Most tire wear, front or rear
Old Sep 27, 2019 | 12:19 PM
dennish's Avatar
1992 MB 190E, 2016 MB C300
My 2016 CPO had the front tires replaced by the dealer when purchased 4k miles ago (RWD17" all around).Rears were slightly worn. I want this set of tires to wear out evenly so I'm thinking I should put the new ones on the rear. My previous cars wore the rears more than the fronts, but my local tire shop advised me that the fronts will wear faster than the rears. Do these cars wear the rears faster than the fronts.
Old Sep 27, 2019 | 01:40 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
If your tires are all the same size front and rear, you can just rotate the tires every 5-10k miles and you should have even tire wear.
Old Sep 27, 2019 | 02:33 PM
GreekUPS's Avatar
‘15 C300 4M Sport, ‘20 GLC300
I have 4 Matic with staggered wheels, the fronts are wearing way faster than the rears.
Old Sep 27, 2019 | 07:13 PM
Anstormning's Avatar
2018 C300 Sport
I have a 2018 RWD with the sports package, staggered. Replaced the oem tires last week, both rears were around 2/32, front were 4/32 right and 5/32 left.
Old Sep 28, 2019 | 12:07 AM
GreekUPS's Avatar
My front right was also more worn than my front left, is this normal for the C300?
Old Sep 30, 2019 | 08:25 PM
ntdss's Avatar
c300
2009 c300 Sport, staggered wheels with 75K miles, rear worn out faster than front.
Old Oct 1, 2019 | 12:36 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Do point out OEM other than "tire rotation" there is only Toe "directional" adjustment. No Camber or Caster to allow to adjust tire contact angles to compensate for other than showroom height conditions.
Example day to day commuting encountering high cambered roads, altered height / wheel squat through load carrying, lowering or worn bushings. Fitting wide profile tires, curb knock damage.
Both "deletion of adjustment" and increased "within specs parameters" is all to do with ever increasing speed of vehicle assembly lines.
We saw the need therefore to re-instate from the early 90's once again full, precise adjustment. Front Camber and Caster, Rear Camber (and extra Toe to compensate for the new Camber facility). Fixing it right the 1st time - RESOLVING COSTLY, PREMATURE EDGE TIRE WEAR AND HIGHER IMPACT LOADS - which can also lead to increase in ruptured side walls and rim damage.
Adjustment kits are designed to replace at same time, the 4 front and rear highest wearing suspension bushings ..Unique patented KMAC design - precise "single wrench" adjustment. Accurately (under load) - direct on alignment rack.
C180 - 350 #502816 K $480
C300 - 450 / C43 4 Matic #503416 K $480
Rear Camber (and extra Toe)
#502226 K $480
Instructions attached
Also manufacture popular uprated bushings for the 6 multi link rear arms. Less rear end flex, twist, loss of traction. Especially when applying power to lane change / overtake #502628 K $480
Delivery $30 one kit. $20 each extra kit
PayPal, Visa or M/Card
https://i.imgur.com/9CZ07Jy.jpg
https://i.imgur.com/90XBvlK.jpg
https://i.imgur.com/jLcPZdB.jpg
https://i.imgur.com/7i6Jk5C.jpg
Old Oct 1, 2019 | 01:38 PM
Alex AL's Avatar
2018 C 300
I have the staggered tires and purchased the car about a year and a half ago and front and rear have worn nearly the same in about 10,000 miles. Depending on how you drive will determine if the front or rears wear faster. If you drive more conservatively then the fronts will probably wear faster, but if you drive more spiritedly like me then the tires awill likely wear faster. I can’t help but break the tires loose when it is wet and I am coming out of a corner.
Old Oct 6, 2019 | 11:30 AM
mikec35's Avatar
2016 C300 sedan
At 102,000 miles my 2016 C300 is getting ready to get it's 5th set of rear tires. I am on my 3rd set of fronts. I drive a lot of highway miles and the rears wear on the outer edges and get real noisy after about 10-15K miles. I've had the car aligned 3 times and it doesn't help the rear wear.
Old Oct 12, 2019 | 11:25 PM
RDO247's Avatar
C63S
Everyone knows Mercedes have issues with premature tyre ware sure to the lack of adjustability in their alignment.
I went through three three sets of tyres in 18 months due to premature wearing of both front and rear tyres but more so the fronts.
Mercedes or the tyre shop cannot fix this through alignment only, saying this Mercedes will still offer to align your tyres and take your money.
The only way way to fix this so your not buying tyres every 8-12 months is to fit camber kits which will allow for adjustment in turn allowing your new tyres to ware evenly.
I have run the K-Mac front and rear camber kits for approximately 2 years which is how long my last set of tyres have lasted me.
Fit this kit now or when you replace your tyres so you get the maximum life out of your tyres.
I did this along time ago and swear by this product, contact Kevin at K-Mac, he’s a wealth of knowledge and will save you a lot of money in the long run.
