2013 cls63
I am a long time M156 owner and about to upgrade to a CLS63. Found a 2013 locally. Is there any known issue and tips when looking for an used one? Thank you so much!
Steering, suspension, brakes and cooling are generally OK across most models.
M157 2013 model still has the head bold and cams issue? I thought that problem only for M156 from 2007 to early 2012.
https://mbworld.org/forums/w212-amg/...-w212-amg.html
https://mbworld.org/forums/w212-amg/...63-4matic.html
Can we replace CC with steel rotors?
The only reason I would want them is for the reduced brake dust lol. Brake dust is a **** on these cars. The extra Performance benefits are nice but the regular brakes are still performance brakes (Im not one to hit the track). But with everything there are risks...rock chips, have to be careful changing tires, etc
First one is resonator delete. Do you have any suggestion for straight vs x-pipe?
Second: Lower the ride with H&R coil springs? Is this some kind of DIYs or dealer's job?
Seems like not many W218 owners add the rear diffusion or front lip spoiler to your car?
i did the res delete on mine W218. just went with straight pipe as i read that, with turbos, there was no benefit of the x-pipe. also, i lowered mine on H&R's, as well. for me, the drop is perfect (i also used spacers in the rear) so i saw no need for the extra expense of coilovers. and yeah...i'm pretty handy around a car but springs were a bit outside of my skill level. the links in the back (air suspension so there are no springs in the back, in case you werent familiar), however, i could have done.
lastly, i added a rear diffuser but its just a CF version of the one that came with the car. the RT-style rear was a bit too boy-racer for me and obstructed the view of the exhaust tips when looking at the car from the side.
Here’s a pic of the drop on the H&R/links combo.
I had resonator deleted with straight pipes on my E63, I am going to do the same for the CLS. Thanks.
Found this one for $100 cheaper than on Amazon
==> never mind, verified with sale rep that part includes only 2 front coilsprings.
Left foot hard on brake pedal.
Then you should be able to spin the C/S/S+ dial to RS/race start.
Then it'll say right paddle accept left to cancel or whatever so right paddle.
Then foot on gas, revs up, release brake, and off you get.
But again, you have to make sure traction control is in the right setting to even get the ball rolling. Sounds like a lot but once you know the process it's easy.
Congrats on the new ride... and, I am sure that you have noted by now that the brakes are NOT "noisy" as someone mentioned above. Enjoy the new ride!
