Need Advice on Adding More Power to HPS SC
Rating: Thread Rating: 9 votes, 4.11 average.
Old Apr 20, 2007 | 05:39 PM
  #1626
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Originally Posted by JMMT
I want to clarify a few issues that were brought to my attention. Number 1 there was no oral agreement between Robert Chen, Linh Nguyen or myself to develop a HPS third generation 122 supercharger system. I have made this clear to all parties on numerous occassions that any future developments would be introduced and released by HPS. In addition many of Robert's comments about these issues have been misleading and taken out of content regarding myself. I hope forum members can read in between lines.
Finally, to end speculation, any engine failure to date was due to software/timing issues created by an outside source with no affiliation with HPS. The software proved to be detramentel to the engines or the individuals that elected to use their services.
Thank you,
Jim McFarland
Mechtech Motorsports
Jim,
I don't want to drag you into this but I did not come up with MP122H blower alternative out of thin air. I hope you remember what HPS's Dr. Kava and you were so excited about when I came to pick up my car after you guys did some R&D on my car with a possible pump and heat exchanger replacement to add more power. Everything is documented day by day on this thread.
I will support you in stating that you did not attempt to circumvent HPS. I asked you to help me build a one-off custom kit only. As for future commercial applications, I expressed no business interest other than stating that I would give positive testimonials if the product was successful.
As for the tuner HPS contracted with to work on HPS customer's cars, yes he is not affiliated with HPS but he was a supplier/contractor of HPS when the work was originally done so HPS does bear some responsibility for the results. None of the customers signed a waiver when the work was initially done. This tuner worked on my car initially and improved its performance because as I repeated over and over again, I was running dangerously lean and making only 10+rhwp gains before the tuning was done. You even admitted just a few days ago before I got my car back for the broken drive belt and pulley that my tuning is running fine and advised me not to replace it with your new flasher program.
Old Apr 20, 2007 | 06:08 PM
  #1627
Clk&Slk's Avatar
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
Thank you,
Jim McFarland
I also want to clarify even farther with my position regarding to this issues. I was brought into this issues because people needed my help getting info/contact for them. What I did was no differences then what I did in the past to help out HPS with their issues with the sc kit. HPS never considered me as their partner then. So don't even considered me as partner regarding to this issues. I simply just want to help out with Robert and Mech tech to solves some of the problems.
Old May 3, 2007 | 02:47 AM
  #1628
mig888's Avatar
EVE
I dont think Jim should start throwing stones especially on the things you have covered up for HPS have you seen JIMs reputation hes not the innocent party at hand
Bimmerforums
e46fanatics
Jim you should keep your opinion out of it. Like Adam had said you have told him " Antifreeze in the oil wont hurt an engine".
I guess leaky cores are effecient as well
MechTech SHould have never posted
BTW someone I Know is putting a whipple on his cls its nuts he finally got his cnc mill and a new lithograph and hes going nuts
Old May 3, 2007 | 06:13 PM
  #1629
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Old May 3, 2007 | 06:25 PM
  #1630
ProjectC55's Avatar
Originally Posted by AMGSC
Finally MT agreed to proceed with the project to build me a MechTech SC Kit that comes with the new MP122H blower, 75mm throttle body and custom reflashed ECU instead of SI's chip tuning.
They will heavily subsidize the development costs and my out-of-pocket upgrade costs will be minimal. Jim is confident it will be more powerful than the new Kleemann kits but we shall see. If this kit is successful then MT will make it commercial.
I'm glad Jim is willing to take the initiative that HPS refused. I will refraim from posting daily or weekly until the entire project is completed and the kit is fully tried and tested to work reliably and with the estimated power gain of 75-100rwhp more than the Gen II. Hopefully this kit will push me over the 485rwhp mark! The project is slated to start once the blower comes in next week.
Brother, you r one self sadistic S.O.B! Jeez! Stop already and just get a Kleemannn.
Does this ever END!!!!!
Old May 27, 2007 | 02:43 AM
  #1631
SoCalCLK's Avatar
2017 W205 C43 AMG
HPS's rep is toast on this forum and keeps on getting more and more burnt. Ouch.
