COMAND 10.25" Screen Upgrades
Old Oct 5, 2018 | 02:17 PM
  #326
eling23's Avatar
soon-to-be 2018 glc43
Originally Posted by zippi
I asked the seller if the adapter can support my car.
His answer:
"Unfortunately this adapter was not tested on C class.
The following item will work
https://car-solutions.com/en/aux-mod...5.5-system.php
That's strange as the description of the item on the website list C class as one of the compatible cars.
I got a response back from the technical support and they indicated that it should work on my car. I took the chance and just ordered it. I'll let everyone know how it goes once i have it installed. Hopefully it will work and also take care of the video/audio delay.
Old Oct 6, 2018 | 04:16 AM
  #327
fgarcor's Avatar
Mercedes w205
​​​​​​ Which car model and manufacturer year do you have?
Old Oct 6, 2018 | 04:24 AM
  #328
fgarcor's Avatar
Mercedes w205
I found a similar device:
https://www.car-interface.com/vendita/en/obd-encoders-for-mercedes/608-aux-icon-activator-mercedes-comand-online-ntg5-205222.html
But I queried directly Caraudio-Systems, as they seem to manufacture it instead of being resellers, let's hope that they can tell whether it works. From my point of view I don't see the reason why not.
Old Oct 11, 2018 | 02:02 AM
  #329
eling23's Avatar
i finally got around to installing it! hardest part was figuring out the best way to run the wires. Thanks to all the info here, it helped a lot. Does anyone know how to change the screen resolution? I have the 8.4 inch OEM navi screen before. When I goto the usb-car icon the OEM screen shows up on the right side with a generic car picture on the left. The OEM screen is zoomed in a lot thus making the a lot of the menus unreadble. I tried to goto the car info icon and change the parameters for the display but the only options are 1,2,3,4,5. None of them fixes the problem. Is there somewhere else I need to go? thannks!
Old Oct 11, 2018 | 02:55 AM
  #330
eling23's Avatar
actually nevermind. Didn't know you could scroll down. #7 worked for me
Old Oct 11, 2018 | 04:10 AM
  #331
eling23's Avatar
Update on the aux-in. So I ordered that OBD activation and plugged it in. Within a few seconds the unit restarted and the Aux-in menu appeared. Due to timing I did not connect the cables in the back the HU yet. Will do it tomorrow and report back. Btw I have a 2018 GLC43 but from what i've been reading, the audio and navi portions are exactly the same as the w205 which is why ive been coming here for more info.
Old Oct 11, 2018 | 02:42 PM
  #332
zippi's Avatar
S205
Sounds promising!!!! The delay between video and sound annoys me more and more.
thank you for being the patient 0 !
Wait for your full feedback.
Rgds
Old Oct 13, 2018 | 09:27 AM
  #333
Pazevedo78's Avatar
Glc coupe 250 4matic
Do you have sound delay issues?
What screen did you buy?
Old Oct 13, 2018 | 01:42 PM
  #334
Pazevedo78's Avatar
Android 8. 4gb RAM
What do you guys think of this:
Ouchuangbo 10.25 "Android 8.0 car radio
https://www.aliexpress.com/store/pro...628f6c35fspqlB
True android 8
4gb RAM
Is it worth it?
Old Oct 13, 2018 | 05:01 PM
  #335
zippi's Avatar
S205
I didn't choose this one, cause the stock car system display is stretch to the entire screen, and it looks awfulll. IMO, the integration between stock system and Android is better with our Android 7 unit (actually Android 6, despite of what is displayedin settings menu).
Old Oct 13, 2018 | 05:05 PM
  #336
Pazevedo78's Avatar
Yes, i think the same. It looks much better in the android 7 units.
Just thinking if the 4GB RAM won't make the difference...
Old Oct 14, 2018 | 11:39 PM
  #337
dacia's Avatar
2014 E350 station wagon gasoline
The new 7.1 Android comes with 64GB of storage and 4GB of memory and a better screen.
