2014 W204 C250 P2015 CEL
Old Nov 17, 2025 | 05:59 PM
e46_connoisseur's Avatar
Mercedes C250
Hey guys,
I just went to an Autozone after getting my first-ever CEL in this car. The readout is
  1. P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance Bank 1
  2. P2015: The Position Sensor or Position Switch For The Charge Movement Flap (Cylinder Bank 1) Has A Malfunction.
  3. P2016: The Position Sensor or Position Switch for the Charge Movement Flap (Cylinder Bank 1) Has A Short Circuit To Ground.
The car shifts smoothly, accelerates normally, and has a normal idle with no shudders, etc. If the light wasn't on, I wouldn't know anything is wrong.
What does this mean, and what needs to be done to resolve this?
The mechanic I went to recommended I take the car to a Euro shop and replace the entire intake manifold, but since the car is functioning normally, that seems overly expensive.
Old Nov 17, 2025 | 09:50 PM
TimC300's Avatar
What engine is that? or what is your vin?
The codes are for a sensor so I would start there.
Old Nov 17, 2025 | 10:35 PM
Mercedes C250
It's a 1.8L 4cyl turbo. I believe designated m271, but not sure.
Is there even a sensor to buy? When the mechanic was looking at OEM parts, all he could find was a actuator and intake manifold.
Old Nov 18, 2025 | 12:02 AM
TimC300's Avatar
I have very limited knowledge of the M271 engine.
You may want to get a scanner of your own that may help you diagnose further.
I am totally guessing on what may be the issue. The charge movement flap in the codes listed may be the swirl flap motor (part 60 in diagram)
I came across a thread that mentions a swirl flap hall sensor. Im not sure where that is though: https://mbworld.org/forums/e-class-w...ke-system.html
Old Nov 18, 2025 | 12:05 AM
TimC300's Avatar
Maybe post your question in that thread I linked to. Im sure he will help if he can.
Old Nov 19, 2025 | 12:22 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Nope. That’s a solution for some other MB engines but not the M271. Probably replacing the swirl flap actuator shown by @TimC300 will solve the CEL problem.
Since it appears that you don’t get deep into DIY, do take it to an MB specialist shop for this.
I don’t really know why they include swirl flaps on DI engines as there’s no mixing of fuel. It’s just air. But I’m not that kind of engineer and it turns on the CEL when it fails, so you have to fix it.
Old Nov 19, 2025 | 12:38 AM
Mercedes C250
Thanks! I posted in that other thread, and he confirmed the Swirl flap = Charge movement flap and the position sensor is I presume inside the motor housing.
Old Nov 19, 2025 | 12:51 AM
Mercedes C250
Yep, I don't have time or the tools to dig around. I will take this knowledge to a Euro shop and see what they say.
I think @TimC300 was right as well.
So the TLDR: there is a sensor in the swirl flap actuator that could be bad or the actual swirl flap actuator went bad?
Old Nov 19, 2025 | 01:31 AM
TimC300's Avatar
Appears confirmed the swirl flap position sensor is in the motor housing. The motor looks to have 5 pins which matches the electrical diagram kindly posted in the above linked thread..
I think with the appropriate Mercedes specific scanner you can see what the sensor is reading, is it within spec or is it not reading at all. Can also actuate the motor it seems 0-100% with the scanner and see if it is functioning.
I was not aware how the M271 intake worked until reading thru the linked thread above. Im familiar with the M272 engine that has swirl flaps and tumble flaps in the air intake.
Quick overview of swirl and tumble flaps:
Old Nov 26, 2025 | 11:20 AM
Mercedes C250
Hi,
The shop I took it to claims there is significant carbon buildup in the intake manifold assembly and wants to replace the entire manifold as well do walnut blasting of the valves. Is this reasonable?
I asked about just replacing the actuator, and they said it would break as the carbon build up becomes more severe
Old Nov 26, 2025 | 11:55 AM
Odd Piggy's Avatar
If the carbon build up is significant, walnut blasting may be appropriate. I had it done once on mine at 75,000 miles when it was apart for other work. I can’t think of any reason to replace the intake manifold. Seems like that could be cleaned up in the solvent parts cleaner or with carburetor cleaner.
Old Nov 26, 2025 | 12:12 PM
Mercedes C250
Ok, so the intake valves can be walnut blasted, but intake manifold has to be cleaned in a different manner? Will cleaning the intake manifold with solvent parts cleaner or with carburetor cleaner be any easier? Do you still need to take off the intake manifold (at least you don't to replace it but still the labor costs) and how much extra labor is involved with cleaning it versus installing a new one?
Edit: manifold is plastic so it cannot be walnut blasted
Old Nov 27, 2025 | 12:45 AM
Odd Piggy's Avatar
The intake manifold has to come off to do the walnut blasting anyway. The shop may consider replacing it less expensive than labor to clean it. I don’t know if my indie cleaned it or not. If you clean the intake manifold yourself, stick to petroleum based solvents. The Berryman soak can is too harsh and might cause it to become brittle.
