission every 39K miles like ROW - it is one expensive piece of kit to repair & changing axle oils every 100K miles is a very good idea. The W203 4Matic owners find the axles an easy DIY. The W204 is majority W203 under the shell with tweaks.
So 100K for front and rear differentials, anything else under their that should have its fluid changed? Or anything else you think MBUSA is compromising anywhere in the car?
To summarize:
1) Front and rear 4matic differentials are advised to be flushed every 100k miles.
2) Change engine oil and filter every 10k miles (duh!).
3) Perform transmission fluid flush (which simultaneously flushes transfer case for 4matic, as they are connected) and replace filter (also make sure torque converter housing is drained via separate drain plug) every 39k miles.
4) Perform brake fluid flush every 2 years.
Some of the above maintenance is not "required" but HIGHLY recommended. And no, not recommended like your dealer trying to get a few extra bucks, but recommended as in will save you numerous repair bills and headaches down the line/out of warranty.
I would also like to add that at the same time the brake fluid is performed, I would also do a laser alignment and 4 wheel road force balancing. In my experience, in my areas (with the terrible condition of the roads) 2 years is just the right amount of time when I start to feel vibrations and my alignment starts to get out of wack. While these may seem "extra" or not needed, if your alignment is off it could give you uneven wear, making even new tires worthless and garbage in a matter of miles 10-20k.
Glyn has also previously recommended to install fluted bolts so you will be able to adjust castor or camber when performing alignments. (This will get rid of slight pulling to right by having a 1 degree additional positive castor on the RHS (so LHS = 9.6, RHS = 10.6 degrees) due to camber in the road surface, even if your alignment was just done and is good).
To summarize:
1) 4matic differentials are advised to be flushed every 100k miles (front and rear).
3) Perform transmission fluid flush and filer (as well as torque converter housing) every 39k miles.
It may be considered "lifetime fill" but as our experience tells us, this shouldn't be (transmission fluid was once considered lifetime fill). It is always a good idea to do at LEAST one flush, just to get any debris and some fresh fluid in there. But I would do it every 100k miles (if the car lasts till the 200k mark) and every 39k for the transmission.
I am not sure if the transfer case flush for 4matics is listed in the maintenance manual. It may be considered "lifetime fill" but as our experience tells us, this shouldn't be (transmission fluid was once considered lifetime fill). It is always a good idea to do at LEAST one flush, just to get any debris and some fresh fluid in there. But I would do it every 100k miles (if the car lasts till the 200k mark) and every 39k for the transmission.
1. 7gtronic has the transfer case integrated into the same bellhousing as the tranny. so this shares with the tranny oil
2. w204-4matic have front and rear differentials. its listed in the manual for the oil amount and weight....
please get ur information right......
the point of the thread is about differential oil change. i think i read somewhere that it is lifetime, but i need to recomfirm. no harm getting it changed every time u do tranny change.
US Service 20
Required
once at 39,000 mi:
" Automatic transmission > Oil and filter
change
Transmission 722.6 AP27.00>P>2702I
Transmission 722.9 AP27.00>P>2702W
" Transfer case > oil change (4MATIC models) AP28.00>P>2801P
However, this may just be for the e-class, where I obtained my information. I'm not really positive on the w204 as I haven't had to do the service yet...
So what you're saying is that the transfer case for 4matic is integrated into the transmission fluid housing, but that there are two separate (front and rear) differentials for w204?
qaz - Please treat respected members of this forum in a polite fashion.
This can either be specified as mileage or time, or you can undertake an analysis program that is only practical in fleets.
US Service 20
Required
once at 39,000 mi:
change
Glyn-
Any confirmation on whether the 4matic transfer case is simultaneously drained and refilled with the main transmission drain/fill hole?
Glyn-
for those people that are confusing transfer case from differential they are different. i have not found any maintenance info, but they say is forever.....
