Need Advice on Adding More Power to HPS SC
Old Feb 9, 2006 | 01:25 PM
  #351
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Linh
Since You are in contact with Adam @HPS...we need a cook for the Dyno Day GTG April 15th..And Since Adam is Great at COOKING NUMBERS...ask him if he will stop over and Cook up some Burgers !
Update on the Jesse software program?
Old Feb 9, 2006 | 03:40 PM
  #352
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
LATEST UPDATE: AMGSC car
Just spoke to MechTech. Still tuning the car but...
1) Boost is back up to 7.5 psi.
2) AFR remains at 11.5/1 throughout entire RPM band.
However they are now reprogramming the transmission control portion of the ECU so that the car does not automatically shift gears when the extra power is loaded onto the tranny.
Jim is excited about what's going to happen next! I asked him if there are any risks to my tranny or engine and he assured me no. He told me that the he feels that once the tranny shifting issue is taken care of. I should easily see 430-450rwhp.
I will keep all of you posted but so far so good!
Old Feb 9, 2006 | 04:13 PM
  #353
JamE55's Avatar
Out Of Control!
Old Feb 9, 2006 | 04:35 PM
  #354
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I am glad to see you making progress. I sure hope Jesse can make it right. Make sure you get that assurance in writing. But that's just me, if you want to take his word on it, then that's your own choice.
Old Feb 9, 2006 | 10:31 PM
  #355
AMGSC's Avatar
Kleeman SC without ECU - S1 Package
Has anyone purchased the Kleemann SC without the ECU upgrade (+$1,000).
How does Kleemann make the power without ECU reprogramming either.
Everybody says it's impossible for HPS to get power without ECU reprogramming but nobody has questioned Kleeman's non-ECU package ($11,000). Does the non-ECU SC package with the stock injectors put out the advertised power?
Can anyone show me their dyno with the non-ECU (S1) SC?
Old Feb 9, 2006 | 10:48 PM
  #356
Thericker's Avatar
V12-Biturbo
So what were the final dyno ##"s from today
Old Feb 10, 2006 | 12:23 AM
  #357
genechien's Avatar
'05 C55 AMG
why don't you just email kleemann and ask them? from all your questions and comments, it's plain to me that you're desperately looking for some flaw with the superchargers of other tuners like kleeman or renntech. it might make you feel better if other people have also wasted money on products that just don't work as advertised but at the end of the day it does nothing to solve the huge problems you have with your car.
good luck trying to find any info on kleemann defrauding people to make a few quick bucks.
Old Feb 10, 2006 | 12:35 AM
  #358
AMGSC's Avatar
I was not there today but the lowest was 380rwhp due to the following possible reasons:
1) 37lb Fuel Injectors maxed out per ECU reading (AFR back up to 13:1)
2) Tranny kept slipping as more power was applied (per check engine code).
3) Could not completely disable ESP, ABS, etc...and set to pure dyno mode.
Next day(s):
1) Replace with 44lb Fuel Injectors
2) Adjust Tranny setting via ODB2 DME.
3) Fully disable ESP, ABS, etc..and engage pure dyno mode.
But the boost did jump from 6 lbs to 7.5 lbs psi which maxed out the 37lb injectors.
Old Feb 10, 2006 | 12:53 AM
  #359
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
Next day(s):
The numbers are getting better. but why is it that you are running 3lbs of boost more than me with bigger injectors, ECU tunning and aftercooler and you are only makine 20hp more than me. I have no ECU tunning, no tranny problems, running stock injectors and no aftercooler.
I don't understand why you would need to adjust the tranny for more power. Seems like things are getting way too complicated.
I bet your car would make more power with the MP112 blower, stock injectors, Spilt Second timming adjustment, and a Super FMU tunned on the dyno.
I often wonder if the aftercooler is the problem in your system. It looks very small and restrictive, it may be reducing the air flow into the motor. This month I should be able to get 380whp once I add the chemical cooler.
Old Feb 10, 2006 | 01:08 AM
  #360
pshek's Avatar
2003 C-Class Sportcoupe
Next day(s):
Let see, now with your HPS Gen II kit, you need more boost, larger fuel injectors, pulley, and ECU tune just to make 380rwhp with tranny issues and CELs...........I hope HPS won't sacrifice the reliability of your car's engine just to save face after being shown that they had cooked dyno numbers. If you want to try and attain 413rwhp albeit unreliably, then I just hope your engine doesn't blow up.
