what does it take to convert to xenon?
1 Post
03' E39 M5, 10' CLS63 AMG
u'll need to take off the front bumper and then install the Bi-Xenons. and then go to the dealer or some one to set the Xenon's to be present in ur car. other wise the light will not fire up properly
Super Moderator Alumni
Many forum members have done this mod and posted the steps and success of the install. Search the W203 and C32 forums for many threads on this very subject. Good luck.
Super Moderator
The task of installing headlights is straightforward. If you feel compelled to DIY, set aside about three hours to do the deed. Before installing mine, I helped another member (emrliquidlife) with his just two weeks prior. It is not challenging. However, removing the inner fender liners, pulling the bumper free, and simply facilitating proper access to the lights themselves may prove to be somewhat time consuming. https://mbworld.org/forums/c-class-w203/175716-diy-w203-sedan-headlights-removal.html
Do you currently have the halogens? Is so, as Harry posted, the omnipresent electronic spirits will require reprogramming from halogen to xenon via DAS, either from a mod-friendly dealer or a competent independent technician. If you are merely planning to improve light output and night vision, I have a pair of frosty xenons that I’ll practically contribute toward the cause of any MBWorld gentleman in good standing. Should you care to upgrade to the latest and greatest in worthwhile W203 goodies, a set of Euros from MBenzNL is easily justifiable, wherewithal permitting.
The 2003+ BiXenons are the clear lens lamps.
The 2005+ Halogens are also clear lens lamps.
All fit in your car. You should be able to get the 2002 Xenons for a deal.
