02's lemons?
I love the looks of my C32 but the reliability just plain outright sucks.
I had more issues with my M3 then I have had with my C32.
The e46 was never wrecked but had bad front end vibrations, issues with wiring, and the interior didn't last to 65K. The steering wheel looked like a dog had chewed on it and the seats cracked like no tomorrow. The sport button would magically come on by itself and almost got me in a few accidents.
The C32 has been good to me.
So far, I have replaced the TCU, IC pump, and brakes. Other than that, the car has been great...even with all the mods. The previous owner replaced the defective radiator under warranty. The TCU was replaced because I wanted to see if it fixed the tranny jerk, which it did. The IC pump in my mind in a wear and tear item and is an easy fix.
FYI - If you modify your driving style a bit, you can overcome the tranny jerk. I've had a C280 for almost a month now and I can say that it has a tranny jerk too. It's funny because it seems to be worse than the jerk in the C32. The C280 also has a bad 2nd-3rd jerk when under moderate load. Keep in mind this is an 07!
Try driving in bumper to bumper traffic and have it randomly come on when you start to accelerate.
I guess I could say the thing about our sprint booster....It has almost caused a few accidents too. It's funny that something like this would cause you to almost hit someone.
Well, if you go by Renntech's stages for the E55, then I'm actually like a stage IV or V. The car should have close to 400WHP when I get it back on Tuesday. The last time it was on the Dyno, it made 360Whp without cams, porting, or valve work.
Renntech Pulley
Custom Renntech ECU
Evosport Headers
Schrick Cams
Ported / Polished Heads
Custom Valve Job
100 Cell Racing cats
Custom SS exhaust piping
IK-20 plugs
Greenfilters
Magnecor Wires
i love my lemon.
Have you owned the car the whole time? There is a good chance it has already been replaced.
Buy the pump off ebay and keep it on hand.
If it does fail after your warranty, at least there's a cost effective replacement that's well documented on this forum, using the same part from a Ford Lightning.
Those were the more benign common issues. More seriously, there was also a weak transmission mount which sometimes let the transmission move so much under hard acceleration so you'd hit 2nd instead of 4th. Ooops! Hello new crate motor. There was also the infamous plastic impeller water pump in pre-sometime-in-1997 models which could fail prematurely and cause the car to overheat in a matter of minutes. Usually the engine was severely damaged by the time the driver even noticed. You could go ahead and replace it with a later metal impeller unit but the bearings in those were prone to fail, which led to the same problem. You had to pretty much change the water pump every 40k or so. Worse of all were rear subframe mounting points which could crack and break away from the body shell. This was very rare but if it happened, you'd be in the market for a new car because your M would be toast. There was no way to repair it. Companies like UUC offered products to shore up these issues but still.
So the E36 M3 had issues more numerous and serious than our cars yet they never hurt resale. Not making light of the C32's issues but to say it's a lemon isn't really accurate. I think the relatively low resale values can be attributed to other factors -- a more competitive market than 5 years ago, the lack of the gushing media enthusiasm that the E36 M3 received, and the relatively high number of AMG models which has led to a lack of brand identity. For the C-Class alone, we've had the C36, C43, C32, C55 and, soon, C63. The M3 has been the M3 since 1988 and everyone knows what it is. Few people know what my C32 is. I have to explain it.
In any case, for me, it just meant I got a great deal on an excellent car
i got it with 26xxx. i know i havent had it replaced. not sure if the previous owner replaced it or if the stealership did at anytime. i dont think it would have gone bad in the first 26K.
i could always check with the stealership i guess
