C32 @ 426hp & 593lb/t
Old Oct 6, 2006 | 02:11 PM
alumar's Avatar
2019 E63s AMG
Birdsauto C32 to S32 Conversion
I am waiting to see the cost on this......will post the return email when they shoot me back.
Old Oct 6, 2006 | 02:17 PM
jturkel's Avatar
02 C32 AMG
wow....yah definitely interested on what the price of that is
Old Oct 6, 2006 | 02:27 PM
Eurocharged Rick's Avatar
SPONSOR
the torque that they are quoting is inconsistent with the chart that is below that paragraph, it says 384 torque...not 593 torque...might want to ask them to clarify that...sounds just like the evosport stage 2 setup except for the cams and high flow cats...
Old Oct 6, 2006 | 02:34 PM
Zeppelin's Avatar
C32
Not only that but they don't even know where the air filters go
Old Oct 6, 2006 | 03:49 PM
Fifth Ring's Avatar
C32 AMG
All that money, all that HP, and you go from 0-60 in 5.1 to 4.8?
Old Oct 6, 2006 | 04:27 PM
CLKBSVegas's Avatar
a Black
That does seem strange. Don't we have stock C32's on this site that have run sub 5.0s?
Old Oct 6, 2006 | 04:52 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
Hmmm..... something is not right.
1st paragraph says 593lbft (=804Nm ). The table says 384lbft (=520Nm). So there are 2 numbers: 593lbft or 520Nm. BIG BIG difference...
If it's true that this upgrade could give 426hp & 593lbft, not 384lbft. This could be one of the best upgrade of all.... w/ less weight (600 lbs less) & same torque peak (2700rpm), should be able to blow stock W211 E55 (469hp & 510lbft). Heck, I bet it could blow away 65's.
But if it's "only" 384lbft, nothing special...
EDIT: Never mind... someone mentioned this already.... but hell, can someone verify that it IS 593lbft, or even 520lbft??? If so, I'll sell my C55 and get C32 w/ this upgrade... that'll be one hell of a car.... But from the list of the package, I think 384lbft is the right one
Old Oct 6, 2006 | 05:38 PM
newton22's Avatar
BMW E39
Typo. I don't see that motor running 593 ft-lbs at all. If any, that will require serious internal upgrades, SC upgrade, and if not all that, then nitrous.
Old Oct 6, 2006 | 05:58 PM
andy_cyp's Avatar
Obsidian E55
I spoke to these guys over here in the UK, and it is deffinatly a typo guys, the 426 bhp figures are quite correct but the 593ftlb are not.
Price over here for this conversion is £9.500===$17.500. So dont bother
Old Oct 6, 2006 | 06:08 PM
alumar's Avatar
2019 E63s AMG
17.5k????? wtf
Old Oct 6, 2006 | 06:35 PM
sdsilverm3's Avatar
Did I read the boost correctly at 2.1 BAR? That's ~30psi. Can the supercharger support that boost level?
Old Oct 6, 2006 | 06:38 PM
Vadim @ FD's Avatar
S600TT, R350
This is an old MKB kit. The picture is taken from their website.
Old Oct 6, 2006 | 06:50 PM
Vomit's Avatar
2002 C32 Black/Charcoal
Sure, for at least about 10 seconds before meltdown.
Old Oct 6, 2006 | 06:51 PM
JamE55's Avatar
Out Of Control!
That's my next new mod.....30psi. LOL
Old Oct 6, 2006 | 07:15 PM
SPONSOR
figured it was a typo, and wow, that is some price for that HP level...definitely not worth it!
Old Oct 6, 2006 | 08:21 PM
jgsx's Avatar
04 C32
I thought that EVOsport tried 2x psi and the supercharger clutch was slipping
Old Oct 6, 2006 | 10:41 PM
SPONSOR
they did, and it did...
Old Oct 6, 2006 | 11:02 PM
Vadim @ FD's Avatar
S600TT, R350
At 23 psi car made over 400 at the wheels, but the compressor clutch would not hold that kind of rpms.
Old Oct 6, 2006 | 11:04 PM
SPONSOR
so there is no way to prevent the clutch from slipping?
Old Oct 7, 2006 | 01:32 PM
Vadim @ FD's Avatar
S600TT, R350
Short of redesigning the whole clutch setup, the answer is no.
Old Oct 7, 2006 | 01:41 PM
SPONSOR
will the E55 clutch setup work? is it any different? maybe a heavier clutch setup?
Old Oct 8, 2006 | 02:01 PM
Vadim @ FD's Avatar
S600TT, R350
E55 clutch has different offset. More boost is not a reliable way to go at this point. Heads and cams will be more beneficial and reliable.
Old Oct 8, 2006 | 02:14 PM
SPONSOR
gotcha...thanks for the feedback, i agree with you...i am going to look into porting the heads and getting a set of cams....
Old Oct 8, 2006 | 03:26 PM
sdsilverm3's Avatar
How efficient is the supercharger at that boost level?
Old Oct 8, 2006 | 04:19 PM
m444's Avatar
Audi C7.5 S6
At stock boost, the blower is about at the limit of the efficiency With the standard oversize crank pulley, one is already operating down the slope of the efficiency curve. The Intercooler can barely keep up, even with the normal pulley swap.
Positive displacement blowers typically like to work in the 6lb/sqin to 12lb/sqin range. At over 15lb/sqin, one should consider making the engine more freely flowing.
The turbos & fan type (Vortech) forced induction systems are NOT positive displacement blowers, air volume is determined by blower turbine/impeller RPM. Also, because of the type of air intake plumbing they can easily use air/air heat exchangers, which are more efficient. Once the blower is placed in the valley of the V6 manifold, cooling is more difficult, but it very effective at low boost levels.
When running higher boost, one is just heating up the air and putting excessive drag on the belt drive.
If you want to run 30lb/sqin boost, go to an air/air intercooled twin turbo setup.
We need to find an expert at porting the V6 Mercedes heads. Also the cam needs to be optimized with the ported heads for blown applications.
