COMAND 10.25" Screen Upgrades
Rating: Thread Rating: 3 votes, 5.00 average.
Old Nov 21, 2018 | 04:42 PM
  #401
Andrew Maddox's Avatar
2015 C300
Originally Posted by eling23
The carplay that from the usb dongle will not work with steering wheel control and center rotary knob control which sucks... It doesnt even allow you to adjust the volume. This is a pretty slick screen but i come to find out it's not really for me because I like to do everything from my iphone, whether it be streaming spotify or songs from apple music. I tried using the spotify app on the unit itself, it's ok, but again the control using the control knob is not really well integrated. I have to do everything via touch screen mostly unless im playing music from a usb or its hard drive. It's just my personal preference. I can see why others would like it. No delay issues for me as i've activated the aux input in my car..
how do you adjust volume then? so the only thing you can do is the oem settings w/ the knob and wheel? everything else is touchscreen? changing songs on the carplay is touch screen too?
Old Nov 21, 2018 | 05:18 PM
  #402
eling23's Avatar
soon-to-be 2018 glc43
Ok my statement may have been a little confusing. When the carplay dongle is inserted via usb and your iphone is hooked up, the control knob and steering wheel controls do not work. For volume, the normal volume buttons still work because the sound is being routed through the OEM HU. You will probably have to adjust the android screen's default volume for the USB input so that it plays at a respectable volume. If the android unit's default volume for the USB is too low and you adjust the volume on your OEM HU up too high using the OEM controls, you get some distortion and degraded sound quality (note: this is from my experience only and others may have different experiences). There is no volume slider within the carplay app. But in terms of maneuvering around the main carplay screen and even within the apps within carplay (and changing songs), it's all touchscreen. From my research there seems to be a black colored usb dongle out there that has some steering wheel integration, but it's not that refined.
Old Nov 26, 2018 | 10:17 PM
  #403
junichi's Avatar
W205
Originally Posted by zippi
Hello,
Do you figure out to make "ok Google" works on the head unit?
On my device, the voice match option is locked, so I cannot activate "ok Google" on any screen.
When I start the Google app, the "ok Google" works from the Google search interface... But it will be terrific if it can works from any screen.
Same on your side?
I have 2017 W205. I will not replace OEM screen with this after market screen until it supports "OK Google". I want to have similar experience with MBUX in my old car.
Old Nov 26, 2018 | 10:44 PM
  #404
ItchyTasty's Avatar
2015 C300 Sport
Just ordered this. 9.33 in version, because the aspect ratio is better than the 10.25 in my opinion.
Regarding the install, what tools are needed? From what I've seen, a T15-torx screwdriver, pry tool, and a Phllips screwdriver. Is that all? And optionally, a piece of tape to stick the GPS antenna to the center dash speaker grill?
Also, regarding the Burmister system, am I correct in saying I specifically have to unplug the fiber optic connectors and plug them into the new connector? Everything else is "standard" in that I don't have to do anything special?
Old Nov 28, 2018 | 12:06 PM
  #405
Mike012992's Avatar
c300
don’t buy
Just letting everyone know my experience with these larger screens. I currently have one on now had it for about 5 months no issues till about 3 days ago when I try switching over to my oem screen it doesn’t work it’s just on a black background and now not even the touch pad or the buttons around it work I can’t even turn off the auto start thing it’s completely powered off I can’t play the radio or connect my phone but when I switch over to the android screen that still works fine and now today the backup camera doesn’t want to display anymore it is such a pain im thinking my best action is to put my oem screen back on hopefully it will all work again and if it doesn’t I will go straight to dealership acting like idk how this happened I have a video of this but not sure how to upload it here
Old Dec 13, 2018 | 07:16 PM
  #406
dacia's Avatar
2014 E350 station wagon gasoline
Have you contacted the seller?
It comes with a one year warranty, doesn't it?
Old Dec 18, 2018 | 12:47 AM
  #407
sentralfyr's Avatar
2015 S205 AMG
Anyone tested the DVR function yet?
I have ordered this one, it says it supports AV-OUT
https://www.aliexpress.com/item/SINO...42aa4c4d3pis9A
Old Dec 22, 2018 | 12:25 PM
  #408
sentralfyr's Avatar
2015 S205 AMG
I have now updated my screen to the latest software.
Not tested yet, just installed
If anybody need the files, you can download it from HERE (install on your own risk!!) it work perfectly for me
Old Dec 26, 2018 | 11:45 AM
  #409
bngu1's Avatar
2019 E300
Anyone have the Mercedes Benz boot screen they can share? i have the AMG boot screen and don't really like it much. thanks
Old Jan 3, 2019 | 01:59 AM
  #410
sentralfyr's Avatar
2015 S205 AMG
Here is a link for Mercedes Boot Screen
Old Jan 3, 2019 | 07:07 AM
  #411
sentralfyr's Avatar
2015 S205 AMG
https://www.aliexpress.com/item/SINO...3da24c4dUXaNmm
SSINOSMART DASHCAM
Bought and installed this DashCam
Connectet the power cables to left side fusebox with
I used these two fuses with piggyback connector, im not sure yet if this is correct, these are fusenumber 219 Weight sensing system (WSS) control unit and 204 Diagnostic connector, maybe i have to switch places on them
Only got i to work with Miocam application on the screen, but not with the DVR Button on the screen with cable
Pictures of the DashCam
Old Jan 4, 2019 | 08:18 AM
  #412
sentralfyr's Avatar
2015 S205 AMG
Got i to work now!!
