Burmester Sound System for the C Class (bass/subwoofer)
Anyways, I was really surprised to see that there is actually no designated sub for this system! Can anyone confirm if the image attached is correct for the C? When I test drove the C450 a few months ago, the system sounded great, and the bass did sound quite full... but was still surprising to see on this document that there's no subwoofer at all for this upgraded sound system...
Anyone that listens to music with a lot of bass, are you happy with the sound?
I listen to mostly EDM and some hip-hop/pop music
My last e90 LCI had no subwoofer per se, it had the two woofers under the front seat, but on high end multispeaker systems such as the burmester the balance is great so you technically do not need a sub
The system doesn't lack bass (unless you want bass that can blow out windows) but imho can be a bit thin/harsh on vocals.
it's like the subs cannot keep up with fast paced music.
now for everything else the burmester does not dissapoint. i usually don't hold high hopes for stock "premium systems".
i've had aftermarket amps, subs, and interior tweeter on my previous ride. any decent aftermarket setup will make even $50k optional premium stereos sound bad.
only stock premium system i heard that actually sounded good was the mark levinson on a LS460. very balanced.
anyone heard the bang&olufssen on the higher end audis? i hear those are pretty dope too
Last edited by RobInBoston; Sep 16, 2019 at 07:09 PM. Reason: added point about EDM
