ND-Photo.nl's 2005 CLS55 Build thread
Old Sep 7, 2023 | 02:15 PM
  #526
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
I have seen them before but havent been able to find a European seller. I found one on eBay which is $100 + $50 shipping.
Old Sep 7, 2023 | 05:49 PM
  #527
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
That is not a bad price. Eight years ago I paid $116 USD for mine. Accounting for inflation and shipping, $150 sounds reasonable. And below are two examples of clutch failure...
https://mbworld.org/forums/w211-amg/...ull-speed.html
https://mbworld.org/forums/w211-amg/...ed-my-car.html
Old Sep 8, 2023 | 04:49 AM
  #528
Ok I've just ordered it. Paid $163 in total, which is cheaper than repairing damage once it explodes
Old Sep 17, 2023 | 01:25 PM
  #529
Seems I was running into issues with the new injectors? Cold start was horrible and it was running very rich, so I decided to put back the old injectors (after servicing them first)
All injectors serviced, new rubber rings, new retainer ring and new filter baskets
All old injectors back in the fuel rail
After fitting them, all problems were solved again...
Old Sep 17, 2023 | 01:29 PM
  #530
Also replaced the gaskets of the oil filter housing. I needed to buy the 46mm socket to remove the big hollow bolt
The new socket and oil filter key
Elring gaskets
Oil filter out and insides cleaned
Gasket was hard as a rock off course
Sticky sand etc
Dirt & debris
Old Sep 17, 2023 | 01:34 PM
  #531
Remove the 4x T30 torx bolts to separate the 2 halves
Another 2 hard gaskets
More dirt & debris
Cleaning with an old toothbrush and some brake cleaner works very well
Some spring loaded action behind the small plate
I replaced the rubber O-ring as well
And as usual, it leaked a bit after. So I will replace the bottom seal with an original MB gasket. Thankfully, that seal isnt that expensive
Old Sep 18, 2023 | 10:27 AM
  #532
Created a small video on dirty vs polished exhaust tips
Old Sep 20, 2023 | 11:51 AM
  #533
MB Moneypit's Avatar
CLS63 AMG
Ok, guilty as charged.
So what did you use to clean, more importantly polish?
Also beautiful neighborhood, I love the Netherlands.
Old Sep 21, 2023 | 03:58 AM
  #534
As requested by @MB Moneypit !
  • Wash it first (normal car shampoo)
  • General degreaser to get the soot/carbon deposits of as much as possible
  • Scotch brite pads in combination with metal polish, used the most coarse pad only on the hardest to clean areas >
    Amazon Amazon
  • Metal polish with polishing cones as last step > https://www.amazon.nl/BESPORTBLE-Pol...dp/B097H72FZZ/
I received the tip that the Mothers metal polish is top notch stuff, so I will be getting that in the future. I bought some other brand
Mothers:
Amazon Amazon
I only need to wipe off the tips from time to time at this stage
Old Sep 21, 2023 | 04:27 AM
  #535
Removing the inner & outer tie rod
Old Sep 26, 2023 | 06:19 PM
  #536
Bought an engine hoist to swap the engine mounts (again). I put in Meyle engine mounts, but after hearing about them on M539 Restorations, I decided to swap them out with Lemforder. The difference is definitely there, Lemforder gives a much smoother experience.
Work in progress
And I stumbled on a small issue, I could not get the bolt in the drivers side mount. The notch did not line up perfectly. Some small adjustment was needed.
Old Sep 26, 2023 | 06:22 PM
  #537
Inspected the F32 Pre-fuse block, as I still had some issues with the CLS switching off convenience functions. I did not know you need to loosen a nut under the car to get it out. So I only cleaned the connections, did the same for the negative mass point right next to it
Old Sep 26, 2023 | 06:26 PM
  #538
Also decided to use the heat reflective tape on the top of the airboxes as a small supporting mod. Work in progress:
Also fitted the Gates HD green belt, will compare it to the Gates RPM belt. See if the Gates RPM makes a little bit more boost
All done
Old Oct 1, 2023 | 12:03 PM
  #539
Thanks again for the reminder @bbirdwell! I got the scatter shield installed, a little bit of insurance for the supercharger pulley
For the uninitiated:
https://mbworld.org/forums/w211-amg/...er-pulley.html
Sits fairly close to the pulley, but no issues whatsoever
Old Oct 1, 2023 | 12:05 PM
  #540
Also replaced the fuel dampener, as its probably 18 years old by now
Old Oct 1, 2023 | 12:07 PM
  #541
When I replaced the fuel dampener, I also replaced the MAP sensor. Quite a fiddly process as there isn't much room. My tip: rent a midget or someone with small hands, as the right bolt has ample room to remove it.
Old Oct 1, 2023 | 12:08 PM
  #542
And I also passed the 200.000km mark!
Old Oct 3, 2023 | 02:31 PM
  #543
Washed it on saturday, and came back to it on sunday like this....
Old Oct 3, 2023 | 02:32 PM
  #544
On my way home from work, after it rained all day. I was blessed with some sunshine
Room enough for bigger brakes
Old Oct 4, 2023 | 11:42 AM
  #545
POV Installation video of the Scatter Shield
Old Oct 13, 2023 | 02:02 PM
  #546
All by myself
Old Oct 13, 2023 | 02:06 PM
  #547
Rural parking in the Netherlands
Old Oct 13, 2023 | 02:13 PM
  #548
LED license plate light broke down again, so I went back to festoon leds. I found these from maxgtrs which has flexible ends. The red ones are cree leds, which I had lying around
These went straight to the bin
Old Oct 13, 2023 | 02:18 PM
  #549
Added a battery monitor to the car in helping me find a power drain.
And the app show this information
After driving 30-40 mins or so
Old Oct 14, 2023 | 06:40 PM
  #550
machild's Avatar
2006 CLS55 AMG, 2005 SLK 350 AMG
How much of a drain do you have?
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