Old May 27, 2007 | 04:33 PM
  #1632
AndySays's Avatar
2007 C350 SS
Old May 27, 2007 | 04:55 PM
  #1633
AndySays's Avatar
2007 C350 SS
and BTW... In Adam's email he mentioned that he told all potential customers that Jessie's tuning was the only cause of all their problems and that everything is fine now. What a crock of SH*T. Jessie's tuning is the ONLY reason the car is not in the scrap yard. I was driving around with 18/1 AFR and making only a gain of 10rwhp until a knowledgeable forum member challenged me to dyno my car and I found out the truth about the false/bogus/fraudulent dyno chart that Adam still can't explain.
I don't care if HPS sells a platinum kit that makes 1,000rwhp because I would NEVER do business with this company and Adam in particular again. He said he wasn't worried about me posting on this forum but I happen to know that when I google HPS, my posts often appear on PAGE 1 of the results. I wonder if he has tried that himself.
Everytime I post something here, Adam emails me so I know he is reading this. Here is my warning to you Adam, remove that false testimonial from your website from MYHPS.COM within 24 hours from now or you will be getting a call from my attorney shortly thereafter. You know I will do it. I already have a suit in progress so my lawyer would love the additional business.
So I'm guessing that HPS still hasn't removed your testimonies
I just checked the website for fun and I found this, your the first personal testimony:
Robert Chein aka "AMGSC" - C55 AMG Racing Track 2nd Generation Intake
Published Friday, June 23, 2006
My experiance at Willow Springs Race Track with a HPS supercharge C55 AMG Mercedes-Benz.
"My friend took me on a few laps in my own car and it handled much better than the instructors's Mustang. On the straights, it blew past almost everything on the course. There were 2 NASCAR cars, 2 Indy type cars, 2 modified Vipers, 1 Ferrari, 1 Ford GT, 1 Porshe GT3, several Porshe 997's, Boxters, 1 E55, 2 C55 (Including mine), 2 M3s, 1 C32, 1 S4 and quite a few Vettes, Zs, G35s, Lancer EVOs, WRX-STIs and Mustangs."
"It's funny but Brandon took it easy on my car on the track but I consistently did over 160mph on stretches of Interstate 5, 99, 58 and 14 while I was trying to make it from Button Willow to Willow Springs. The car lunges instantly from 60mph to over 150mph in a heartbeat and was steady as a rock even the though all the cars I passed looked like a blur."
link: http://www.myhps.com/index.php?src=n...20Testimonials
Old May 27, 2007 | 09:00 PM
  #1634
SoCalCLK's Avatar
2017 W205 C43 AMG
Nice find. Ouch, dude!
Old May 27, 2007 | 09:40 PM
  #1635
Josh K's Avatar
Tesla Model S
wow....this thread is still going...just...wow...
Old May 27, 2007 | 09:59 PM
  #1636
SoCalCLK's Avatar
2017 W205 C43 AMG
Hey Josh, what up. It never gets old making fun of HPS and good 'ole albino.
What's new?
Old May 27, 2007 | 10:34 PM
  #1637
Josh K's Avatar
Tesla Model S
What's new?
lol nothing much. quit World of Warcraft (for real this time), benz (with non-HPS s/c) is still running strong, just ordered a Cooper S for my new daily, basically just getting back out in the world now that I'm not stuck on comp games lol
Old May 28, 2007 | 12:07 AM
  #1638
AMGSC's Avatar
New throttle body, header and exhaust kit search
Guys,
I am researching headers/exhaust kit now. I want a more aggressive sound from an exhaust kit but decided why not just get the headers and change the cats since my warranty was voided long ago.
I can't decide between the Kleemann ($3,600) or Renntech headers ($4,995 but selling on Ebay for $3,000 brand new). Which would you recommend? I really want equal length headers that flow from 4-2-1 instead of 4-1 and widest collector possible but neither are equal length, correct? What other brands are out there for a C55? I searched the web but could not find any MB headers that are equal length.
Old May 28, 2007 | 01:43 AM
  #1639
Vadim @ FD's Avatar
S600TT, R350
They are no other brands.
In order to make a tri Y-headers you will need to move primary collector down under the floor in the front seat area. There is very little room for a properly sized converter.
Basically it will be a custom job.
Is it worth doing it?
That is a question for your valet.
Will it make more power?
Yes and no. It will add a significant boost in mid-range TQ, but very little at the top end.
Will your car pass smog? No chance in hell.
Which means, that if you will want to sell the car, it will have to go back to stock................. But you already knew that.
Good Luck!
