Starter Fuse ?
Good luck.
I'm not sure which fuse the OP is talking about, it could be the pyro-fuse that is like an SRS system component and likely needs diagnosis tools to reset control units if this fuse has blown.
FYI
this pyro-fuse its actually The whole box where you can jump the car with . It has a “positive” nipple attachment where you anchor the positive jump cable at …It seat close to the battery compartment
Start enable fuses are 31, 52 & 57. 52 usually blows & should be upgraded from 15 amp to 20 amp if your starter motor ever refuses to turn over.
The other device is a high power fusible link designed to prevent a car fire etc.
Thank you
FYI
