Flat spots on tires after letting car sit
Old Jan 8, 2014 | 04:43 PM
c3002008's Avatar
C300, ML350
Hello,
I noticed that my car shakes for the first miles if I drive it after letting it sit in my garage for weeks. I believe this is the result of flat spotting, correct?... Do any other c300 sport owners have similar issues? any ways to prevent this?
Old Jan 8, 2014 | 05:18 PM
ChitownBabyBenz's Avatar
2009 MB C350 Sport
Anything you let sit for period of time will have that problem. I store a motorcycle in the garage and I move it few inches at a time once every week to avoid flat spots. Some people use jack stands or such. Unfortunately there is no way to fix it once it's done - you need new tires.
Old Jan 8, 2014 | 07:18 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Our car sat for over 6 weeks whilst o/seas & there was no sign of a flat spot. They were Michelin Primacy HP. The weather was mild.
Old Jan 8, 2014 | 07:20 PM
Sportstick's Avatar
Another round of ICE
If you want to get more involved, you can minimize this result. New vehicles are shipped with higher tire pressure (don't go past max cold shown on sidewall) because not only do they sit for unknown periods, they are tied down on haulers/rail cars under pressure which adds to the tire-flattening effect. Part of a new vehicle pre-delivery prep is pressure reduction to the proper setting.
You could pump up the tires to the sidewall max before you leave for weeks and then reset when you return. You would want a portable air compressor in your garage for this ongoing process. This would reduce the flat spot effect, but might not eliminate it.
Old Jan 8, 2014 | 07:51 PM
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
I think the OP was talking about temporary flatspotting which goes away after a few miles of driving once the tires warm up and return to their regular shape. I've experienced this on our C300, but it is even more pronounced on my 530i. The BMW's steering is so sensitive, even the slightest deformation clearly manifests itself through the steering wheel. I can detect the tires flatspotting even if the car only sat overnight.
Old Jan 8, 2014 | 08:27 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
I have had flat spots on my Toyo Proxes on my G35 coupe from letting it sit for to long, they went way after driving it for about 50 miles on a warm day.
Old Jan 8, 2014 | 09:26 PM
Glyn M Ruck's Avatar
Super Moderator
Flat spots are inevitable with standing. SS's pressure advice is good.
Some tyres are far more inclined to do this than others due to carcass construction & steel belt behavior. In my experience Michelin tyres seldom do this due to soft carcass philosophy.
When initially driving on flat spotted tyres after standing do not drive fast until they have settled or you can induce peculiar wear.
Old Jan 8, 2014 | 11:16 PM
c3002008's Avatar
C300, ML350
thanks for the replies... yeah I was talking about temporary flat spotting that goes away upon driving the vehicle for few miles. I will take SS's advice on adjusting the tire pressure when I let my car sit. thx
-- I was searching the internet and I came across this product called tire cradles (tirecradle.com) which prevent flat spots, it costs 350 bucks for set of four...
but I think for now I will just stick with overinflating tires when I let my car sit for any extended period of time.