Old May 28, 2007 | 11:18 AM
  #1640
SoCalCLK's Avatar
2017 W205 C43 AMG
Cool. WoW, lol! The last game I got addicted to was Star Wars KOTOR, and I told myself to stay far away from WoW!
Congrats on the Cooper S. My g/f bought a Cooper S Convertible in April 2006, and she loves it. It handles real nice and has more power than expected. Plus, you can do a lot to it to make it faster!
Good to see you back on MBWorld.
Old May 28, 2007 | 03:37 PM
  #1641
AMGSC's Avatar
Good Luck!
Can you refer me to someone who can do this custom equal length tri-Y header, cats and exhaust system in So Cal area. I really respect your knowledge of tuning MBs.
Old May 28, 2007 | 07:14 PM
  #1642
Vadim @ FD's Avatar
S600TT, R350
In about a week I should be able to help you.
Stay tuned
Old Jun 1, 2007 | 02:47 AM
  #1643
mig888's Avatar
EVE
why cause you work at GMG now lol Robert the guys at Gintani in the valley can build you a header no problem the issue is cost
Old Jun 1, 2007 | 05:28 PM
  #1644
AMGSC's Avatar
What's GMG and are they local? As for Gintani, I will google them and see what they offer. Thanks Jose!
Old Oct 13, 2007 | 05:44 PM
  #1645
AMGSC's Avatar
Back from the Dead
The saga continues...My rig is getting a complete makeover starting with SC. Kleemann Cams, Cats, Headers, Powerchip ECU, AMS and EVOSPORT pulley kits followed next week by 80mmTB, SS Exhaust, X pipe, CM90 pump and Cobra Heat-Exchanger, Suspension links and Nitrous. Car is at GMG Racing which I know is in the goods hands of Vadim hiimself.
Question: Should I upgrade the blower on my HPS kit or just Get the Kleemann? I can't find the twin-screw version anymore. Is anybody selling theirs?
Old Oct 15, 2007 | 01:08 AM
  #1646
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Please, for the love of God, stop the madness with this car/thread/self-ownage.
Please.
Old Oct 15, 2007 | 01:15 AM
  #1647
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
The M112 blower is fine, it makes crazy power on my buddies C6 Vette 585whp. The M112 was never the problem it was the kit that HPS made around the blower.
Mario
Old Oct 15, 2007 | 01:38 AM
  #1648
AMGSC's Avatar
Mario
Strange but Vadim says the HPS airbox/intake is a decent design and told me there was no need to upgrade it. The Intercooler and Heat Exchanger kept the AITs at 90-97F at WOT during Vadim's dyno of my car although I still plan on installing the Johnson CM90 and Code3Smith's massive HE anyway. It also made 6+lbs of boost UNTIL the Kleemann Headers/Cats/Cams were installed. It then lost 1lb of boost.
I looked closely at Kleemann's new SC Kit and the intake manifold and plenum looks no more areodynamic than my HPS kit. The Kleemann also has a flat top and sharp corners. The Renntech SC kit hardware also does not have much room for the air to flow into the engine either. The blowers on all three kits are mounted upside down where the outlet faces up and must make a 180degree U-turn back down into the engine.
The key problem with the HPS Kit (after upgrades) in my opinion is that it did not have the 2006 C55 ECU file for proper tuning/ECU mapping/calibrations. Now that Powerchip is doing it, I should be fine. Let's find out when I get my car back on Thursday. If it still does not make the power I expect then I will get the Kleemann or Renntech SC Kit and sell my kit for $1500 (only after Magnusson replaces the bearings in it under warranty).
ps. I may even go as far as boring the car out, strenghtening the tranny, etc and making this an SC'd C65 with 25psi of boost.I think I'm now possessed by the Mod Demons.
Old Oct 15, 2007 | 11:11 AM
  #1649
JamE55's Avatar
Out Of Control!
Please.
LOL
Old Oct 15, 2007 | 08:07 PM
  #1650
AMGSC's Avatar
Originally Posted by JamE55
LOL
What's up James? It's funny how many PMs I get during a week thanking me for the negative AND positive experiences I've posted.
I am doing no more than other forum members who are doing heavy modding by sharing my experiences so that they can decide what is worthwile and what is not from a cost/benefit perspective.
I know that a heavily modded C55 still cannot compete with the E, CL, CLS, S, SL in a straight line unless I lower the Compression Ratio and Increase the Boost. But that's in the works...
You have already rated this thread Rating: Thread Rating: 9 votes, 4.11 average.
