heated seat
Old 02-28-2008, 02:19 PM
  #51
c32used's Avatar
LET C32 2002
Originally Posted by john89011
My driver's side heated seats don't work. When I push the button, no response and the red light does not come on. The passenger one works fine.
Any ideas other then checking fuses because I checked those. Bad relay?
Thanks guys!
I recently had my seat controls repaired(which activates the heated seats and the button light on the dash) and the plugs on the passenger side wasn't plugged in right so check that the plugs are in tight in the front of seat under it.
Old 02-28-2008, 07:44 PM
  #52
1Lop2K5C's Avatar
C63
I'm on my third set for the driver side. With the original seat bottom, it would suddenly feel barely warm. The second time, it would just burned my butt and crapped out. i'm thinking the seat heating pad is sensitive to certain amount of weigh because mine happened right after a fat vallet guy sat in it. Only good thing is I get a whole new seat bottom everytime.
Old 02-29-2008, 12:28 AM
  #53
c32used's Avatar
LET C32 2002
That exactly what happened on the driver side and then I had the seat control modules draining battery issue...so it may appear I will get another lower seat then...
Old 02-29-2008, 12:31 AM
  #54
crazeazn's Avatar
C55
besides getting a new seat everytime any other options?
Old 02-29-2008, 12:50 AM
  #55
c32used's Avatar
LET C32 2002
Because the heater is built into the seat well I seriously doubt to many options are available..
Old 03-04-2008, 02:23 PM
  #56
Lagunatic's Avatar
02C32AMG
This happened to me as well. Took it to the dealer and they replaced the bottom cushion on the seat - not the entire seat. Was covered under warranty.
Quick Reply: heated seat