Old Feb 10, 2006 | 01:11 AM
  #361
Thericker's Avatar
V12-Biturbo
Next day(s):
It sounds like there are to many cooks in the kitchen, all these variables I'm hoping for the best though and it better be well over 380-400rwhp on your 5.4 liter it should be more like 450+++ w/all these great new mods :
Old Feb 10, 2006 | 01:17 AM
  #362
Richard Galing's Avatar
W210, W220, W163, W164, C6
The included HPS heat exchanger (ala oil cooler) in my kit was not so much of a problem but rather a limiting factor, it didn't function up to par...just my 2 cents. I discuss this with both Adam and Bill, so I do wonder if they have improved upon the early production kits. Not much you can upgrade on the intercooler core without having to redesign the manifold plenum.
Robert....if you do have photos don't hesitate to share them.
Custom HE vs Earl's oil cooler
Old Feb 10, 2006 | 01:22 AM
  #363
pshek's Avatar
Thanks for posting the picture. I've seen larger heat exchangers in watercooled personal computers than that HPS heat exchanger. No joke...
Old Feb 10, 2006 | 01:36 AM
  #364
Look at it this way, at least it'll fit in the back pocket of your Levi's.
Old Feb 10, 2006 | 01:43 AM
  #365
vraa's Avatar
Don't forget that a car moves and a computer doesn't
Old Feb 10, 2006 | 01:50 AM
  #366
AMGSC's Avatar
Yes, According to Adam and Bill, the heat exchanger you have in your car was replaced with a newer version from a different vendor after it cracked in Linh's car (first CL install).
Thanks for the advice about the heat exchanger and intercoolers.
Linh was present during today's dyno and said it looked like the rpm was fluctuating wildly during the dyno. Do you know how to disengage the ESP, ABS COMPLETELY so that the computer doesn't try to compensate for the imbalance by locking up the wheels even with ESP off?
Old Feb 10, 2006 | 01:54 AM
  #367
AMGSC's Avatar
They assured me that if they break it. They buy it (Retail Price) . I have full confidence in them.
Old Feb 10, 2006 | 01:55 AM
  #368
Thericker's Avatar
V12-Biturbo
So since my car was done before Linh's that must mean I have the older version
Old Feb 10, 2006 | 02:04 AM
  #369
E55Cent's Avatar
Hola Sean, I thought it was Linh's intercooler core that went bad, not the heat exchanger by the front bumper.
Old Feb 10, 2006 | 02:06 AM
  #370
Thericker's Avatar
V12-Biturbo
Yes it was, but I thought that's what amgsc was talking about
The way amgsc described it I missunderstood :
Old Feb 10, 2006 | 02:17 AM
  #371
E55Cent's Avatar
I think AMGSC is correct that the heat exhange was upgraded with a more effecient cooler, but not because it broke on Linhs car. The intercooler core will remain the same unless HPS redesigns their the whole kit.
BTW you are right, you still have the old (oil) heat exchanger.
Old Feb 10, 2006 | 02:49 AM
  #372
That is certainly good news, furnish some pictures of the HE when ever possible...I'm curious to see the change.
I recall Jim had the same issue when my car was on the dyno, however my car did not have the "dyno mode" feature, does your? I have heard in "dyno mode" the ESP is less intrusive but not competely turned off.
-Turn the key to the second position
-Quickly press the R button (Odometer reset) three times.
-You should be able to see this screen that displays voltage -Scroll with the up/down arrows until to see the screen that shows the toggle options for dyno mode
-Use + or - to toggle
Good luck Rob, I wish I had your patience.
Really...the HE cracked or the intercooler core?
Intercooler core pic.
Old Feb 10, 2006 | 09:16 AM
  #373
JamE55's Avatar
Out Of Control!
I hope you have that in black and white as your insurance.
Old Feb 10, 2006 | 10:07 AM
  #374
Bif powell's Avatar
2002 c32
>>3) Could not completely disable ESP, ABS, etc...and set to pure dyno mode.<<
Pull the fuse.
Old Feb 10, 2006 | 11:39 AM
  #375
Vadim-SoCal
Guest
Posts: n/a
Next day(s):
37 lb. injectors should be good for almost 600 flywheel HP. With 380 rwhp you are nowhere near that number.
Something else is going on with the tranny, it should hold 600 HP plus.
Car should dyno by simply turning ESP button off. Again something else is wrong with the setup, DME does not like it.
You have already rated this thread Rating: Thread Rating: 9 votes, 4.11 average.
