oil level question
Old Aug 31, 2005 | 10:21 PM
genechien's Avatar
'05 C55 AMG
oil level question
so i finally got around to using that check oil level function and after the computer did it's thing i got the message saying that i need to add 1 quart of oil to reach the max oil level.
does this mean that i should add 1 quart of oil to top it off?
Old Aug 31, 2005 | 11:38 PM
nugget's Avatar
05 C55
I received the exact same message checking it just before and after my 10,000 mile service… so I’m assuming this is normal. Engine temp seem to be normal as well. I haven’t had a chance to ask my service consultant just to be sure. I’m so lazy. :p
Old Sep 1, 2005 | 10:50 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
you guys are kidding>>>>>right??
This is why my breakin process is really ment only for enthusiasts and MB builds in a high tolerence in the ECU for those who abuse the engine and don't add oil when required.
ADD OIL NOW!!!
Old Sep 1, 2005 | 11:04 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I had the same thought North - are these guys for real!!!!!
The car tells you that your hand-built AMG V8 is down a quart of oil....... hhmmmm, what should I do?? I say risk it all over a $5 quart of oil - keep driving, ignore the message. NOT.
Old Sep 1, 2005 | 02:00 PM
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
I agree that you should add the oil if the computer says you should.
However, shouldn't the computer alert you to an "error" if the motor really was low on oil (like a smart computer should)? Or do you really have to check the oil level regularly yourself?
Another question: When you do check the oil level manually, what happens at the end? Do you get a message like "oil level is OK" or something like that?
Whenever I do it, it just hangs for a long time, without ever confirming for me that things are OK or not.
Old Sep 1, 2005 | 02:12 PM
Renault78law's Avatar
2003 C32
Mine does the same. When it says, checking, and after a few minutes the screen resets, just hit 'check oil' again, and wait. repeat if necessary. eventually, it'll give you the result.
Old Sep 1, 2005 | 02:35 PM
Are you waiting the obligatory 5 min (after Driving) with the engine turned off and parked level?? should give you a readout in under 20 seconds.
I usually check mine after I get gas>>>>>
Old Sep 1, 2005 | 03:38 PM
kjb55's Avatar
The center display, without user input, should give you the low oil warning beginning at 1 quart low.
When initiating a check - my display will advise 'Oil Level Okay' or advise if low also. If the correct amount of time has not passed since engine shut-off, I get a message that advises me to wait and try again.
Old Sep 1, 2005 | 05:34 PM
genechien's Avatar
'05 C55 AMG
well my thinking was that my oil level was somewhere in between the max level and the low oil level...which would be fine
and i didn't get an low oil level warning or anything, i was just curious and wanted to check out the oil level detection function
but i guess i'll add a quart just to be careful
Old Sep 1, 2005 | 07:05 PM
That might be good thinking if you were driving a Ford F150 but you are not.
the 5.5L AMG V8 is a High Pro motor that likes to be filled with oil at all times.
My advice is keep it happy and add oil when needed.
enjoy your ride>>>>
Old Sep 1, 2005 | 11:39 PM
nugget's Avatar
05 C55
I'm definitely not going to assume my dealer knows what they are doing anymore after this one. My trust to them has been lost. I’m going to stop by my dealer during work tomorrow. Thanks for the pressure guys... I needed this wakeup call.