Had to use the DVD AV connector
And i also have to figure out how to change time and date( Date and tim adjusted itself to be correct suddenly)
Old Jan 5, 2019 | 07:44 AM
  #413
sentralfyr's Avatar
2015 S205 AMG
Here is a Night video when the camera is in use
https://www.youtube.com/watch?v=Qum5...ature=youtu.be
Old Jan 6, 2019 | 12:27 PM
  #414
TorbenK's Avatar
C220D W205 Estate
Looking good sentralfyr.
Nice work 👍😊👌
Old Jan 6, 2019 | 04:56 PM
  #415
Christion's Avatar
2016 c300
Do those of you with the 10.25" screen have issues with android auto automatically switching to night mode with the carplay dongle?
Here is an app on the play store that resolves that issue. It is a background app that can't be opened. It's based off the sunrise and sunset times in your time zone. Sometimes if you restart your phone and the app isn't working, you just click on it and you'll see a new notification for your sunset and sunrise times.
https://play.google.com/store/apps/details?id=gb.aahelper.hr
Old Jan 6, 2019 | 10:00 PM
  #416
Christion's Avatar
2016 c300
Buzzing noise on 9.33" screen fix
I used a vibrator to find the buzzing noise that this 9.33" android screen was making. For those who bought this screen, I added felt tape next to the plastic blue port and in between the metal and plastic. This stopped the noise. I pulled this screen out and put the old one back in out of frustration. After a couple days I absolutely couldn't stand the garmin sd card navigation, lack of android auto and the overall god awful infotainment system, and figured I'd give this one more try if I could fix it. My 15 Hyundai Sonata had Android Auto and a bigger screen. I can't believe that it's taken until now for Mercedes to make led lights and android auto standard on expensive luxury cars. Why would any luxury car not have things like that standard? Even a base c300 should come standard with the larger comand screen, because you can spend a lot less and still have a larger screen than this midget tablet mounted to the dash. Mercedes makes a beautiful car and I love the design, but they severely fail at infotainment systems.
I bought this version instead of the 10.25" screen because it has 3gb instead of 2 and android auto displays properly on it. From what I've seen, android auto looks stretched out on the lower resolution 10.25 wide screen.
Old Jan 7, 2019 | 08:03 PM
  #417
ItchyTasty's Avatar
2015 C300 Sport
Unfortunately it only has celcius/kph unlike the android 8.1 version from dmpcardesign. I'm checking with the seller (Shenzhen Merryway Technology Co., Ltd) to see if they have a newer version yet.
I have the 9.33 in screen, and mine has Farenheit and MPH. Here;s a link to what I bought: https://www.aliexpress.com/item/9-33...3fd97107IJ24Rg
Old Jan 7, 2019 | 09:31 PM
  #418
Christion's Avatar
2016 c300
I applied an update last night and the seller just showed me where the new mph/Fahrenheit settings are. Thanks for the reply!
Old Jan 8, 2019 | 12:12 AM
  #419
ItchyTasty's Avatar
2015 C300 Sport
Cool, glad to hear it. Let's keep in touch. I feel like us 9.33 inchers are a rarer breed here and the software is a bit different so maybe we can help each other out with settings and such. FWIW, I've seen both screens in action, and the 9.33 wins easily from the aspect ratio alone. I would never buy the 10.25in version after seeing how it looked in comparison.
Old Jan 11, 2019 | 08:24 PM
  #420
Christion's Avatar
2016 c300
Can anyone with the 10.25" screen take a picture of android auto running on it so we can see exactly how it looks?
Old Jan 11, 2019 | 11:54 PM
  #421
ShakyTom's Avatar
C43 AMG Coupe
Fellow 9 incher here
Old Jan 12, 2019 | 12:59 AM
  #422
Christion's Avatar
2016 c300
Old Jan 12, 2019 | 08:20 AM
  #423
fgarcor's Avatar
Mercedes w205
Find two options: with the dongle, the screen is completely stretched. With the HUR application (no need for dongle) you can choose whether you want it stretched or just the natural size of Android Auto.
And the third picture is Android Auto with the Google assistant. You can see the format fits perfectly fine in a 10" screen, but this is not yet available.
Old Jan 12, 2019 | 10:01 AM
  #424
Christion's Avatar
2016 c300
[QUOTE=fgarcor;7652183]Find two options: with the dongle, the screen is completely stretched. With the HUR application (no need for dongle) you can choose whether you want it stretched or just the natural size of Android Auto.
[/QUOTE
Wow, thanks for the awesome reply! If the widescreen version of android auto was out or at least has a release date, I would have bought the 10.25" screen instead. It has much better support from great sellers like carlife mall.
Here is a picture of android auto through the carplay dongle displaying perfectly on the 9.33" screen.
Also, with the newest carplay app and dongle updates, you can program the command knob or other buttons in your car to skip songs, play songs, summon google or siri voice, etc. It's fantastic. I can now skip songs without touching the screen while I'm using google maps. I don't have to worry about the screen hearing me say, "ok google" when the music is up and I'm on the highway.
Old Jan 12, 2019 | 11:26 AM
  #425
ShakyTom's Avatar
C43 AMG Coupe
Is the dongle better than using head unit reloaded if you just want to use android auto?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