However it is about $200 more from what I have seen.
Old Oct 15, 2018 | 06:25 PM
  #338
Pazevedo78's Avatar
Any news?
Old Oct 18, 2018 | 11:25 PM
  #339
eling23's Avatar
Any news?
Sorry been away busy at work, I wil test it tomorrow, I just have to take my dash apart and hook up the L+R RCA cable and run it to the screen to test.
Btw, can the unit play songs off my iphone when i have it plugged into theusb? if so how do i do that? thanks
Old Oct 20, 2018 | 02:11 AM
  #340
zippi's Avatar
S205
Don't know, I play my phone mp3 trought BT.
Old Oct 20, 2018 | 08:43 AM
  #341
zippi's Avatar
S205
Hi,
I received the USB adapter and I can confirm that it fixes the latency issue between video and audio I've had with the Bluetooth adapter.
However, still have the issue with the unit bluetooth phone. The people I call still ear an echo of their voice.
I thought the problem was related to the Bluetooth adapter latency, it finally appears it isn't.
I'm curious to know if using AUX solves this problem.
Old Oct 22, 2018 | 04:13 PM
  #342
Pazevedo78's Avatar
hello,
I have the first one (BT adapter).
and I want to try the second one (usb).
Hi,
With the usb adapter you have to connect your phone in usb socket? How does that work.
Hi just received today the package, and I'm getting ready to avance to the installation.
But I don't understand this usb adapter. Is for what?
Old Oct 22, 2018 | 04:27 PM
  #343
zippi's Avatar
S205
The unit has to be connected to the car so the audio from the unit goes out throught the car speaker.
For that, you have a bt adapter (so you connect the unit to the BT of the car) or a USB adapter (so you plug the USB adapter to one of the usb port under the central armrest.)
Old Oct 22, 2018 | 05:30 PM
  #344
Pazevedo78's Avatar
So I connect this usb adapter to one of the usb ports in arm rest?
And doing so I resolve the sound delay?
Thanks!
Old Oct 23, 2018 | 01:53 AM
  #345
sentralfyr's Avatar
2015 S205 AMG
Thanks!
Thats correct,The USB adapter should be connected to one of the USB port in the armrest.
You can try to download an app called KODI, here you can adjust the delay of sound in videos.
KODI
Old Oct 23, 2018 | 07:36 AM
  #346
Pazevedo78's Avatar
KODI
But conecticon via usb solves or not the delay?
If we still need to use Kodi to sync the videos with the sound, the connection doesn't solves anything...
Sorry but imI not getting it! ☹️
Old Oct 23, 2018 | 07:57 AM
  #347
Sly_North's Avatar
GLC X253
The discussion to which you're replying started with...
I received the USB adapter and I can confirm that it fixes the latency issue between video and audio I've had with the Bluetooth adapter. [...]
Old Oct 23, 2018 | 08:03 AM
  #348
Pazevedo78's Avatar
Yes. I got that. 😁
But then sentralfyr said to use Kodi... That's what puzzles me.
If there's no lag we don't need to fix it!
Thank you all.
Next weekend I will see... 😁
Old Oct 24, 2018 | 01:34 AM
  #349
eling23's Avatar
ok i finally got around to connecting the aux to the screen. Happy to report everything worked. No lag whatsover. Also to note that the audio quality from the aux is way better than from the BT module. Before when i'm playing music using the BT module the volume would be somehwat low. Had to try to find some balance b/w the volume from the screen and volume from the HU. But since our HU doesnt have a volume level status it was hard to gauge how far it was turned up. Will do more testing in the days to come.
Old Oct 24, 2018 | 02:09 AM
  #350
eling23's Avatar
i am looking to order the usb carplay dongle. There's so many diff ones on aliexpress with a range of prices. Do the dongles work for ios12? Can someone give me a rundown of how it works and if it works well? Im understanding that you have to download the carplay app from the playstore first? I would like the latest carplay version for IOS12 if possible. Thanks!
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
