Ticking/Clicking noise during acceleration
C300
I have a 2008 C300 7AT, 60k miles. I recently found some high frequency clicking/ticking noise coming from the engine compartment when I accelerate a bit hard, especially at lower RPM (say <2k), but sometimes happens at >3k RPM too. The noise will be gone in 1-2 seconds, but often comes back when I step on gas hard again. I cannot duplicate it at idle by revving the engine. I have been always using premium gas.
Does anyone have similar issue?
Is it cold out when this is happening? More specifically... are you heating your car while this is happening? I have a similar noise in my car that I am 100% sure is the blower fan to my heating unit, only occurs when I am heating my car and during acceleration... something with the utility belt more than likely?
C300
no, it is there even i turned the fan off. i am suspecting the belt, but it does not make sense since i cannot create the noise when it is idle.
Got something similar like you Raceway, constant annoying flaps noise at accelerating and decelerating. No noise when cold though, start flapping up when worming up. Can be from the gear box? Any help really appreciate.
I know the original poster posted this question a while back but i used to have the same problem in my 2009 C300. I found that when I ran regular gas, the car would make a ticking sound when I accelerated hard. When I started using premium gas, the ticking completely went away. Occasionally, my wife will forget and fill it up with regular gas. When that happens the ticking sound come right back.
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
![Wink](https://mbworld.org/forums/images/icons/icon12.gif)
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Knock, pinging, preignition, detonation by whatever name you know it. Should not happen with high octane fuel. Can be destructive.
When next at the dealer ask them to check that your ECU is set on a more forgiving map. So that it can adequately retard the timing when the knock sensor detects the onset of knock.
Only possible with a Star.
1 Post
2015 Mercedes Benz C300 4Matic
Exactly my issue with a 2015 C300.... When i accelerate hard, I hear a click/ticking sound right before it speeds up.
SLOBENZ (07-08-2020)
did you ever figure out what it was !?! I have the same problem! I have no cel !!!! It makes me lose acceleration after the clicking sound !!!!! The dealer couldn’t find the problem and I got charged for no reason 😡
Something like that?
Same problem!
Originally Posted by DIBAJ;[url=tel:8667514
8667514[/url]]Same problem here! I've had an other engine problem, got it rebuilt, sound went away but started hearing it again about a week ago. Anyone figured it out? I almost want to sell the car because of its mechanical problems.
Was it the utility belt I can’t replicate the noise when I put it in neutral and rev