Old Oct 13, 2019 | 03:15 PM
nick_wass's Avatar
C300 Sport W205
My rear tires wears twice as fast as the front - max 18k miles. No alignment issues - wear is even.
Old Oct 13, 2019 | 04:51 PM
GreekUPS's Avatar
RWD or 4Matic?
Old Oct 13, 2019 | 05:04 PM
nick_wass's Avatar
C300 Sport W205
RWD 19”
225/40/R19 front. Wheel 7.5 J
255/35/R19 rear. Wheel 8.5 J
Old Oct 13, 2019 | 11:41 PM
Mr. J's Avatar
C450, GLC43
My GLC43 chewed up the fronts with only 25,000 miles. The rears are fine. 20" Goodyears.
My C450 is doing OK because I swapped the OEM Conti runflats with Pilot AS3+. They are holding up well but tire wear is still much more noticeable on the front tires.
Old Oct 14, 2019 | 07:37 PM
mikec35's Avatar
2016 C300 sedan
I just put another set of rear tire on my car, that's 5 sets in 102.000 highway miles. The fronts last about 40-50k, the rears start making noise at about 10-14k miles and are so noisy by 18k miles I have to replace them. I'm going to call K-Mac and see if they have a kit for the rear of my 2016 c300. Thanks for the tip.
Old Dec 25, 2022 | 03:43 PM
Headgames's Avatar
Mercedes Benz C class 300 2019
Kevin kmac
can you please tell me how to get Intouch with Kevin at kmac. I to am having the tire problems
Old Dec 25, 2022 | 08:45 PM
RDO247's Avatar
C63S
Old Dec 26, 2022 | 03:31 AM
K-Mac's Avatar
SPONSOR
Hi (XMAS Greetings!)
Have been constantly upgrading and increasing product range. Many new design breakthroughs !
Now virtually front and rear adjuster kits to suit every Mercedes Benz model to 2023 - Sedans, Coupes, Wagons, SUV and light commercials.
All in the pursuit of resolving the situation that OEM there is only front and rear Toe (directional) adjustment.
No Front Camber or Caster. No Rear Camber (and need for addition of extra Toe) to resolve costly, premature edge tire wear.
Brought about through day to day commuting encountering high cambered roads with excess right hand side edge wear. Altered height through load carrying or lowering. Fitting wide profile tires etc.
ALL ALIGN TECHS CAN ADVISE - “have adjusted front and rear Toe to factory specs”! (no resolving of the actual issue of “uneven premature wear”).
C63’S’ FRONT (ALL Models Sedans, Wagons, Coupes)
503316-1i $345 (Both Sides). Less cost then one hi-performance tire. This new kit is Camber only and can be fitted without need for arm removal.
#503316K $480 (Both Sides) above Camber and also Caster. Caster bush - design is Mono ball / 2 Axis providing also significant improvement to brake and steering response.
C 63’S’ REAR
#502326-1K $480 (Both Sides) C63’S’ Coupe Camber (and extra Toe) adjustable. This kit really does set new industry standards. ‘S’ Coupe model (only) has shim adjustment allowing one position 4mm Camber change. KMAC design is precisely adjustable (and like all kits the unique patented design allows precise “single wrench” adjustment! Accurately (under load) - direct on alignment rack and serious adjustment (designed so up to 4 times the one position OEM adjustment). Can be fitted without need for arm removal.
#502226K $480 (Both Sides) All Sedans and Wagons Camber (and extra Toe) adjustable. As above all kits are precise single wrench adjustable. Kit can also be fitted without need for arm removal.
FOR MEMBERS ENQUIRING RE TRACK DAYS / COMPETITION (pursuit of front row of the grid lap times)
Also manufacture:
#503316-2J $380 Front Upper ‘A’ arm inner bushes for extra Camber and Caster.
Precisely adjustable also eliminating the OEM soft rubber and advantage / security of retaining the OEM hi strength forged alloy arms (not replacing with welded, fabricated).
#502628-1J $380 C63’S’ Coupe (Set 8)
#502628K $480 All Sedans and Wagons (Set 12)
Uprated bushes for the “Multi Link” rear arms. Less rear end twist, flex, loss of traction. Especially when applying power to lane change, overtake.
#502226-3M $595 (Both Sides) C63’S’ Coupe.
#502226-1M $595 (Both Sides) All Sedans and Wagons
Rear upper adjustable Camber arms (also extra Toe). Difficult to access (unlike lower arm adjustment) and if adjusting to resolve inner edge wear - reduce important clearance top of tire to outer fender (mainly used to increase negative Camber to allow extra wide tire fitment).
NOTE: XMAS to 1st. of January 15% Discount applies and DHL delivery worldwide is $40 one kit and $20 each extra.
Best Regards, Kevin
Few issues last week re order page not loading. If so can ring our toll free # 1888 847 9099 (24/7).
Audi to Volvo KMAC - Experience of Resolving OEM Suspension Shortcomings Since 1964!
