ABS ESP ESC Inoperative, Power Steering Malfunction 2010 MercedesBenz C300 Sport W204
The common culprit is a bad wheel speed sensor, cracked reluctor ring, or wiring problem to one of the wheel speed sensors. But you have ESC control unit faults that look valid. The low voltage could trigger the other two. Getting your own dedicated MB scanner would verify the parts store scan. The low voltage needs to be verified with a voltmeter. The ESC control unit can go bad, but it’s not all that common.
@TimC300 has a very similar car, so if he pops in, listen to his advice.
Then fixing should not involve replacing any good parts... pay attention to status: stored or active ?
With that you should be able to see what wheel is acting up.
It's always possible that ice is nothing the sensors if your in a state that got snow recently.
sensors
The starter battery could use a good float-charge but it's not bad.
The Alt. is powering the whole car with better than 13Volts.
Try to never use battery power while the engine is stopped. The chassis is really power hungry: the radio + amp is a high load.
1st time I was actually on my way to get my cars yearly inspection when it came on. I turned around and got my scan tool and erased the code. The warning came on again while driving so pulled over and erased the code again. It finally stayed off so I immediately got my car inspected.
Then it started coming on again this past September. I stopped to get gas then the warning popped up. It kept coming on after starting the car and reaching around 15mph. This went on for 5-7 days maybe then just went away.
I was not too concerned because the car drove exactly the same, no loss of power steering. If the car did drive differently then I would have been more concerned. if the warning kept popping up i was looking in to two options:
1- Buying a used module and trying to reprogram it to my car using a Launch obd scanner. I currently have a Foxwell scanner and while it does alot it only lets me read the module and not make any changes. I have read that launch scanners have more capabilities.
2- Sending my module out to a repair shop that specializes in these things.
steering + ESP/ABS.
ESP transient fault is stored!!
Foxwell showing wheel sensor issue, right?
What's the steering module saying?
Seems like CAN disruption...
The only fault code was the 5001 for internal fault of N30/4.
When I was seeing the warning coming on this last time I was thinking the fault code was telling me what was wrong, there is an "internal fault" in the module. Something wrong with the software or circuit board. Damaged circuit boards are a bit out of my comfort zone for working with.
I found a few places to send the module out for repair when looking thru the W221 threads. A few people had good luck sending them out for repair. I forget the names and would have to go look again.
ESP electronic module
Make sure this is not referred troubles over CAN-C from other modules.
So yes, I followed the advice and cleared the codes. The ABS message did not pop up for one day and then the next day it came back.
I was gonna take my battery to get replaced under warranty, (turns out it didn’t have one), and when I installed the same battery back, the message disappeared! And this time it has not came back since then. LOL. So hopefully it stays like this because I was honestly sick of those stupid dings and messages popping up on the cluster.
I’m guessing the battery needs replacing, and probably soon. I live in a city in Texas where the temperature fluctuates in the winter, and we have really hot summers and I read that temperature kills batteries.
Check your batteries !!!
For those that don’t know, you can access that secret menu by holding down the red hang up button, the # button, and the 1 button at the same time for around 5 or so seconds. (This is for the preface lift w204)
thanks for sharing your knowledge and advice with me guys!
Made a thread on it here: https://mbworld.org/forums/c-class-w...sted-5yrs.html
When I bought it at the MB dealer i made the mistake of not looking at the manufacture date until I was already home, turns out it was already 15 months old and I think it wasnt in the best condition. learned my lesson. This time I bought an H7 AGM battery at Walmart. The battery is great so far.
I have an inexpensive battery tester and im impressed with how it works. When I first got it I wasnt sure how accurate it was since I had nothing to compare it to but then testing the clearly bad battery and then the brand new battery the results seem pretty spot on.
Testing the old battery:
Testing the brand new battery:
Variable alternator voltage does not always operate well. It can sizzle batteries with 1300.Watts (14.9V, 90A) without any DTC.
Use the Dasboard Display: "Shop menu" (aka. "secret menu") to visualize live voltage from 12.6 to 14.9V= ok!
